Home » Archived » Test and Performance Tools Platform (TPTP) » [TPTP AGR] Running in Standard Mode with fixed size and position
[TPTP AGR] Running in Standard Mode with fixed size and position [message #105048] Mon, 16 July 2007 06:21 Go to next message
Originally posted by: emontagne.odyssey-group.com
I test a plugin that use SWT and some test cases use position based
recording.
When I run the test in standard mode, the workbench is launched and
maximized. But to able to run it on different hosts (different screen
resolution and one or two screens) I would like to open the workbench at a
specific place (0,0) with a fixed size (1000x800 for example) not the
maximum size.
How to do this?
Eric Montagne
Re: [TPTP AGR] Running in Standard Mode with fixed size and position [message #105079 is a reply to message #105048] Mon, 16 July 2007 14:18 Go to previous message
Hi Eric,
If you know the exact size and which configuration goes with which size, you
can record separate test cases which specifically resize the workbench and
enable/disable them based on the host you are running on.
I am not aware of an alternate shortcut for setting the workbench size and
location (coordinates). However, I think you bring up a good idea for an
enhancement whereby a user could manually set the preferred size in the
Overview page of each test suite. I have opened the following bugzilla to
address this:
Please feel free to add your name to the CC list and
comment/contribute/track its progress:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=196702
Let me know if there is anything else I can assist you with.
Sincerely,
Liz Dancy
"Eric Montagne" <emontagne@odyssey-group.com> wrote in message
news:f7fgqe$u4h$1@build.eclipse.org...
> recording.
> maximum size.
> How to do this?
> Eric Montagne
Previous Topic:Profiling Eclipse itself
Next Topic:ExecutionTimeAnalysis + MemoryAnalysis
Current Time: Sat Jul 26 00:18:11 EDT 2025
Powered by FUDForum. Page generated in 0.11586 seconds
