translateToRelative [message #105213] |
Fri, 14 November 2003 14:41  |
I thought I had got my head around draw2d's coordinate system - but
obviously not. I'll try simplify my problem to get to the point. If I
have a root edit part with a rectangle edit part as its child say at
location 50,50. I now have a point (p) in absolute coordinates which I
want to understand as a relative coordinate to the rectangle's figure. I
thought that I could call:
Rectangle.translateToRelative(p)
Obviously not, because the result is exactly the same as before the call.
What am I doing wrong?
James
Re: translateToRelative [message #105244 is a reply to message #105229] |
Fri, 14 November 2003 16:07   |
Thanks Randy, I'm not sure I fully understand. The result I'm expecting
(trying) to get is given a rectangle figure at 50,50 (as a child of the
root figure), then an absolute point 150,150 should be translated to
100,100. I thought by calling Rectangle.translateToRelative(p), that
would be the resulting value of p.
James
Randy Hudson wrote:
> The resulting point will be relative to the rectangle's *bounds*.
> So, you can then call Rectangle.getBounds().containsPoint(pt);
> The resulting point will not be the same when scrolling vertically. Make
> sure you are not translating a point you don't own.
> "James Willans" <jwillans@cs.york.ac.uk> wrote in message
> news:bp3b56$l4i$1@eclipse.org...
> > James
Re: translateToRelative [message #105255 is a reply to message #105244] |
Fri, 14 November 2003 16:53   |
Nope, it doesn't do that. You can always easily do that by making the
following additional call:
point.translate(rectangle.getClientArea().getLocation().nega te();
the reason that "relative" is defined is relative to the figure's bounds, is
because hit-testing is performed using the figure's bounds. So, you may be
asking when does translateToRelative do anything? The answer is when a
figure's *parent* affects the coordinates in which the figure exists/paints.
For example, a wrapper figure which applies a zoom factor, or Viewport,
which provides scrolling by translating the coordinate system.
news:bp3g61$qoa$1@eclipse.org...
> James
Make
I
I
I
call.
> > > James
Re: translateToRelative [message #105269 is a reply to message #105255] |
Fri, 14 November 2003 19:30  |
Thanks Randy. The coordinate system is beginning to make sense.
James
> > James
> Make
> I
> I
> I
> call.
> > > > James
FUDForum. Page generated in 0.07125 seconds
