Re: How to register a Xcore model ? [message #837824 is a reply to message #837468] |
Fri, 06 April 2012 06:17 |
Ed Merks Messages: 33142 Registered: July 2009 |
Christiano,
Comments below.
On 05/04/2012 7:58 PM, Cristiano Gaviao wrote:
> In EMF projects we use the org.eclipse.emf.ecore.generated_package
> extension point to register packages from models:
> <extension point="org.eclipse.emf.ecore.generated_package">
> <package uri = "http://www.xtext.org/example/Domainmodel"
> class =
> "org.eclipse.xtext.example.domainmodel.domainmodel.DomainmodelPackage"
> genModel =
> "org/eclipse/xtext/example/domainmodel/Domainmodel.genmodel" />
> </extension>
The generator does already generate registrations, but it's for the
Xcore resource, which does contain a GenModel, so should be fine. I
think it probably doesn't work though because the registration doesn't
indicate which offset within the resource contains the GenModel. Please
open a bugzilla so you can track the fix for that.
> How could I do that with Xcore models ?
> regards,
> Cristiano
Ed Merks
FUDForum. Page generated in 0.02391 seconds
