Home » Archived » M2M (model-to-model transformation) » [ATL] Using two input models
[ATL] Using two input models [message #104829] Mon, 11 May 2009 05:50 Go to next message
I am creating a model transformation that takes two input models of
different metamodels ('slco' and 'channels'). The model adhering to the
'channels' metamodel is nothing more than a list of elements occurring in
the other one. It is called 'channels_in'.
Now I have a helper (shown at the bottom of this post) that accesses this
'channels_in' model and collects all items in this model as an OrderedSet.
I checked he 'Allow inter-model references' checkbox.
This works fine. I get a Sequence (even though I asked for an OrderedSet
to remove duplicates) that looks as follows:
Sequence {IN!Ch1}
'IN' is the model adhering to the 'slco' metamodel.
I then copied this helper to another transformation with the same input
and output signature, because I also need it there.
Howerve, now It doesn't work the way I want it. The result looks as
follows:
Sequence {Channels_in!Ch1}
As you can see, I get the elements from the wrong model.
What can be the cause of this and how can I solve it such that the helper
returns the model elements from the right model? Any help is much
appreciated!
Marcel
The common part of the transformations:
create OUT: slco, Channels_out: channels from IN: slco, Channels_in:
channels;
helper def: channelList : OrderedSet(slco!Channel) =
channels!ChannelList.allInstancesFrom('Channels_in')->collect(i|i.Channel)- >flatten();
Re: [ATL] Using two input models - some more symptoms [message #104909 is a reply to message #104829] Mon, 11 May 2009 07:10 Go to previous messageGo to next message
In the first transformation (the correctly working one), I use a hand-made
model 'channels_in'. In the second one, I use an ATL generated one.
When I look at these text files, there is a difference in the path to the
element:
First:
<Channel href="Test.slco#//@channels.0"/>
Second:
<Channel href="/SLCO Sync2ASync/Test_out.slco#//@channels.0"/>
When I manually remove the '/SLCO Sync2ASync/' part, the second
transformation also works.
Re: [ATL] Using two input models - some more symptoms [message #104979 is a reply to message #104909] Thu, 14 May 2009 03:13 Go to previous messageGo to next message
> hand-made model 'channels_in'. In the second one, I use an ATL generated
> one.
> the element:
> First:
> Second:
may be the space between "SLCO" and "Sync" couild be the problem. Use
names with no space or special characters.
Cordialement
Vincent MAHÉ
Ingénieur Expert
IRISA-INRIA, Campus de Beaulieu, 35042 Rennes cedex, France
Tél: +33 (0) 2 99 84 71 00, Fax: +33 (0) 2 99 84 71 71
Re: [ATL] Using two input models - Solved [message #104982 is a reply to message #104979] Thu, 14 May 2009 08:53 Go to previous message
The spaces were indeed the problem.
I removed them and everything works fine now.
Thanks a lot!
Previous Topic:[ATL] Multiple output models with the same metamodel, possible?
Next Topic:Match rule (assigning the default target element of another rule)
Current Time: Wed Jul 16 09:32:54 EDT 2025
Powered by FUDForum. Page generated in 0.08352 seconds
