[ATL] HOT transformation [message #105112] |
Sun, 17 May 2009 07:39  |
I have a ATL transformation which take one input and produce in output
one ATL transformation (High Order Transformation), it works fine with
ATL 3.0 (tested with Galileo M7).
Now I want execute this output ATL transformation, but this output is in
XMI format, then my first question is, can I execute directly my ATL
transformation in XMI format and how?
If not possible, I could transform my XMI format in concrete syntax to
execute a .atl. With TCS I could do it, but I don't find TCS source code
repository. What is the status of TCS, what is the project plan. And
what is TCS compared to TMF Xtext from oAW?
I found AMW project from GMT which use HOT transformation, but it
doesn't works and I don't understand these sources.
Thanks.
Re: [ATL] HOT transformation [message #105226 is a reply to message #105112] |
Mon, 18 May 2009 07:57   |
Esteban DUGUEPEROUX a écrit :
At this time you can't.
ATL 3.0 API provide utilities to:
- output ATL source code from an ATL model
* org.eclipse.m2m.atl.engine.parser.AtlParser
* available within ATL ant tasks, use "ATL" extractor
- create an ATL model from ATL source code
* available within ATL ant tasks, use "ATL" injector
- compile ATL source code to an ASM file/outputstream
* org.eclipse.m2m.atl.engine.compiler.AtlCompiler
- compile an ATL model to an ASM file/outputstream
* org.eclipse.m2m.atl.engine.compiler.AtlDefaultCompiler
> Thanks.
William
FUDForum. Page generated in 0.25817 seconds
