Visual Editor installation [message #105280] |
Tue, 06 September 2005 02:28  |
Originally posted by: SashaNeftin.gmail.com
Hello all,
Last period I was develop in the Websphere Studio and use Visual
Editor for develop GUI application.
I have question about process installation of the Visual Editor in Eclipse.
I download:
1. Eclipse SDK Version: 3.1.0. Java Runtime Envonment: jre1.4.2_08.
2. EMF build 2.1.0.
3. GEF Build 3.1.
4. VE-runtime-1.1.zip.
5. I install it and copy plug in into plug in folder of the Eclipse.
6. I did restart from the command line with eclipse -clean.
When I do File->New I don't see in the list below Visual class yet.
Can you help me install it please?
Sasha Neftin
Tel: +972-545200879
Re: Visual Editor installation [message #105489 is a reply to message #105458] |
Wed, 07 September 2005 09:32   |
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Try using the update manager instead. Install just Eclipse 3.1 SDK, then
use the Help->Manage Configurations->Find and Install...
From there select VE, EMF, and GEF.
By the way you don't need BOTH VE runtime and VE SDK. The SDK includes
the runtime. SDK gives the source too. Unless you are doing VE
extensions you don't the VE SDK.
Sasha Neftin wrote:
> 1. I install emf-sdo-runtime-2.1.0, VE-runtime-1.1, GEF-runtime-3.1 and
> VE-SDK-1.1.zip and unzip it.
> 2. I did restart the Eclipse from CLI with the "eclipse.exe - clean".
> 3. I don't see some changes in menu bar File -> New , I haven't Visual
> Class.
> 4. I try copy plug in from
> emf-sdo-runtime-2.1.0,VE-runtime-1.1,GEF-runtime-3 and VE-SDK-1.1 into
> folder plug in of the Eclipse, and again : restart with "eclipse.exe -
> clean".
> 5. No changes.
> Please, can you support me some step by step instruction for install
> Visual Editor.
> Sasha Neftin
Rich Kulp
Re: Visual Editor installation [message #105502 is a reply to message #105489] |
Wed, 07 September 2005 09:35  |
Let me rephrase how to get the update manager, the text has changed for 3.1:
Help->Software Updates->Find and Install...->Search for new features
Rich Kulp
Re: Visual Editor installation [message #610672 is a reply to message #105280] |
Tue, 06 September 2005 12:49  |
What do you mean by copy plugin to plugin? All you need to is unzip each
zip file into the same directory. That is the way to install the zip files.
Sasha Neftin wrote:
> Hello all,
> I download:
> 2. EMF build 2.1.0.
> 3. GEF Build 3.1.
> Sasha Neftin
> Tel: +972-545200879
Rich Kulp
Re: Visual Editor installation [message #610681 is a reply to message #105330] |
Wed, 07 September 2005 00:59  |
Class.
clean".
5. No changes.
Visual Editor.
Sasha Neftin
Re: Visual Editor installation [message #610684 is a reply to message #105458] |
> Class.
> clean".
> 5. No changes.
> Visual Editor.
> Sasha Neftin
Rich Kulp
Re: Visual Editor installation [message #610685 is a reply to message #105489] |
Rich Kulp
FUDForum. Page generated in 0.14769 seconds
