Home » Language IDEs » C / C++ IDE (CDT) » getting started (newbie)
getting started (newbie) [message #104777] Fri, 04 June 2004 15:20 Go to next message
Originally posted by: maz.wpi.edu
This is a newbie question. im trying to use eclipse for c++ for the first
time. I try to go through the tutorial that is included with the plugin.
But once i create either a standard make or managed make project in the
problems i get this error
Error launchin external scanner info generator (gcc -E -P -v
c:/eclipse/workspace/.metadata/.plugins/org.eclipse.cdt.make .core/specs.cpp)
when i try to build after creating the hello world main.cpp and the
makefile if i choose standard make it cannot find the make program or
start it. I tell it to use the default make the error is
Error launching builder (make -k all )
(Exec error:Launching failed)
Do i need to download something else besides the plugin zip file?
Thanks for the help
Matt Maziarz
p.s. I tried searching the internet and help files to find a solution
sorry if i missed it
Re: getting started (newbie) [message #104805 is a reply to message #104777] Fri, 04 June 2004 17:08 Go to previous message
You didn't install a compiler, did you?
Use either Cygwin or MinGW32.
> Thanks for the help
> Matt Maziarz
Previous Topic:CDT : problem running projects
Next Topic:CDT 2.0 Source
Current Time: Sun Aug 31 17:36:43 EDT 2025
Powered by FUDForum. Page generated in 0.03794 seconds
