Home » Language IDEs » ServerTools (WTP) » [ANN] Web Publisher - Web Authoring Tool for Eclipse (with Ruby Technorogies)
[ANN] Web Publisher - Web Authoring Tool for Eclipse (with Ruby Technorogies) [message #9578] Tue, 28 October 2003 05:46 Go to next message
Originally posted by: narushima_to.ybb.ne.jp
I create web authoing tool for Eclipse Plug-in.
Web Publisher
http://webpub.narucy.com/home.en.html
Download page:
http://webpub.narucy.com/download.en.html
Main features are below:
HTML template parts archtecture. (It like a Macromedia Dreamweaver.)
HTML Editor supports Ruby/Amrita/ERB for automate HTML document generation.
Plug-in for Eclipse Platform. Web Publisher using with Eclipse
Platform base functions and third party plug-in.
Web Publisher rivals are WebStudio, or Macromedia Dreamweaver.
Web Publisher take advantage of using Ruby technorogies. (Ruby
is Object Oriented Script Language.)
Please check it.
Narushima Hironori mailto:narushima_to@ybb.ne.jp
Re: [ANN] Web Publisher - Web Authoring Tool for Eclipse (with Ruby Technorogies) [message #9627 is a reply to message #9578] Tue, 28 October 2003 14:05 Go to previous messageGo to next message
looks like a good effort, but throws the exception below when trying to
open the HTML editor. using 10-23 integration build and j2sdk1.4.2.
org.eclipse.core.runtime.CoreException[2]: java.lang.NullPointerException
com.narucy.webpub.ui.WebpubUIPlugin.initializeDefaultPrefere nces(WebpubUIPlugin.java:101)
org.eclipse.ui.plugin.AbstractUIPlugin.initializeDefaultPlug inPreferences(AbstractUIPlugin.java:631)
at org.eclipse.core.runtime.Plugin.getPluginPreferences(Plugin. java:347)
org.eclipse.ui.plugin.AbstractUIPlugin$CompatibilityPreferen ceStore.initialize(AbstractUIPlugin.java:176)
org.eclipse.ui.plugin.AbstractUIPlugin.getPreferenceStore(Ab stractUIPlugin.java:568)
at com.narucy.webpub.ui.editors.HTEditor.<init>(HTEditor.java:49)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknow n Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Un known
Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
org.eclipse.core.internal.plugins.PluginDescriptor.createExe cutableExtension(PluginDescriptor.java:138)
org.eclipse.core.internal.plugins.PluginDescriptor.createExe cutableExtension(PluginDescriptor.java:179)
org.eclipse.core.internal.plugins.ConfigurationElement.creat eExecutableExtension(ConfigurationElement.java:103)
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:151)
at org.eclipse.ui.internal.EditorManager$3.run(EditorManager.ja va:676)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:960)
at org.eclipse.core.runtime.Platform.run(Platform.java:461)
at org.eclipse.ui.internal.EditorManager.createPart(EditorManag er.java:674)
org.eclipse.ui.internal.EditorManager.openInternalEditor(Edi torManager.java:661)
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:459)
org.eclipse.ui.internal.EditorManager.openEditorFromInput(Ed itorManager.java:333)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:424)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2081)
at org.eclipse.ui.internal.WorkbenchPage.access$6(WorkbenchPage .java:2029)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2016)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:84)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2011)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:1912)
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:132)
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:105)
org.eclipse.jdt.internal.ui.actions.OpenActionUtil.open(Open ActionUtil.java:49)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:15 8)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:14 7)
org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchR un(SelectionDispatchAction.java:194)
org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(Selec tionDispatchAction.java:172)
org.eclipse.jdt.internal.ui.packageview.PackageExplorerActio nGroup.handleOpen(PackageExplorerActionGroup.java:316)
org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$ 5.open(PackageExplorerPart.java:326)
org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:392)
org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:390)
org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:600)
org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:689)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:209)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:204)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:233)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:847)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2173)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1863)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1579)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1562)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:858)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at org.eclipse.core.launcher.Main.basicRun(Main.java:299)
at org.eclipse.core.launcher.Main.run(Main.java:765)
at org.eclipse.core.launcher.Main.main(Main.java:599)
Re: [ANN] Web Publisher - Web Authoring Tool for Eclipse (with Ruby Technorogies) [message #9758 is a reply to message #9627] Wed, 29 October 2003 15:23 Go to previous messageGo to next message
Thanks, these errors cause is not installed or not ruby interpreter
not setted in you eclipse enviornment.
Please check preference page Web Publisher > Ruby Interpreter.
(Next version of Web Publisher notify this error result to user on
screen. thanks!!)
Re: [ANN] Web Publisher - Web Authoring Tool for Eclipse (with Ruby Technorogies) [message #9780 is a reply to message #9758] Thu, 30 October 2003 12:16 Go to previous messageGo to next message
does it need a ruby interpreter? i don't have one installed. can i use
it without one? if not, which plugin do i need to get?
Re: [ANN] Web Publisher - Web Authoring Tool for Eclipse (with Ruby Technorogies) [message #9823 is a reply to message #9780] Fri, 31 October 2003 03:59 Go to previous message
Hi, thanks for your message.
Yes. Web Publisher requires Ruby Interpreter.
(If you hete Ruby script and you link Python or PHP, Web Publisher
is not render to you...
To do ruby install, I recommend this to use installer as follow:
http://sourceforge.net/projects/rubyinstaller/
Take it easy!
Narushima Hironori mailto:hironori@narucy.com
Previous Topic:Introduction, Apologies for the Slow Start, and Invitation to Work on WSVT
Next Topic:Status Update
Current Time: Tue Jul 15 12:55:33 EDT 2025
Powered by FUDForum. Page generated in 0.07499 seconds
