Home » Archived » Visual Editor (VE) » Off-screen drawing
Off-screen drawing [message #104717] Thu, 01 September 2005 13:30 Go to next message
Is there any way in SWT to create a Shell or Display that is off-screen,
so that standard SWT controls draw to memory instead of the screen? For
example to create thumbnails in a visual builder.
I was forwarded here from the SWT newsgroup with the hint that there are
platform-specific solutions.
Jonathan
Re: Off-screen drawing [message #104736 is a reply to message #104717] Thu, 01 September 2005 13:47 Go to previous message
Originally posted by: myersj.gmail.com
Hi Jonathan,
The Visual Editor uses this technique to grab images of SWT controls to
use within its design view. Unfortunately as you say, it requires
platform specific code.
Here's the code to do this on Windows:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.ve.swt/ vm_swt/org/eclipse/ve/internal/swt/targetvm/win32/ImageCaptu re.java?rev=1.11&cvsroot=Tools_Project&content-type= text/vnd.viewcvs-markup
And on GTK:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.ve.swt/ vm_swt/org/eclipse/ve/internal/swt/targetvm/unix/ImageCaptur e.java?rev=1.10&cvsroot=Tools_Project&content-type=t ext/vnd.viewcvs-markup
GTK requires the use of a native library to capture the image:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.ve.swt/ os/linux/x86/?cvsroot=Tools_Project
As of yet the VE does not have code to accomplish this on OS X.
Hope this helps,
- Jeff
> Jonathan
Re: Off-screen drawing [message #610585 is a reply to message #104717] Thu, 01 September 2005 13:47 Go to previous message
Hi Jonathan,
And on GTK:
Hope this helps,
- Jeff
> Jonathan
Previous Topic:Off-screen drawing
Next Topic:Internal Error: Setup Java Visual Editor
Current Time: Fri Jul 25 09:46:24 EDT 2025
Powered by FUDForum. Page generated in 0.04872 seconds
