Home » Archived » BIRT » Passing a parameter to an ORDER BY clause
Passing a parameter to an ORDER BY clause [message #105174] Thu, 05 January 2006 17:57 Go to next message
Originally posted by: kelly.penhallwilson.bricsnet.com
Using M3 currently - I'm having an interesting issue with trying to pass
a parameter to an ORDER BY clause. What's interesting is that it works
properly with a type 3 JDBC driver, but not for either of the type 4
drivers I've used (MSSQL server is the database - the type 3 driver is
an old weblogic driver, and the type 4 drivers are jdts and microsoft's
new beta type 4 jdbc driver).
The parameter is set in the Data Set - the ORDER BY clause is simple:
ORDER BY ? DESC
Here's the error message from the microsoft driver - the error from the
other type 4 driver was similar, but referred to the prepareStatement:
A Birt exception occurred.
Plug-in Provider:Eclipse.org
Plug-in Name:BIRT Data Engine
Plug-in ID:org.eclipse.birt.data
Version:1.0.1
Error Code:odaconsumer.CannotGetResultSetMetaData
Error Message:Cannot get the result set metadata.
SQL statement does not return a ResultSet object
The SELECT item identified by the ORDER BY number 1 contains a variable
as part of the expression identifying a column position. Variables are
only allowed when ordering by an expression referencing a column name.
Any idess would be helpful - thanks-
kpw
Re: Passing a parameter to an ORDER BY clause [message #106319 is a reply to message #105174] Mon, 09 January 2006 12:10 Go to previous messageGo to next message
Originally posted by: wheeler.ninjart.com
Am Thu, 05 Jan 2006 14:57:46 -0800 schrieb kellypw:
I tried that too, but i didn`t work.
Is it possible at all to use parameters like this?
> ORDER BY ? DESC
Is there any other way to do this?
Hoping for answers ;)
Re: Passing a parameter to an ORDER BY clause [message #106621 is a reply to message #106319] Tue, 10 January 2006 03:12 Go to previous messageGo to next message
>>ORDER BY ? DESC
You could build the query via script in the beforeOpen method of the
Dataset. Just set the queryText variable according to the value of the
parameter.
queryText = "SELECT ... ORDER BY " + params["p1"];
Stefano
Re: Passing a parameter to an ORDER BY clause [message #107127 is a reply to message #106621] Tue, 10 January 2006 16:57 Go to previous messageGo to next message
I'm very confused -then what would go into my Query?
>>> ORDER BY ? DESC
> parameter.
> Stefano
Re: Passing a parameter to an ORDER BY clause [message #107262 is a reply to message #107127] Wed, 11 January 2006 05:07 Go to previous messageGo to next message
You can put anything on the query in the dataset property window, it
will just be evaluated at design time when you click on "Preview
Results". At runtime (and when you preview the report) the query will be
set by the script.
>>>> ORDER BY ? DESC
>> parameter.
>> Stefano
Re: Passing a parameter to an ORDER BY clause [message #108681 is a reply to message #107262] Thu, 12 January 2006 14:59 Go to previous message
Thanks - I was very confused by that - I will try it...
> set by the script.
>>>>> ORDER BY ? DESC
>>> the parameter.
>>> Stefano
Previous Topic:ORDER BY clause ignored in web viewer
Next Topic:Ability to set the width in a cell via scripting?
Current Time: Mon Jul 14 23:31:58 EDT 2025
Powered by FUDForum. Page generated in 0.65645 seconds
