Home » Eclipse Projects » Eclipse Platform » building eclipse ... with eclipse
building eclipse ... with eclipse [message #104891] Fri, 01 August 2003 15:41 Go to next message
Originally posted by: tcn.spamgourmet.com
Hi!
I downloaded eclipse-sourceBuild-srcIncluded-3.0M2.zip since I though I
might be able to fix some things quickly for myself.
Well...there are ant scripts but it turns out to be kind of hard to import
the whole bunch into eclipse itself. Do you developers develop eclipse with
vi rathen then with eclipse itself?!?!
So, how to I import all the stuff into eclipse? :-)
Timo
Re: building eclipse ... with eclipse [message #105081 is a reply to message #104891] Fri, 01 August 2003 15:51 Go to previous messageGo to next message
Originally posted by: pascal_rapicault.yahoo.fr
Depending on what you want to change I advise you to directly load the code
from the ide using the "import" feature.
Otherwise you can also download the code from the repository.
These are the way we are building eclipse in eclipse.
PaScaL
This is not the way we are working with Eclipse.
If you want to
"Timo Nentwig" <tcn@spamgourmet.com> a
Re: building eclipse ... with eclipse [message #105361 is a reply to message #105081] Sat, 02 August 2003 07:10 Go to previous messageGo to next message
Well, eclipse CVS is not open for the public, is it?
Re: building eclipse ... with eclipse [message #105388 is a reply to message #105081] Sat, 02 August 2003 07:26 Go to previous messageGo to next message
> code from the ide using the "import" feature.
Well, that's just the problem I cannot simple import the plugin/
directory...
Re: building eclipse ... with eclipse [message #105424 is a reply to message #105361] Sat, 02 August 2003 08:50 Go to previous messageGo to next message
Yes it is open.
server: dev.eclipse.org
repo name: /home/eclipse
user: anonymous
Re: building eclipse ... with eclipse [message #105435 is a reply to message #105388] Sat, 02 August 2003 08:54 Go to previous messageGo to next message
No I'm talking of File > Import > External plug-ins and fragments.
Re: building eclipse ... with eclipse [message #105445 is a reply to message #105424] Sat, 02 August 2003 11:00 Go to previous messageGo to next message
> Yes it is open.
Thanks a lot!
Re: building eclipse ... with eclipse [message #105484 is a reply to message #105445] Sat, 02 August 2003 13:49 Go to previous messageGo to next message
>> Yes it is open.
> Thanks a lot!
Hmmm, I still have problems, FiltersAction (org.eclipse.ui.views) cannot
resolve org.eclipse.swt.widgets.Shell despite I checked out
org.eclipse.swt.
And there are plenty of such problems :-(
Re: building eclipse ... with eclipse [message #105630 is a reply to message #105484] Sat, 02 August 2003 17:56 Go to previous messageGo to next message
I bet you have compile errors in swt.
If you don't change the build path.
PaScaL
Re: building eclipse ... with eclipse [message #118753 is a reply to message #105484] Thu, 28 August 2003 10:38 Go to previous messageGo to next message
Originally posted by: Andre_Weinand.oti.com
On 2.8.2003 19:49 Uhr, in article bggtiq$9i2$1@eclipse.org, "Timo Nentwig"
<tcn@spamgourmet.com> wrote:
>>> Yes it is open.
>> Thanks a lot!
> org.eclipse.swt.
Do you really want to fix something in SWT?
If not, just PDE-import SWT.
Otherwise you'll have to rename the .classpath_<platform> for your platform
to .classname
--andre
Re: building eclipse ... with eclipse [message #120050 is a reply to message #118753] Mon, 01 September 2003 11:21 Go to previous message
On 28.8.2003 16:38 Uhr, in article BB73E092.1D8B1%Andre_Weinand@oti.com,
>>>> Yes it is open.
>>> Thanks a lot!
>> org.eclipse.swt.
> to .classname
> --andre
Oops, I meant ".classpath" (not .classname).
--andre
Previous Topic:Internationalization
Next Topic:JBuilder to Eclipse Migration
Current Time: Wed Oct 22 23:35:19 EDT 2025
Powered by FUDForum. Page generated in 0.04712 seconds
