Home » Archived » BIRT » Birt 2.0RC little problems
Birt 2.0RC little problems [message #104704] Thu, 05 January 2006 04:38 Go to next message
------=_NextPart_000_001F_01C611E4.38D70870
Content-Type: multipart/related;
type="multipart/alternative";
boundary="----=_NextPart_001_0020_01C611E4.38D70870"
------=_NextPart_001_0020_01C611E4.38D70870
Content-Type: multipart/alternative;
boundary="----=_NextPart_002_0021_01C611E4.38D70870"
------=_NextPart_002_0021_01C611E4.38D70870
Content-Type: text/plain;
charset="iso-8859-1"
Hi all,
the Birt 2.0 RC is verry verry good, and i will thanks for this great =
product.
But I have tested it und this little problems in the moment I found:
A chart with parameter do not work, this is the error
when I delete the parameter from the binding I can edit the chart =
without error.
I have attached two pdf's (birt20M3.pdf und birt20RC.pdf) here you can =
see my other problems.
The rptdesignfile where I generated the pdf's are the same.
This are the problems in birt20RC.pdf
a.. The pagebreak is wrong,=20
b.. after the pagebreak there is no headrow,
c.. the columwidth is allways the same,
d.. the rowheight is on the 3. page wrong
e.. from the masterpage there fails the right column.
f.. on the last page there fails the footrow.
The problems with the fonts in Birt2.0M3 is repaired.
The image of the chart are considerable better.
The template are works, the libary are works and also many other =
problems are repaired.
I have a verry important presentation with BIRT on 26.Jan.2006, what do =
you think, the problems in pdf are eliminated on this date?
Once moore thanks
Kurt
Content-Type: text/html;
<HTML><HEAD>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2800.1528" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV><FONT face=3DArial size=3D2>Hi all,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>the Birt 2.0 RC is verry verry good, =
and i will=20
thanks for this great product.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>But I have tested it und this little =
problems in=20
the moment I found:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>A chart with parameter do not work, =
this is the=20
error</FONT></DIV><FONT face=3DArial size=3D2></FONT>
<DIV><FONT face=3DArial size=3D2><IMG alt=3D"" hspace=3D0=20
src=3D"cid:001901c611db$d70050f0$464da8c0@kommserver" align=3Dbaseline=20
border=3D0></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>when I delete the parameter from the =
binding I can=20
edit the chart without error.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I have attached two pdf's (birt20M3.pdf =
und=20
birt20RC.pdf) here you can see my other problems.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>The rptdesignfile where I generated the =
pdf's are=20
the same.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>This are&nbsp;the problems in=20
birt20RC.pdf</FONT></DIV>
<UL>
<LI><FONT face=3DArial size=3D2>The pagebreak is wrong, </FONT></LI>
<LI><FONT face=3DArial size=3D2>after the pagebreak there is no=20
headrow,</FONT></LI>
<LI><FONT face=3DArial size=3D2>the columwidth is allways the =
same,</FONT></LI>
<LI><FONT face=3DArial size=3D2>the rowheight is on the 3. page =
wrong</FONT></LI>
<LI><FONT face=3DArial size=3D2>from the masterpage there fails the =
right=20
column.</FONT></LI>
<LI><FONT face=3DArial size=3D2>on the last page there fails the=20
footrow.</FONT></LI></UL>
<DIV><FONT face=3DArial size=3D2>The problems with the fonts in =
Birt2.0M3 is=20
repaired.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>The image of the chart are considerable =
better.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>The template are works, the libary are =
works and=20
also many other problems are repaired.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I have a verry important presentation =
with BIRT on=20
26.Jan.2006, what do you think, the problems in pdf are eliminated on =
this=20
date?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Once moore thanks</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Kurt</FONT></DIV></BODY></HTML>
------=_NextPart_002_0021_01C611E4.38D70870--
Content-Type: image/gif;
name="charterror.gif"
Content-ID: <001901c611db$d70050f0$464da8c0@kommserver>
R0lGODlhHALXAfcAANfSyv///wAAAIKCgv8AAAAAgm2GypKy4zlFpiQtmllt vqLG74ai2xQYjn2a
10lZsl1xvpa25zVBpjE9onmW0gwQimF1wiAolqbK857C63WOzkFRrlVpuhwk lhgckj1JqnGKzoKe
1xAUji01noqq32V9xlFhtkVVrpq6546u4wgMhk1dtoqm33WS0hggkj1Nqpq+ 656+61Vluhwgki05
nggIhoIAAAQEghAUiml9xmF5wkFNqmmCyk1hto6q3zE5onmS0gwMiqbK7ygx nmV5xmmCxigxmig1
nkVVsllpunGOzpa656LC70VRroKe246u301dslFltoam2wQIhhQcjiAoml11 wjlJqpKu4yQxmlFl
unGKyiAklkldsmV5wjU9ojVBoklJkgAEggQEhmlZ64Ki232W0klVsoqm24Ka 1xAQii05ohQckqbG
7xAYjl1xwpq6622Cyn2W15a240FNrm2KylFFqlFJsk1Fpk1FolVJtkFBhlFF rkFBgkVBjoqi0lFJ
rlFRmnGKvllZojU1fVVJuiAgbU1FqkVBkklFmkVBijkxkoKaznWOwhgYZX2W xklBlklFnqam0teq
zk1FnhAQXSgodYaeznmSxklFloKaynmSwmltsj09isrK5+/b6+PC33Fxpn19 ss6y0mFlqlFRkpKS
xnl1ukVFjrKu17KOwo6Ovsqexte20klJmi0ogm1tsp6CukFBirqaxi0odUVF ilFNoq6awmFdotvO
58aOvo55rmVlqigtdcqiyj09hpJ9vlFJtqaCsuPX63Fxupp9uiQgbXl5qlFJ ihwcbYaGtiQkedLO
53VtspZ5ssaeykVBmsrG4+PC286uzraawl1ZpmVhqsaexv////////////// ////////////////
/////////////////////////////////////////////////////yH5BAEA ANgALAAAAAAcAtcB
AAj/AAEIHEiwoMGDCBMqXMiwocOHECNKnEixosWLGDNq3Mixo8ePIBNiGwkg gMmTKFOqXMmypcuX
MGPKnEmzps2bOHPq3Mmzp8+fQIMKHUq05QABJUMqXcq0qdOnUKNKnUq1asej Sa1q3cq1q9evYMOK
9Yg1gMACaNOqXcsWrZi3Ym7InTu3ht27d1Xo3Rukb5AKgAGrGYyjsGHDDRIr XqyYimMqHiJHduFi
huXLljto3tyBi+cLoEOLTkC6tOkERlKrTn2k9YjXsEfQmE2bxpofuH9M2L37 i2/fYIILByOhOILj
yJNfufKhefMX0F/smE59B50N2Dc02X6iu3fvZx6I/x9PXnyXLlDSq4fSo317 E/BNRJk/X4sWGfjx
c9jPIYn//woEKKACEBRo4IEQWKGgBQw2qMODXkQYIREUElHChTlkqGEORXTY YRwghhiHASSWaEAd
W6SoIggsKuGiBjDGqEELLQBh4404UkCBGTz2yKMDQAaZxpAhFGmkkWUkycCS TErhJBpQRhklCVT6
YKUPT2SpZZZYdInFAWCGCeYcZJZZ5hJoponCmmyiAAMMMcQZZwZ01mknE0ws oOeeC7ThpxCABiro
oIQKIVBZZ6FFxqKMNtooW3DFRRddeFW6F19+BSYYYYcdxtiniT0GmWQeUIYZ Zpxt5hkXorV6wWmw
rv+2WmtHxAZbbbTdlhtvvf32xXDCFSdBcsQisJxzz0VXHXXXZbddE99FG155 1J63nnruvRcfffXd
l58M/PX3n38DCojguQpa0aCDEEroRYUWYrhhhh5+KCKIJpaIooopsgiCi0rI GCONOBYMhI4++hik
kEQeeWSSZTDZ5JNSSkklCVdiuaWWXn4pZphmhpymmm2u+aacc9qpMp587uln G4XGXOihSJkFgKJ9
5LyHIn6ggkgmiVCSBx52hLFWpJNSWmlel6rg11+aDqZGp56CypiopJZa2amZ pdrZZ66GButpsqpG
q62v4TqbrrjxOoGvvwJLnHHFIncsstFJt6x12Wn/x1204FFbLXrXspdtfPJx a9+34PI3LrnlEnju
gemuy+CDOrj7boUXljAvvfXei2++J/Lbb4svCjxjjQbfiHDCPy7swJBpOPyw khIz4KQUFVtc5ZUb
c+zlxyCHfObIS5RsMpwoq7xyni33+WegMwkAKM1Z4ZyzLLUo8jPQQhNttFpI Jy3X0kxf+rSmFUhN
NWJWL4Y1qaZyPYPXX7MaNmhjm1Y2a65Bm9pskxvd8ApucpvbsOp2nLs5J297 45uz/ga4E0xLcOOx
VuGy1QPEcSsKi/tWuB6XhMhJbnIFqpzlMKc5eHXucxwKnehIVzrT+Qtgqltd 61y3I9iZQXaza5jt
/0IAsdzpjmK9Q8PFMhY8Lg2PeAcw3vFGpjw3MU9OzrsT9Fr2MkHZbCFHuR4A EHWzApAhZ6WgRitG
AYxTwKIathjaIcaXlvLRxSQ3wItJ0oepvrDPfe/DQfzk95is1Y9r+FvV/vjX P9L8zwhnE6Da2GZA
3iBQbsJiYAOZgzdl7a1Z2HlWBbtzQQw+QIPX4qAHFeet/IzwcSZEoYFUuC4W usuF8ppXvYoguhGR
bl/8umHqBEawHR6sh7ADIu2GWKQi5m53SYTSEoHXxI5BMYpSnAPykqe8kzUv i3RiWfS6SL2GhNFQ
Y6xZosiwh1pM4xO5kAQxOMGLQQTCFeJDS0rekv80POoxAHzUy/qixqn3DbIx haTf1hDpNUUuspGO
/F8kbTVASrrtksDKpCYdmCzoRBCUfoPWKEuJQVSuR5XbYiXjXjmuWMoyQQta YbskhEvPfW6XvaQh
MFeEuoCprpg7fF0yZbdMZjpTYtCM5jSt1MQnWBOK2dQm8qroTSyCMwPi5OL0 APVFASBlIF6lmRjJ
qChFCEMaw/CEJOhpzzD8AhpF02cACmDHufjzLnu0S9OclimCTi2QBw1VQiVz yFMlEmz7gyhqJBpA
ik6ygBf1VQI1ykCOfgCCn+ybKEdqygwSLpWHSyl9QuhKx8Eyci+Fqbpkmrlb ci6XG8LpDH9pui3/
CNOnxGRdUJGZMGUK0XZHnRjvlPo7plbzicSL6japesWUgTOrfCInVwkSVgBU N51jVWcZyYAKVkiD
GdFIhSlWoQxRHCMUuADE+ExCV7igRC4psUteUaIXkwQhAFALDCANGtj5EXah hm0oYsOm2EdONDYV
hewBJYtJulWWkw/05LJAutkKklRwJsVWaOHzQdLqx7QtRe1Lacmu1tL0tTbV pQzvpdPa3jaHQG2d
UHtL1N86LLhLSmoSl6qx4D01udlcbjebG4OrYnWL0d2qEL4oEK9eF7voJKsZ UTGJP/zhEozQxCMw
sYlGCEIQ6pXrScSAxxvg0Z97THMA6rtmlOR3/1N/5e9B/TsZAKNKwPpLLEQN 3FgEP3ZXC/7NZB1c
N8tidsKapSDgLjy4whnOPascbSs/vB8SulSWJL7cTCeEYhjKlsW0tWFPYaxb GfNWYTWunVFxh1Qk
9o7HTf3xx5Q71SGjrMhXha7LlMzkJn91IOfEns0UhYhJ6KIZ9QyEWwnRC2Mk I8wFYK97U2LmAORR
zTVQiQrs60e/BlKQ/R1sne13Pzwv8lV7ZmytJIkriwYaOA1e4IORdVkJV4fC ipZWZ83z2ZNuOHGS
XimIASRiTMe0lpveHIVeeNMVi6jFov7XMGUUY4PNGNULK+oQcXzE4e64uD3e mKzFRGsq2vqbz/9F
8q5hVk7qOpkgwU5n9syYiWtY+RKa0DKXvSyIO6x3rtOeFJoBquamcfvN7Sso 1QLbADprjdyHzTOB
0122A9/qz217d9wySuhiGdrezEq0SC2871P2W8OQFm23BF7p05YrtZm2gC1P vHDYaujTDw91MEf9
01Jb/NQ98q2qN85q4UZTiSCPNXJnHeRal6yqzs2irvUk3SW73NfAtl6Utauo RMTCF85Q9i+YbQxH
VGIRPpdre8ls7TtaO9tEj73R8dtt/Sq9U0x3emHvnCqH6rmRfF63Y9utYEsy mOvyLjSEO6o3RE9w
7Isue4bTg1IOq1SEA4fc20d88BK3sNMN91D/TvXOU4njluJ+L9jFA59qZhKx 8Dl2dcVgfdwuXbPk
JHs8kY08eemxfLqYB1ZfFXNSRgaUQAmqcA27gAqkZ3qvcAd68HOrx3onUW3X FnvyRV9H90e3VzVz
Jm5PZz9Rd24Fpm5oIxtYV0m9ImjxpknGsnz15lGZ9XyjZEHSd3bU928dNmmN 03Yhtn0Gt1oIZ2Kc
VncpFlsOFyIQt3fmR2rGdEw+9EPtt2oR80zy5zsYQ00+tngk13gmp3+3xn8q R3m8Zk6aJ2zrlAdq
WAyzcAvIQAvGsAyoFwwReDRwYT7ngz41sFcDZXtxtnTh5hiGZGeXMYIPRXWy YnVpk4KRxYLI/+eC
XyeDzhdK+fYdjFYe0/do2mJ9AYd9PkhwQIhCcTd3RRgvR3h3STg6+bJTp9OE ffeE6xc7GWdjt1OF
reZxr5Z49ecxQCZFQgaGKCd5Y+h/XmSG2TVzZIAHyogHh2AHdgAI0AiBelAI dOQWd4iHeriHTdOH
cPZtuQeCu1eI5naIwGeC7FYb7mZ8jjgclKV89HZo9yZ2NXiJ5JGJ1Qdwa+eJ 4vKDAwJ33adpRKhw
puhpqehLq+hifJdbsAh4ssgwgwdc8Ndxh0d/W2h/UOWF+dcmkIdrKRc9xEg9 AxCSIjmSI3mGMjds
ZmQHzeiM0AgIdyCNhUCNdshP2KiHfNhXfv/ojYE4Kv8FdeP4e/0TfCeYYICm jvD2iBsFg/AYdjTI
Wftmjzp4faX1idrXj9wnhN7nWkZIkOI3WwcZcTj0isYUi1I4iw95YxGpY7mY hcZVkbzIeL7oeBq5
f7k2jJXnZHiZl3h5jChZAGHwl4AZmIEJKddoPtl4k7XXjYC1k4Pok703YK5S glXXZ1dHfEW5gkfJ
jl1HLJHYfPHYlGT3lDioiR2kdiDEgywFilYZhJYjdwlXU1xpL6D2lUwYlgo5 lgxZlg7pfhynlvOn
i255fxiJJswVhnXpkZUnMzKDhmXUFs5JmDRpmDa5jTipmHI2SLpHiF3zmFIX mYg4K5S5iJZQmXVG
uXWamXxep5RgNx34Bn36JpqOdo87yHb7qJrmcpWtSYoCyXAq1pWzaSKsaFsJ iX4LGYWCx5tpeYVT
Apwix4XFE5dfOJfG2ZHjpGTKGTP/zDkWGrqhHNqhHvqhILqhZBSiJFqiJnqi KJqiJDqiKtqiLvqi
MBqjMvoQLDqjNnqjOJqjOsoVNbqjPvqjQBqkQsoQPTqkRnqkSJqkKVqkStqk TvqkUEoVTBqlVFql
VnqlEjGlWLqlXNqlVKqlXhqmYjqmOwqmZHqmaJqmJmqmatqmbvqmXcGmcDqn dFqnISGndpqnerqn
EIGnfPqngAqofhqohFqocDqohpqoiiqmiEoQNvCokPqoizqplCqkjQqpBJCp mpqpkFqpnvqpMoqo
NrCppEqqNuCmvxYRTwZWBZGqF7GqQeqqISGrO0qrCWGrJ+qnj1qqvKqpkgoR L3erdsH6cngpgMHa
ZAaBq6y6ELBKEcp6q9BKXRrxrNLKENSqEMV6ENSalw1Bq9eqqsDarNOqrcIq Ed+KrMyarNY6FXg6
qr36rpwKrti6rF/1a6l6reeKrfk6r+YarcuKEeeKrxZhr84qr0yxr9YVFbgq rvzqEAibsGL/Iafu
Cq/weqoPUa/Hiq4QW6//CrHVSqyrOqzWlbHoyrElG1bZOrIYW10ga6y+trIv a7Ii66oii6zDerMw
ixQwq7IvG7Md67E7q7MoS7OtSq8sC7Qbe7RBS7Iqu7M8q65PS7BPG7Uom7BC y7KwKrNGu7I6a7Vb
u7E9+7UkO7NMCxISS7EUawMDcLEae6/HarIeG7c2W61027VSS69tG7d3O7d8 y7EEe7ddO7d/u7BI
C7iFK4B5a7hSS7M167Vaa6xwS7SB67iserR8q7eVm7n+ermSS7cjy7lyi7eH +69Cm7jSCren67mm
u7d3ql0LMbGaGgDwKrumurbdmreke7Ih/6uu1yWr3Dq5RAu2Nmu4TTu6flus 9oq8mfu72kqsmlu4
ytu20du0wIsQg+u8j6uxz6u8f0u9QDu991q5yEu4xeu1Ptu7dTu6UVuy4pu7 int5AXi6rOu91csU
Zgq7mXoSvaq/puqwuIu72au90hu6nau9eom0mNe9oKu1wSu33dvA7ru9z/u/ DVzB1jvB5ou6viu8
lCu4RSvAe6vAreqtCBy4gDu56ovCkFu1AyzCImy+8fu9BFy08/sR90uqKVGq Obypanu7CAzA/zvD
GHy4IZy6BpzCxrvAEezBl7vEMOzCPwzFoOvAEmzCRwy1RLy8EjzFpnvFNJy7 QYzCUEzCW/+sxF3M
vh0bvhvMxKFrw66bEPhLADucvyhRqmpru8Javz7Ls+ErwFbbu4zrt2n8sSAb ueeruTJruWGrwI3r
cljLwnv8tmIMyIssupDrshlswCnrtiwcvY3cuIG8tIF8yZo8tMlbvZsMwVw7 tdNbvs67x+KbvCMs
yH7sxlkBx/tbx3Ksy3aMx6C6FA/7ywabp2Aax7HbEu/aw8IMEmW7zBwRzF5a zLO7EhUbks58zdhs
FdI8zbzcq3eczeAczk2xze+qEmlrzRUBwa8KzcDcouq8EQw7Fir8EfNMz9b7 sOycq298EMZ8zOac
zOh8z2X7zgXrv+s6sK+MxaobswIbrgP//cEOTb5Kwa0ZUc8dIcbp3LDpC6xD Ss46jMzeHNDkqtFt
PBEB68MF/bPpqtD2TNIIW8Ml/cweYdEync8qvdAxfdBB6tGbusNzXLu+zNJU a7kzO8uJ+8iinMGP
vMjNTMWUe7VOC8KSXLWpvMaOHMmVjLpRvNTrK8qnXMmpa8JKW8uwXNRD/blh C7UZW9VpHclLDdWY
XL47vc/8/NH8S8d37asiqa8JjcrQC61S/MQyjMRcnKxjjdZ+bdiK7NeBzdBI jMqsu7hlXLqPnb7Z
irVHfdNB/Me8y77PWs9jjMWJLdiN/aM33NPdjNcmAdRBDdGO/cCtfMmBDdV6 zLyvrdny/+vEwAvJ
Z2y3sWzKDgy+f5zQzQvIfQ2+ws3JvB3FQ3zBujvJnTy885q1VSza9FvFwm2p dG0QcZzXqE27PCzS
I/2zD+zavc3cFgzC5I3bWlzZLB3aL2zeFqzCymrIGw3GTuzU+B3f/jrajDzA 4/1koQ3R9F3d9w2k
bNrds9vL4v3e1c3fA+7e6K3bZJ3JEa668F3G6q3EL5zesz3hTRzfxAvDMR3h /425443ipG3dJk7Y
Ng2iZ4u2AL3XJL2+favIjrzKyp3WvC3JYM3BWB2/cB3D1/3cgj21Kg3KSavB rh20V623i83UXKvH
Nl7hVQ3dVjzcgL27uou4Of7j9TvVWjudozEu47x6x63NoS9+sBddqWsuzjS6 3QjRz2iL5iDa1GCx
5ngeqG8O52Z4yw2xq2ZOAI86kn5+6IieEf+DOgB0ztoNnuiQHulgJOcKweiC bseFbuiv6hQ0nefD
nNGevumSTuaUDkaWHqmZrukmTdw4Dc2d/uUV3cjk+q0Yi7ivXuFNXK64rtOK 3ay3Hte93tCjrhSN
eigkeeyPbtDsLdRsS+vLruzC7sOUvOvUntNebu0rne3MHuA1vrnDbsu9NhHI nuafLsh2i7OH3OVK
Hdlfu+49G+VDXrzxntxPzdXnbtzD6+S+veTv/tXL7u9ize64zslHPebffhHF 3hRmfdhHvuIeLNkH
ztlfDLaXXdkt7tugjdgP7r60XMC0/MPc/vCWvNkEjrdMfvAbkfBPQdkSPsbc 673FfcpYLrz/jL3x
ZkzzJJ7dw03VK1zCS57ltM3eMo/xKVvy/b3Jz47yFKHynJ7JN3/hHezSk43z 5c3hBk71IK6+he3z
if3xOO3FbNzfDUvG2K704l7qXWHFLf70Ua/V873EH7/vK7727U3Yc0/hCYzI XOz2JS/3fI/GRk/x
YG/2FcH0swrK1yvLrozu7r7hX77jDGzWP3/kFU/FtS7vpGzj9k66Oo7Gb0ve l33Yn2/UtUzwJWzw
hB8Rhs8V0R6r1Y6iMD2rqf8Vq78VrV+rAn6jsc/Ms0/7aN/7wB/8mQfowl/8 xn+SscrzAAvPWq7m
fT7TG/r82+4Vwezr5h2itf+hsG3rZf/Z/90P8vdNwuz80OP6+sqe67G+3N5e sGSf4uFa/p+O4Sia
/R66/UKO0t3e2WQ94tN//gABQCAAAQMNHkSYUGBBhQ0dGmT4UKLEiBMhWsSI sKLGjBA3drwI8uPA
jSNBnkR5cEDBACldOhQQM6LMhQQXxrxZEGdOmxx12tS5kyZQgkOLMgyKVGjP gyZnkuQJVOhSpR+r
Vo36k+bOozyxHp05lWvNnkNlXiUptmTTqB7Fei1pVC7Os2mTZjUKtazerXPR duVq9i1YsmaZvkTc
cCWAlokdM107tibSySHZaiXqk3Llyk8nO22IeTNRz1LJHt7LGXLRwqdV/3y9 unTmp7Wh2u523TXz
Ydy0Xc/eLdty77WpgwOH7Xt3cuLLWT+GbnBx4+guPdetiL114ISbMdtlflt7 2K2hzX8/+x0s87oh
m8dOrT12bfm8S4enXz737fXD+3v3j7DsxNPrvwJbk+2+nPDbrr70hHvQpOpe mm5C6/iDT7mwUENQ
vfeCc84yjhQSLbfwAuzutBNDpKw5F9n6zTgGVVORRBALTK5D/3pb7aYecXRL P8hmdA7A4lCz7UgL
HatwyZNerBFADGHkT0ErqwRSwtFQTDJLIN2b8r0WwxRuvgPHNDNNDjs7k0wp o5zyxxDn5E1OImdE
c04GeXSS/0KW+hTJrxzla3GpETFUa8jADB1My/3sZPSr7CQTclBD41vQR0n5 unTAz0Y70bDfRM0r
U93e7LG9SnV7TtQ6OaWr00xx8+7SUxG1FdCUmtTVIgkT+7XXjoIVtlhjj0U2 WWWXrY5XZg+srtRn
SZRsWmuvxTZbbbeVyFluvwU3XHHHJbdcbr01N11112W3XXfJRfddEeWlt157 78V3oHjBJRbafP8F
OGCBp933234fHThhhRdm2KWClRXsrfZOjfg5iqttOGONN173YWShLLPI7cjk uGSTT97W42MjJFmq
VY10EGWZZ6a5WJWNPXLFHMvMs8aafwY6aD8ZyxZkozEVU99opZdmWqU/i5aV tetkldLVLZvGOmuU
b9a6a6+/ppdrsMcmu+xznzY7bbXXxlZstt+GO+6hqSv5YMTsthdvvIVV8iWM p917277FdVvXiakM
7XDzDn1M77+BTZFakTIi1iqKYFLcRMfs7jfwpoRE3N/+Lqc8cyTTLRxQ4DDa 2/MnJy9Wy8D1fv1C
mEJPifOJXNec9ciXDHbwcFPvc+pCgwrd+DQNk1RaVRcdadPCoPeKtIphBBUv uljcvqyxsCqV+fA1
StT7nm/91NSKYbs+YkfBFO16aCcezy/Gta8VTd4n/yTeSVWxNA5h5EQaAJom ZJ4S2eJaRqNJqQl7
cMpS9gZ0NQYeykNBulORHPWhO0nQSwi7lVIcCB4IEjBDC8ogfla3rP4BTzzl QZXlyHPBpHTPQDH6
VKwW978ZWgyBHawagUrIo0Vpxl8sm01cXnbDz9lQZ0ycIXtW9RDkDVFRpzNT fmK1M5Z1pj7aaqGF
+MQ+HF7Eg11Ckc9K6JEUXUdGaXlVAps4Ram1bFD2Gc7OTpfE5BVwP0ej0Y9y RqXKKUeO83oRnxBJ
SBDtr09hnFAiEfSoK6FRT3ZaYPQE+aUKjjBGfOTgqxBYJ8uxqYxWJNIHLxnK DIXqPGrSIxZF9qHe
zf8yTo6MDiSjZT8NYfBM+iGUraw2R+01kYSj2qJdElREEaFFUPaR2DFfCEe3 nNAqVMtKd9wHza/U
UZk+Ql8ABbihHFITPKGCIazuF072CbNtaJObuHAJt3mqLjr1xJcu49krfJpN Wtyq5z9lps99FtSg
aiPoQRW6UK0lNHb9NNya7inRiWqzdgzF6EkcCiyBUrRxpnsdRNs4L8rdzoLD ymhKO7LRu4nOo5uL
1kshF1CT4s53KsVpt+AJOBw1iir4+6ar2LQpCkqTecWkXuTyQr/BHHN9AmQV SHM6VQCw1G98sWOr
3LQjwYCTPi4dYBXNOLLbadKTRwMkVdWqr50+i6mVlXJQzCYFuk0GUoHODBLS fiVWVepRiymM2VoF
a1XbIWd+h+0kYjd5sLSScUg2AicqTzrIMYJVsBklbO6w2srF3jJOdT3OXQ+I qFM2c0efHS1aN3tZ
nGYWJZ4Samyj1r7AZhOsb7VU9453HkqpM7Lqw+b0eihT1u7TtUITaXGVy67j Bi25y4VuuZobXepW
t1fTtW52tQv/Hey2NKLPjWlJvYstXIJ3u9nqbqBsaFPexVKbjxuWUEe6u8hu r3NUJC53NEutf7r3
vYnrKEnPu6T0itey6/QdYw/sqwUTl1PmvC/pqLjCm+IXshLea4UH/Mi2Wqs4 JXoeXoXLGbkwMoRI
PeMza0jCLmmlUS4jT/pO7Nj1xfjANm6nYUEIzSjlasOPKXDp9JenJ0rSjWk0 4Fj3wsOtqrZERkzt
YvV3GbIO0MQEPDInf+fGLZn3vEGenH7l6KLxjI580MstjSHU5K3qKM1STicK U2U+NT9ox1G0nkAp
rCL6NfjHc5OnITM4QvUo0IokziKbYTmyK62RTnPGk10pOkoT/9Y0w5T08593 1eGiLbnNUR7qamtZ
5CrTsICDPnVWLcnBSF9SlnByZYDMCunSahoxYN6d1bRIzRATtS2D+yKhysk9 +8IKVbQRMVRJJb3H
CqhDYlbii7t5zRXO1Wc+trXDOJ2uCGusqHnLNEyznbJtm6vbC1sqwPYsxnGf jWjthne8E4Nredf7
svT+WLHH29K72Nvf/Ct3vpK0If8KWMn4Xfe/FQ4SfK+sSuTML30vl/CFV3wi DT8zjs0HF2VqEsTS
VjZVQI5gi5f84gF3uOaqVWcBg3hNVZRkjy9scpqf/N3XMt6bYSY6I3ETzvpm IslrPnTpoBxnn6YV
n1/O6L5+di1FIPQy0b9s9NghnbSk/J0pR5toRxtc6kTHODFnlVeYFTUyXoVr UkUYTqF/veaRYfc6
5MztdroLBO7hVu+4Alx3i9+d73+vmd8BP/iTCZ7wh9eY4RG/eIUpnvGPB5jj IT95e0me8pd3l+Ux
v3nUUZ3zn1ea5kE/enfTjfSnZ5roUb96Zqme9a8/luthP3tdyZ72t7eQ7Q2M e94nRPCU3n3vhW93
z/Mz7hYefvJ/P9bmxfiteE8+4pcvRND8cM7RP//99F8z1zvmMOrY73vxI+r0 VCoS/NkXvz1RW36S
ff/89jb8/3791BHv+P2M1/399V/0m+/f//BKv/8TQGTJvwE8vwLMGNfBGOF5 LfczQEBxvAALsZBL
N5uyQDaSO5SaOQeTsA40tAc0FskLns3iIw9sQHHTwKzjQOQzQRUEQWERQVP5 kuw5IrhQomEDk1TZ
IhyrsaDyqUg5n2HapotBtuaTwRcEsgA0PkjRrxI8OA5ZtQcKmbDimUXjuiTz CVULEw86NCRkEiUc
PyfMH2DzoYy7oBz8qmtboiWLqyXqImIKpTfEszmEPi9UDDBUPzHUEZIiuPt5 uvTQmRS6Oi5SrEJt
g0KrCyQFQTKKs0OLiEFM2sM4apNSqrRR+kNQ66U4TDVKRLVO1MJJakSNwkP/ caK8AgwkcxlzyiYn
pDN2GjtE2zge4xls6zWfi6rc4rXZCsVN6z/ec8BdRAkEtK69A8ZnEcZiZL1j REbUU8ZlJGO9ZnRG
0IPGaOS8aaRGzLPGa6S8bNRGyOPGbsS/UQTHZfzGcTy8cjTHwUPHdPy7dWTH unPHd3S7eJRHqaPH
ehy6e8RHmtPHfSy5fvTHigPIgFS4gSRIfzPIg6y3hFTIeGPIhmxjt4eEyGyT yInUtIq0yB/DyIwc
sI3kyO3yyI/MrpAUyeoiyZKMrpNEyeVSyZUsrpZ0yXsTx5gUPpikSbWyyZuc qpzUydaayZ6kPZ4E
Ssz6yaF8PaE0yoVCyqQ8qKVkyoJyyqeMY6eolMq4ocqqfJurxMq10cqtTJuu 9MqyAcuwHJuxJMuv
Mcuz7Jq0VMusYcu2bJq3hMulkcu5FJq6tEugwcu8DLyi5Mtz9Mu/VMfAFMx2 JMzChMfDRMx5VMzF
tMfGdMx8hMzI5OrHyaTMf7TMyxTIzNTMguTMzkTIzwTNhRTN0XTI0jTNiETN 1KTI1WTNi3TN19TI
2JTNjqTN2gTJ28TNkdRNygyA3wTO4BTO4STO4jTO40RO44w2QGTO5nTO54TO 6HTOh9hLEDQ95iqJ
5NTO7eTO7gRO+Kqq3ozM6+yY7HyXlQiW6nxA8lSXxYAI9pQu8FRPA4RPc3FP kqAOl9NPLOPP/fRP
okBP6hRPx6zP+GyKxvhF7pLPAV3MAgXAA9UWBQtQh5jPAXTQBlREBYXQFcSc x9mgjJjQO+zF3ayO
C4UdTGkW89SwNkGYEaSvEFX/iAoVQBMNPkNMwg0NnmtCHCM8MVaJ0QUdURKF DhpdUb7KJRXFHPLJ
ulTCkkKCUd9jUMQkUgYzI/C6z4VA0A2EuioFnTIDT+JLzygtzCmVOD/S0Pek CB1lHEKENVVkiydF
CBn9PzIt02P7QhydMCWVNS0EPqcJ0yAVUseg01zL0BtF0xVFJmtDu2KTwPD8 00ENVImA1HfC0/J8
1EidkEm9lislCE01wy/VLDh1GkDFVJfwVIJR0QRNwkst1SENGyT9z1jtz1mV 1YIQVf471VYdiFxt
PSTFTlbV1cTgVRbKzgEw1mNF1mRV1mVl1mZ11mdVViAd1lYNAGi11mvF1mxF X9bllM5u9dZvlU4B
JdVgjS9wNddzRdc5Qtd1ZdfppFAxJVeVktN4JRx4pVeMmtd7/ZZ81VdyG9d+ XTh+BVhKLVBtNdiD
RdiEVdiFZdiGddiHhdiIldiJpdiKtdiLPdiC/w049GzXjvXYjwXZkBXZkSXZ kjXZk0XZlFXZlV3X
f/WYlfDOmJXZmaXZmrXZm8XZnNXZneXZnvXZnwXaoBXa7nTZjRWAoUXapFXa pWXapnXap4XaqJXa
5Czaoi3Oo51a4sTam93arPXarwXbsBXbsfXaqtXY3zwLtPXOrh3OtF1b4WTb 40yPtg2AuCXbu8Xb
vNXbvcVbsxVQtVVbu6XZrRVc7ixculVOvlXcxWXcxnXcnvXbdwXcuqVcwkVb mYDbusXc4LTco8Xa
ze3cy40J0Q1cwI1bzPVczR1d0lVdrV3d1FXdw33c2aXd2rXdmI3cO5zc1A3d yS1d3+3cz/1Oyv8t
3d6tXMuNXeCt3OHtWuQd3sAVXt+93eml3uqt3tz9UdEVXuP13NGFXeLV3t19 Xtj93u5FXa3NXOYF
3+79Trd93uUVX+uV3/mlX8XFXiiV3vJd38x1XvCNX+Il3/1lW7sdYM6F3/X9 XsQ94P6t3wZ24Ad+
2vuN0+hV39/13wU24AzeX/HlXv+lYOXV3woGYA5+X9mF4BNG4RSmWQl2mvwN 3+Q14P4t4PZt3vEF
3dfN4LltXd69YcJdXQT+YPdV4SEm4iLWThYuupk1YcVd4sE14ieG4ihGYrZa 2x++3SauYiyO4i3m
4tudYuLr4jAW4zEmY+H84vAs4zRW4zVO4TOuhln0ZeM4luM55ls3/lzQfVvl ZGAl7mEYjt3m3Vw4
llshTlw6NuRD9lk7JmGd/WEtLuQR3mDpjeT0lVtEtuRLZlpFFuANJmTzLeDo 7eNGbuT4peAapmQA
ft1UnmEa9mHv9eNAxuRYlmVNDt0OjuH3hd9PNl1OfmFI9mAFvuAExmW37WD9 3WNZRmY6pmU8LmZX
luHfTVtQ/mNKBmVYvuBfTl5AtuJVNmYBJuRkBuc4/6Zl/hVhXVbe5e3d7X1k aQ5mYO7m/21nC+Zd
EQ7nep7jcb5leSbnc9bcTR5h5C3lXebnEl7kSebmTbZle1boMsZnG1Zlc8bm fs5mgQ7kO1bliD5d
WCZmi9ZmVzbd8wVoK17oke5iTY5ZR+ZilCbplX5ik95Oa2ZjmGbpmSZjl6bp m8ZpMbbpnObpnibi
nZbkx1XpU5bZofbpo75ejbVaGHbkw0VdmfZZYc5jXL5mog5qpMZq621oqbbZ gB5ao6ZqYBZkDc7q
stZqpT5bhHboT4bpIN5dHObothXleXbfPoZbZj7ejL7o1uVrs/Zrx91qDGbg EB7fHOZgryboGn5n
eMlG6A8m6Hy26r+W7L5F679lan/Oaww2bKpO6AGO5lsOXlY+aMLW4Lju6MlG bb1taH0e7En25XjW
bNgG4Uj2aEGe56Au5sdO7d0W29UWbM52bcQOaOdl5wNG52HmZbU+59xmbN52 bqn17bj2Y32m4elu
ZeDFY9bd4by26Or+aLjm3FLu4Tvu5ec2b6gFau0E665W4vN27zRObz1ebz42 6vl+7/s+a3FNa/zm
7/6W2fj27wAXcOAE8AE3cP4ObMM9aZHW7vC27wOH8Pn/TfCfbW0XvuoIx/Cf rmzJ5WTw3m6+rmux
rvCqzvASb+MN111oZl63tuVV1u3mNvEYh2CTJt/Pvtxydm3cBu4Ll/Eel18a f+1gvu3YDmvGPmYf
R/Kk1m/L/l+pHvIQdmxfLu4HT/IqD1uX1ua3rmav5mjxJm4Gt/Iwp90CF/My t2cyN/M0R2Y0V/M2
t2Q2d/M4v2cUz171juyiVnA513OyXWaZdvGaxWICjuosduxWBvOppvI9f3M6 x18S33GuzfM7Z9pj
PvL2VvSy9m0Qz2681nRD125P7/QG9+66BumKZvBazuyDDnWm9ujxvnSS7vPa 7ubQxmjMnvJ9Jmrm
Pm7qqWZl6NXydC5tWxf2V1fo6LZxdD52UxbsTl5rD7bmuc3t4H129SVu23Zw WRf2Sid2TI5uajZu
g8bxwtX1ES/oJ3d0VIfxZw72cd/2M2f0Cbbw307obC9seiflclduzR5u2qZb t2btcC/yduf2d2/h
a87uXMbhUZ/r7v71F35oLSdlkHboZjdu70121nX1G2d4bRf4Q4bzE070ng35 jl/0JefwKIbqrx15
kvf/eIJPYpaHeSl2eSqO+ZovYjb/c0sPeEQeajDP+cFdeb4NerGGYC2m8lgX dLJ2YqVfcKcOZVPX
aKKX+rvOWZUWd0mf6uRcYrD+Zh7X3q0f66rvzpSH9KmX6LFHe+Q8XeLM9FzH 2Z/PemuXcqYPez4W
+5N+ZK+PdK2386V3dLWPe6BF6aG/Wj3G+71H/N/M9Izf+FS/blTGdlJPeMhX dcQ2eNJ9drhua4GG
/Fd++B1+fLsmZowX8uH+/FDu/FUP8WAHcdB3++/+99bf+La2677O4cln+FCn 69qv95A2bX1v9Qbv
bmtGenqndWlG99+mboAe5oqG57VX9sQObs5P4NYG/3blN/4VT9zOtvV9x/fS 3/fivmwXnnXtH3Z8
d2pch2hnj33E9f7DLuhcRt/oR1tjP9/ivfh//mx232PLBwgBAQYKDFBQAMKC Aw0uXCgQocOGBBM+
ZEhQ4sGLFyFqtEjRIsOMIT8qpFhxo0GSEidCLAnSpcmXDlWybBlxpcyYJ0V2 jFgyYUifKYH+JHqz
40OSClceBBq0ZsqjOYWy1Mgz6dGTU2dyxRi1J0EAAQCQLWsWwAABYs+yTQt2 6VS4Lj2CRGn3KV64
dHvOFSmXKVe9f+fWtIlUK+KtGf++Fcq4IUyqW7NKlQm5MuXBVi97vZoXL1Kv fCVD1vv5KWHDoSMz
1f+ZNXHqulq/Hq4bdixbs2nX5i7r1jbroMH9xpUM+2Zfqcktg5Vtu/ho45eH K76b2PpnwdJjU1+d
Gbno7HuXmuYO/TT6yeRxXme+fj328tOVqyfN0znp2719q8W9/7dgHLHm1HJN +UWgUVYRWBVhQxmI
33NJ/YSRgMzhp5RnDlbnUYUzefbgcxpqSB6CE5I44VChAedUiqjx9dGLhtG0 oIcqeggii1VBFaOE
NcLEIkf0jRgkTTsmKKJPRMLF23/97UfWbzhJOSWVVVpZpWlXarkll116+SWY YXKZpZhlmnkmmmmi
SaaabWrJZG+7+Rcnm26mmaOdeeq5J58U1tknoIGMChrmn4OqCWducj6JVqGG OvoopJFKOimllVrq
KKJtOflklJd6+imooYo6KqmlWpnpWYpy2qiprbr6Kqyxyhoqqrpt2uSsueq6 K6+9+gpmrfwFCyWr
vxp7LLLJKtvnsIw22+my0Uo7LbXVVvnsrXRauy233Xq7K7bYfjsuueWaG2m4 cyZa7LntuvsuvA21
pbsotPHaey++5s67ar79+vsvtfviCjDBBRs8q8DaHrwwww1fmvC6Dks8McXM qqupuBVrvDHHX0Ks
acchizyyvBenmm3EJKu88sQfn8wyzDEX7LKtMtt8s70084czzz2TqzOxPgs9 dMAm25ox0Ukr7SvQ
jC79NNSyNl1v1FVb/bDRwmYd9NVdez3p1Ox+PTbZYoZdNtppu3m22m27DezW zsZN9dt12y0R23fr
vfdYc6MMMt+B1/+dt+CFo0244Yl7jbjijUfNuOORJw255JX3TLnlmcuMuead q8y556F3DLropVNM
uumpM4y66q0TzLrrsecLu+y1w0u77bnr6zfSuvuOb9iLmqWW8MUbfzzyyDvZ 91rMO9889M9LHz31
01tfPfbXa58999t73z3434sfPvnjm18++uernz773xv/98npWikntW61f//6 +eO/v/798/+//wII
wAEKsIDgE8v84Hc03sVNbsl7IAQjuCoCUtCAFqwgBi+owQxycIMeHCC9FKi1 EDbLgRI8IQqTZ78P
srCDLmwhDF8owxjSEIQNVFWTPka8Eaawhz6k0wyDWMMhCrGIRDxBohFBSJYd LpCEDDwLQuLXwB9S
UYUCSSISs4jFLWqxi1ykIJyiKEUnkrEsCRljFdOYQkV5sY1fdCMc3yhHL5pR jDz/zOETl3jGJqqx
jxFc4RwDGcdBCrKQhNRfGPdIrODNSZGLnKIfI9nEQxqykpS8pCUzWUcmmhCP ZawjGiUpyhBispSZ
NCUqTynDRGIsj56EYihHKctWqjKVtqwlLm+JyCWui5HCw+Esgxm0XBJTl8U8 pjGZV0Jg9tKVrxSm
MNmIzGkmk5rWjOMngehMbUITmoCsJjivKc5wxnCZInwkCQegznWyk51qaSc8 4ynPedKznva8ZzuX
N859kpOf/tQfPs/ZSTqZpKAGPShCE6rQhTK0oQjtJ0T/KdGIns+hAmVmW7qp 0Y1ytKMe/ShIQyrS
UW6TLb87qb+yOdKVsrSlLn0paUxjKlMIYnSmNr0pTnOq053ylJY9/SlQgyrU oRJ1jQItKlKTqtSl
MtWjNW0qVKMq1alSFXlPrSpWs6rVrQb1qlz9KljDKtaOenWsZj0rWtMqwbKq ta1ufWta2QrXudK1
rlKVq13zqte98nMUr3z9K2ADK1K/Crawhj2sJAmL2MUytrEPVKxjIyvZyQ6U spa9rGUhi9nNcpau
mu0saENr1t3gs7SmPS1qU6va1bK2ta59LWxjK9vZ0ra2tr0tbnFr0d3ytre+ /S1wgyvc4RK3uMY9
LnKTq9zlMre5yQ0IADs=
------=_NextPart_001_0020_01C611E4.38D70870--
Content-Type: application/pdf;
name="birt20RC.pdf"
Content-Disposition: attachment;
filename="birt20RC.pdf"
JVBERi0xLjQKJeLjz9MKMiAwIG9iaiA8PC9GaWx0ZXIvRmxhdGVEZWNvZGUv VHlwZS9YT2JqZWN0
L0xlbmd0aCAxNzA4L0JpdHNQZXJDb21wb25lbnQgOC9IZWlnaHQgOTMyL0Nv bG9yU3BhY2UvRGV2
aWNlR3JheS9TdWJ0eXBlL0ltYWdlL1dpZHRoIDE4NjY+PnN0cmVhbQp4nO3B AQ0AAADCoP6pbw43
oAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAvg0MZGspCmVuZHN0 cmVhbQplbmRvYmoK
MyAwIG9iaiA8PC9GaWx0ZXIvRmxhdGVEZWNvZGUvVHlwZS9YT2JqZWN0L0xl bmd0aCA3MzQzNi9T
TWFzayAyIDAgUi9CaXRzUGVyQ29tcG9uZW50IDgvSGVpZ2h0IDkzMi9Db2xv clNwYWNlL0Rldmlj
ZVJHQi9TdWJ0eXBlL0ltYWdlL1dpZHRoIDE4NjY+PnN0cmVhbQp4nOy9D7QV x33neVfw/ITwCyLB
LCEcwrDLsAxhWcIGY0WWMYdEYYisvGDlyKyMCVbIshxF0eFocGQFmYN15CMT DatRGDksq7AMURQT
RuYSjLAZxCCMMRNCFJZDCLZCNAxmWCLyghF+Qk9bw43b113d1V3Vf39dn8+p o4P6Vld9+3frd6vq
+/r2HRoCAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAADw
i1Y8zz33XC5dbNq0ydCLrbz0/e7atSub8HqRJRS1hfc3I7mPisHBwf7+/shU ffrpp3PRDHIh6WqL
YZLNkaqvMhpZw7I+US1aSX2uFAAAAACg8Rj2cfPnz8+lC9WO827RbXdw8uTJ efPmNWwr0ciNEu9v
RvIdFdevX1+0aFFknub1tx4QCklXcwyTbI5UfZVhJA7L+kS1aCX1uVIAAAAA gMZj2McNGzbsypUr
GdtXLah2nHeLtvXPnz+/YsWKRm4lGrlR4v3NSI6j4tq1awsWLIhM0k2bNuWo GWRB0okgfo7Nk6qv
8ofIHZb1iWrRSupzpQAAAAAAjce8ldu2bVvG9rdv355lt2hVf926dSNHjmzq VqKRGyXe34zkNSoG
BgY6t8DpZP8QALmQdFKITN7cqfoq/wnRw7I+US1aSX2uFAAAAACg8Zi3cvfd d1/G9lULWXaLVvWb
vZVo5NXx/mYkl5hcuXLljjvuiEzPHTt25K4ZBEHSSSEyf3On6qv8J2orLA31 EV+0kvpcKQAAAABA
4zFv5Xp6egYHB50bV+eqFrLsFq3qN3sr0cir4/3NSPaYXLp0ae7cuXo7KnN3 795dhGYQBEknBa/e
KdEXWx/xRSupz5UCAAAAADQeffk9ffr07v/duXOnc+Mvv/xyd1MzZswodLXf 7K1Es68uDURAJ2NM
Ll68OHPmTL2RESNG7NmzpyDNIAiSTgpevVNeXWxxFB1G3iYAAAAAgNLQl99r 167t/t/ly5c7N75s
2bLuph5//PFCV/vN3ko0++rSQAR0ssTkwoUL06ZN01sYOXLk/v37i9MMgiDp pODVO+XVxRZH0WHk
bQIAAAAAKA19+X306NHu/x0zZoxbyzdu3FDndjd15MiRQlf7zd5KNPvq0kAE dJxjcv78+cmTJ+un
9/X1HTp0qFDNIAiSTgpevVNeXWxxFB1G3iYAAAAAgNKIXH6PGzeu+4jbjXwH DhzobkS1GdddodfS
GJp9dWkgAjpuMTl37tzEiRP1c0ePHn3kyJGiNYMgSDopePVOeXWxxVF0GHmb AAAAAABKI3L5vWLF
iu4jDz/8sEPLjzzySHcjqs247gq9lsbQ7KtLAxHQcYjJmTNnxo8fr584duzY 48ePl6AZBEHSScGr
d8qriy2OosPI2wQAAAAAUBqRy++9e/d2H5k8ebJDy5MmTepuRLUZ112h1+LA jRs3Dhw4sG7duvvv
v3/WrFmjRo3q7e3t6elR/x05cuTUqVP7+/ufeOKJXL7APjAw8NRTT91xxx0j RoxQXYwdO3bx4sVb
tmy5fv16qKb56q5cufLcc8+pc1ULHbV9fX3z589/9NFH8/qi/bFjx1RM1LWP Hz9eqR02bJjqSAVn
wYIFK1eu3Llz5+DgYC4dxZHj4CntWtK/v27YxuT06dOhO/M7KGEnT57MRZLi 2rVrL7744rJly+bM
maPGYc9NVO7Mnj37gQce2L59uwpLXn0FKP2PP/743Xff3emx84YuWrRo/fr1 b7zxhuFEle8vv/zy
0qVLZ8yYEQwGNTDUO7Vx48YLFy7kIm/Hjh1LlixRn4qdkaCioT5bVIhU10pA Ll0UMaolJl036oNx
8+bNKvLTpk3rRF79t/PmqsRU6ZB7j1VR6NyanXzfiJpfbNGoz0/1Kao+sro/ YNU/1AesOqheUp/A
adopOoxC36biPjQ6c83y5cvVh7+aAjotq0lB9fXSSy/lNREAAAAAgJ9ELr/V IlOtPLsPnjhxwqrZ
48ePd5+uVrCdhavtaj+xvl7BQKLsN998c/Xq1WPHjk3ZoFqWb9iwIc2aPFLJ 0aNHI++ibN18kMUz
zzyTMhRqxxF6v0JMnz5d7R0SRcaxdevWGTNmJEZj1KhRa9asuXTpUvqWDRcV V8FAhdcSqcTq/XXD
KggqiyPHthKZl811/vz5hx9+uLe31xxetatduXKlSrf0LRuu9OzZs/fcc4+h u2HDhq1atSrSUlbj
YcKECWap6jMh0Y42yDt48ODUqVMNXaj4P/vss+lDEXkVOY7qxHYiL7M0eWap wUtXrlxRram3z9zp
woULE/+uYRWQRNJfnRWldWTbe15vhG2Qd+7cGTo4ZcoUq4vq/mRQ+q3++qB/ qig9ibFK5I033lCf
nInBVCsuFfPLly+bW3NTsnjx4shO1TrEuf0sMcmxrxw/NHTUh3zceqCDGjPb t2/PMSYAAAAA4BVx
C8j777+/++ATTzxh1ayq3326as3cna08QwUD5r6efPLJRFcqkhkzZpw9e9bq QoZu3sk2atQoQ7Pz
5s1LDMWlS5fuuuuulDrVluTixYtmnSFOnz49e/bslO13GD169Isvvpiy/ciL MlcwUOG16Eps3183
0gfh6NGjoV857KB2lOZbW9OzadMm818ZQqjKmzdvznilO3bsSNnprFmzuse/ 2sibPeFupk+fbs6d
OHnqAlN2MXfu3PPnz9vGvIhRbdVa+fLMUjvHVfaZTftuhg0bZv5Ti5X+RFJe mi2ldWTVe45vhG2Q
r1+/rtt0p06dSnlFJ06cCJ27a9eulOeG/rrdumkOB9/XiFSbhnXr1iUaj92M Hz/e/KMJtkoGBwf7
+/sj+9q4cWOW9p1jkmNf+X5odHPhwoU777wzZctLly7t/B0he0wAAAAAwCvi FpBqf919cNasWVbN
qvrdpwc3JNiuVxPrp1wwm/tSa+n0Pk8k48aNM3+DO1T/0qVLifuILVu2mK/0 8uXLM2fOtNI5adKk
c+fOmWMeoDazVmZdNymf1ayfmFjBQIXXEjrF4f11I2UQDh8+PHr0aL3yxIkT HRxFHZVBS5YscQvv
8uXLna9UxdCqr7vuuqvTmnqDQp9RiahcMzxPIxd548ePP3PmTPqwFzSqrdop X15i2Pfv3+/Q7/r1
63MJSCJprsuB0jpK33u+b4RDkPVp/emnn055RevWrQud++CDDzqfq5SYY2Xm ypUr8+fPt4pAh56e
nh07dsQ1a6VEfcgvWrQospdNmzZlbN8hJvn2lfuHRsAbb7xhvmVXZ+HChTdu 3Eh/RQAAAAAAQ/FL
4qtXrw4bNqz7ePob/FTN7hNVO8H3mm3Xq4n1rdbMcb0sXbrUqp1I+vv7019I 3HcbA9SmLPRlcL3O
ggULHHROmjQp8QubQzdviXRovJtly5Yl9qKflVjBQIXXEqrv8P66kSYIBw8e 7Ovr02tOnTo1r4fK
3nvvvc6xVSxZssThSg8cOODQ16ZNm65fv57+TqpuDF9h0CsfO3bM6ka7DhMn Tkx5g31xo9qqkfLl
maWeOXPGfM+8gSNHjmQPSCJp3lwHSusoZe+5vxEOQX7++edDx9N/Y2LOnDmh c8eNG+d8bveXFOLU
xnHt2rU77rjD6vK7UZ9C6Qe2QcPChQsj29+6dWvcWenbt41Jvn0V8aHRQa21 Jk+e7NBs6KeNO9jG
BAAAAAC8wrCAvPvuu7uPp/8amqrZfaLaFKTpzlZeXAUDkV3s2rUrsvL8+fO3 bdt2+vTp4Gl7V65c
UZUfeuihuHs8DI9iM6hS+839+/ffuIn6h/rfVpTflXh16sQdO3ZcvXp16OaX UlVTaoMQsug7LF68
2Bx2tWGJNKZmzpy5YcOGo0ePdm5iVILfeOONF198Me6WnnXr1pk70k+xvWrD uWVei0FVyvfXjcQg
7N27d8SIEXq1GTNm2D6mI45HH3008sLnzp37wgsvBA/XVf9Q/6sOOoQ38kq7 b4iaOnXqxo0bVQJ2
HoJ96dIllbzTp0/Xz1J77VWrVuk6z5492zn33Llzzz77bOSt16NGjYq7fVev PG3atO7/nTVr1tat
Wzt/WOmk5/LlyyND0f2BGUehozqyZhzlyzNL7X7Ab29v74MPPrhz50710d2p f/78ecMgvPPOO1P2
4kxw93ju6H0V1FHK3nN/I6zi3DnlwoULoeNqQgw0GNBP7KCGrsO5qtPup0nH qY0j7oNCZY2a8Tst
q1RSn34qXyK/ozFp0qTI31lLqUQtKuLuHO5+Tqxz+w4xybevIj40OkT+nVeN h5UrV6opoPMxqP6r
ukvzF1LbmAAAAACAVxgWkJs2beo+nv6ml45/FdD9rT3b9apVfbfFcMiEaSV9 mXHo5mo/8t6/xx9/
PL22DqtXr9Yrr127dvfu3SlbaN38CZW4J1UeP3480qcyPEJwYGBg4sSJofrj xo0LfhQmErW11L/q
rnYxSoDhLF1YXpVLvpa4tyb9++uGOSZ79uyJfJT0nDlzrH67ysDhw4f19keO HGm4oWvLli264eww
VALWrVsX+cuGhq8Sd1Ay4nSqrX3oc6xD3CeDoZdW1O8NdThy5Ejkl3bND56t bYbWQV7A4sWLDU8d
0e/q7ODwY0mRqHdcbzz9jdkOOLxThfZe6BuR/mL159KbDckOcY/LTvMDBPq5 IUvf6p3at2+fXl9l
06FDhyLrX7hwIfJG35R/x9HrqHSOXO2o3DRntNWVWsUk974C8h2rkXcOTJ48 +fXXX4+sv3//fvNP
+trGBAAAAAC8wrCAVKvc7uNqMZ/mG/2qTuh+0eDmPXN3tvIyVu4Q+eXuNL9f r7Y8+hfuFi1alF5b
6+btwYkdmVto3bzV5ODBg4YT1fuoO0jTp0+Pq6/fijljxow0T2eN/MmV2bNn W11UXpVLvpbIt8bq
/XXDEJOXX3457v7JNImcEv3JzyNHjjx8+LD5LDVidYN37ty5hlMiI9wyfi94 6OZNvJFPpWilSBwV
pXHjxoXOintKcJw8xQsvvGDo5dy5c3ovU6dONZxS2wytg7wOa9euTewu9OfL Dol3C6dh9+7dessq
L06cOJG98Tgc3qlCey/0jUh/sU8//XSoZvAbrwbifjvMPBrjzg097Nfqneq+ rbSDms2711Q6anEy
ZcqU0FmjR48OvoWUXon6DIz0itXMkuYPlOmv1ComuffVIfexqn95RC0azX/f OX36tMHgTZQHAAAA
AD5jXkCGfu7cbFN0CP2QUOjn2GzXq1b1HRbD+sPNzL5KN88++2zoXLWBSq+t le5rnuYWUr4pqiP9
EQ379u3Ta54/fz5kCSb+YFw3av+oP3Jw79696S/K0LhV5ZKvJfKtsXp/3YiL yUsvvRQpSTFmzJj0
v6xnRkVDbz/NrXGKrVu36uceOHAg/ZUqHnjggcSOHnroochz4+6n7eaJJ54I nRX3zfq4aD/22GOJ
vRw6dEg/MW6k1TlD6yBPcd9996XsTr9b2Pz49DScOnUq8g8K5u+DZMf2nSq6 90LfiPQXq96OUE31
7kTe6h+gBmH3GA59/cH8d4rQuR3Onj3rJn7//v2hmmoeP3bsmEFAh4MHD+q9 6N8IMCu5fPmynoyt
m1952LNnT6IGqytNX7OIvloFjFX9vVMD4/Tp04ntG54nn1IhAAAAAPiJeQEZ MjfuvffexAZDTw8L
3dVgu161qu+wGJ40aVLolI0bNyae1eHkyZOhc0eOHJle2+TJk1N2FNdCy+bu 0JUrV4bOjdzO6HaW
4RkOkZw4cSLUQvfPhSdelKFlq8olX4uuzfb9dSMyJtu2bdOPdzN37lyzv5ES /VGBaZ4ZGxB6srch
vJFXOmzYsDQ/9bhz50793DFjxuh3sunoN2GOGjUqpTzFlClT0vQyFPVozTi3 oc4ZWgd5alSEzDQD
oUfEt2z+uhdJ3I8o5XJLsBm903yx7b3QN8JKnmoqVHn//v2G+qEv1Id+dPX5 559Pf27r5nclnMUv
WbIkVPOhhx4y9N6N/kgK/aZlg5KLFy/q38to3VzkmKPndqXpaxbRVxFj9YEH HghVS/OXvg4PPvig
LtIhJgAAAADgFeYFZMjA7OnpMZsV+o0roSeM2a5Xreo7LIavX7++Z8+erVu3 rlixYtGiRaNGjUp/
W+ONGzdC3fX29qbXlua2Q3MLCvNXy7s5c+ZM6NzIdzP0jc7QrdcpCf0Ci9o6 DQwMpLwoQ7O272+Z
15L9/XVD7zfuiZEhIh8IbEXkXWrmHxAPoT+zVzWY/mfLUj4J/OLFi/q5KU2S S5cuhU6My/HIIG/Z
siVNL0NRdxjGfdjWOUPrIM/qcSjp3Xs35R0Sf8UyF/R+88W290LfCCt5a9as CVV+5JFHDPW7v9Gj
0vDKlSvd33wx/K1hKOrbQPr3/VOKVwsM/anp6U3IF154IXTu+PHjUypRn5n6 7xG0bt72HPe830hS
XqlVzSL6yn2sqvcu9OghNYTSf4VBvcu6SIeYAAAAAIBXJC4gQ7t18+9o7Nix o7uyfvui7XrVqn75
i+FQd1bubnrnJ64F27tDQ8/ZUIQenadbTOnvZO7mueeeC7WT/reoDM1aVS75 WnRttu+vG3q/6Xn5
5ZezdK1vctVnhW0j+m11cap0/Snvh9T/CtNK/TX5yHNTylO7+5Q37nbQ01N/ IkHNM7QO8jZs2JC+
o4GBgdDphs/wRCKfATJjxoyrV686t5kevet8se290DfCSt6RI0dClc03Bnc/ pn7BggXqSPezZ81/
49Yfca8/SCGleP0b+nfeeadBdogLFy6MGjVq0aJFK1as2Lp16549e/Q/nEUq OX/+vP6x3Lr54KnE
B6q7XalVzSL6yn2s6u+d1bdaFHPnzs0eEwAAAADwisQF5COPPNL96tKlSw2t hb6M9vDDD9t2l6V+
+Yvh9D3qNdP8KIm5hZUrV1q1oN/CFPoFcP1uH7cnx+q76bg7RYt7f0u+Fl2b 7fvrht6vTn9///Hj
x/XbwNRuPcsDeNeuXRtq0HZAKlatWhVq5NFHH015pYm/2G4499SpU87npqyW 5sebutHTU7eva56h
dZBnlXdW378wo1+7YuzYsXk94zoRvfd8se290DfCVp7+w4VxT0BVH5Xd1To/ iPbYY491H4z75Dl2
7Fiol4kTJzqL37BhQ6ha3GejM7qSN998U39cVevmo2zSPO83sf3sNYvoK/ex +uSTT4bqhH5ZLxH9
ETcOMQEAAAAAr0hcQIZuQjD8Iok6Hvo1Gf35bLbrVav65SyG1WUePnxYrb31 H7M29KjXtN316y28
9NJLVi2E7qxuac/2DD1gUOH2dNbr16+H2on7iZzi3t+Sr0XXVo6ro/cbIvAY I5/YkOUBvGrwhFrT
f7UnEXVKmvBGXumJEydS9qKfm/6uWv3clNU2bdqUsosOenrq/nDNM7QO8t58 802rvkKnDxs2zEHw
oUOH9KeUqKYMvxKYO3oo8sW290LfCFt5+oNMn3nmmcia69at66528uRJdXDf vn3dB1Vrkefqjpz+
B+704lX6h6ql/3tWSnQlEyZM0A+qsZ3+w9bcfvaaRfSV+1jV3zvbv/ZGPi7e qgUAAAAA8I3EBaTa
no8ePbq7gtrpRDYV+o3gyOfm2a5XreoXtBgeGBjoPJtX7enmzZun3wOZpke9 ptW3tiNbsP2a5NGj
R0MthH7wZdGiRYZLy0Lcd/b1mlYRMFQu+Vr0arbvrxtmqSEXQv+NnlaM/5AG /Vd70j8FOkB/9O70
6dNTXum1a9dS9qKfm15hynP1arbbef3GvzvuuCNUp+YZWgd5tn6y1QVG8uab b44dO1ZvZ/PmzbZN
ZSH7heTbe6FvhO3F6j92FvfU7jlz5gR1gjtv1bV0u/fjxo1LPLdD5A+QpRSv /+ik253wBnQlcaj1
Ty7tZ69ZRF+5j1V9crT9a+/p06ezxwQAAAAAvCLNAnLZsmXdFeLsoNCXrNVZ bt05189lMTw4OLh3
796nnnrq/vvvnzVrltnLTd9jdm16C+ndrQ6qfqiFkAOvPzMwL/r6+rKHxapy yddipS1HDDr15yQM
DAyEHqPdwe0BvGrwhNpxeL6oPiZHjhyZ8krT91LCuXq18+fPp+9lKEV6DtU+ Q2sur4gW1JhX04Te
iJoNbZVkJHsoqu3dqgXb7vRfKBs2bJj+eXXhwoXuOsuXLw9euueee7pf0o3W 0Lmtm/kbaRumFK9/
wNrO+InoSuIYPXp0+h8FM7SfvaaIvvT3zvavvfr3Fxx0AgAAAIBXpFlAhr4j NmHChMimQlv7yG8R
2q5XrepnXAyfOnVqxYoVtnZuyh4zasulhcTnxYV+5TlH4h6iaHVRVpVLvhYr bTkSJzLuR+Fff/11
PTJuD+DVM8Xta/hpwqtXs4pwCefq1RyiEWpBvVOhCjXP0JrLK6KFxYsX6y3c ddddWQQkUsSFZKTk
N8KhO/3L8vqjjUKPr+lew2zatKn7pbVr15rPbcX/SEFK8foHbOI12qIrMXDv vfdmbz97TRF95fLe
ZdcJAAAAAF6RZgE5ODgYeqigfuNK6Fv/cb8rbbtetarvvBi+du3aI488MmzY ML0FW3LXlmMLeiPq
bep+NZcIRBL3EEWri7KqXPK1WGnLkUiFjz/+uOGUyAfwzpkzx/bmIj3CuVxC LkOl/HNzGQChFkLp
OVT7DK25vNxbWL9+vX76pEmTLl26lEVAIrlfSHZKfiMcutu+fXvolCVLloTq 9Pf3B6+qIdd9r2zo
m/KzZs0KnXvvvfeG2o97TG5K8Xl9wBrQlZjZtm1bxvaz1xTRV/Yu8moEAAAA APwh5QIytHPRb1xR
R7or3HPPPVm6c6vvthhWO/HZs2fr5xqYMmXK6tWrT5w4kb5HN235tqA3Eroj zioIVpR/727J12Kl
LUf0fp944onEs3J5AG9el5wmvBm7K+HcXKKRGAq9l7woKENrJS/fFl5++WX9 3L6+vs7vcGURkEi+
F5ILJb8RDt1duXIl5JeGnnwS+iu2/mDe0GNtun+KS/8LeNwfuNOLL+EN1bvo oK709OnTEydODB23
fT5D+kvIfrG16isXZz67TgAAAADwipQLyC1btnTXCf0al2LatGndFVT9LN25 1XdYDN+4ceOOO+7Q
TwzR29u7YMGClStXvvjii917uvQ9OmjLvQX9yQyhZ5zqP/vu9l379FhdlFXl kq8l+7tTZr8DAwNT
p07Vz7V6AG8uT2bQx6T+OIIOWSJcwrnZB0Bieg7VPkNrLi/HFl5//fW+vj79 3F27dmUXkEiOF5IX
Jb8Rbt3Nnz8/dNahQ4eCV0O/vPbUU0+FTn/44Ye7K2zatCl4Sbf6Fy9enFG8 nk1prtEKXUnr5u9a
Xrx4Ub26b98+/VWr5zOkf5vS1xTRl/roDlWw/WqMqp9dJwAAAAB4RcoF5KVL l0J3I5w5cyZ4NfSl
RVUz7quptutVq/oOi+EnnnhCP6t101dRu7Nnnnlm9+7dly9fzt6jg7bEFmx/ Y+Xq1auhFkKPUNb9
CocfUrGiuPe35GvJ/v6W3O/JkycjH8D7xhtvpGwhl19VGxgY0DVE1swS4RLO 1atlT89JkyaF6tQ8
Q2suL68WLl68qN/WqFi3bl0ul5BIXheSIyW/EW7dhZ6dq1izZk3w6ooVK7pf OnbsWOj0PXv2dFfo
/oJS6FzF1q1bM4qv5FfVZs6c2bF2Ozz44IN6nRdffNG5/ew1RfQ1ffr0UIVT p05ZdXH27NnsOgEA
AADAK9IvIO+6667uak8//XTwkvp390uG35SxXa9a1bdt/PLly/otFn19fRs3 bkxzo4XVjxrbakvT
wuuvv27VwsGDB0MthB6goT+hYvfu3bY6rSju/S35WrK/v+X3G/kAXhW3lHcZ 3XnnnaFzDxw4YKt/
7969oUbuuOOOyJpZrrSEc/VqtumpohdqQb9NruYZWnN5ubRw48YN/RbQlvFe zXLIHopqe7dqwa27
N998M3TWnDlzglcnTJgQHB87dqx+unrru++nVf8Obk0P/aTssGHDsv9RWGkL VTt8+HCay0yPriQk
e2BgIHRpijFjxnQ7wFbtZ68ZSeWLsVCF7gc4d7C9q199cmbXCQAAAABekX4B uWHDhu5q3Rauwfh1
7s6hvm3jGzduDNXv7e09ceKE+ayACxcupO/RVluaFqy+Rz8U9bMyoR/1vu++ +0IVnnnmGVudVhT3
/pZ8Ldnf30r6zfIAXv036NPf0xWwbdu2UCOq2ciaWa60hHP1anG/qRSHil6o hRUrVoTq1DxDay4v
lxZWrlypnzJz5kyHG9fzJXsoqu3dqgXn7mbNmtV9VvDTaaHvH4VmxoDQDxDs 379fHTx16lRIjP7M
XgfxejbZfqQkkkZJ6I7lDin/lpH+bUpfMxKrO10z9pWmhTVr1oQqPPnkk1Zd hG6ZcNMJAAAAAF6R
fgEZ9/iFy5cvhx7aoGpm786hvm3j+v0VaX6RKsDq5gpbbWlaMLjokejfsux+ cuBQ1HMqFi5caKvT
iuLe35KvJfv7W0m/V69ejXwAbxobYd26daGzdDcykWXLloUaeeyxxyJrZrnS Es7Vq9l+T3/VqlWh
FrZv3x6qU/MMrbm87C3oX+1v3bzPs/th7FWRPRTV9m7VgnN3+hDt3FQZemfj /lD1/PPPd1fr/Lzs
M888E2rz2WefzS4+9Eu1rR99jkQarl+/3tfXd++996qpf+vWrXv37lVHHJTo n9KKl156KVFA+rdJ
/xkyqwfVVr4YC1XQn8Ns+0m4aNGi7DoBAAAAwCusFpChh4m98MIL6qDaNXQf nDZtWl7d2da3bVx/
rl36h44q1q9fn75HW21pWgg9VyGRyZMnh1oIPVpQ3yKpPVfK72C6Udz7W/K1 ZH9/q+r39OnT+vNJ
VGok5oIeYTXAbHvv/jZ0hzhjOcuVlnCuXs3wgJpIdJv93LlzoTo1z9Cay8vY wsGDB3UPSh3p/mWu
Cskeimp7t2rBubvXX389dOKjjz6qji9evLj7Pb1y5Urk6aFnO9x5553q4MKF C0Nt6pnrIF53COOe
WhOHno9jxoxxUKKioT+fYezYsYmpnbJ9hf4Q+LjfbojE6k7X9DWdWxgcHAz9 KJ7VJ6H+OxduOgEA
AADAK6wWkI8//nh3zc6380LfH4y79c6hO9v6to3r62dz/RAzZ87Ue4z7jXhb bWlaUNuHuE2ojv7Q
XbVfC9VRWxJ9k+XwU0H79+9Xu8j+/v6VK1du375ddR13H05x72/J15L9/XUj l371xyO0bn7ZPHSj
Vwh9A9v60d+gT0QfkwZfJcuVlnCuXk1di9nk6ebYsWN6/PVqNc/QmsvL0oJ6 K8eOHatX3rx5s22P
BZE9FNX2btVClu4mTZrUfeKdd96pZu3ucdvxbOOYNm1aUFPl+NWrV0Mfg7Nm zcrlSiM/YK3+AP3I
I4+ETlerNQclQzE3x4Zac77Soag/te/bty/9lc6bNy99X+lrZmlBf7BG+k9C /bZtN50AAAAA4BVW
C8ijR49211RbD30DcuTIkby6s61v69bq9eO8WZ2XXnopcvkdZ4jZXniaFlo2 j5LQtz+rV6/Wq+nf
wezr6zt//ryVVP3nYOIeY2gVFtv3t8xrsbqQHMmr3+XLl+tNJT5pofuGtw4L FixI36n+u2zz58+P
q5zlSks4V6/W+sFtgWnQnxIT95zGkjO0zkk3VJZRc/Xq1ci/5a1atcq2u+LI Hopqe7dqIctfZkOe
p2pq//793UfMLlzodPUhGVKSOCmnv9LQY34VqveUl6nWZvrfI55//nk3JUNO z2dI376e8ukf2R16
aFhiX1ZX7dyC/rfLkSNHpvl735kzZ/Rv07jpBAAAAACvsF1Ajhs3rrvyQw89 1P2/6tV8u7Oq39vb
a9W4frvInj17zKd0OH/+fOR9XIqBgYHsF5KyhdbNn4EzPOU4IPLmzMgT9XsI Wzd/Iya97x35aMoD
Bw6kvChDy7bvb5nXYnUhOZJXv9euXQs9d6WD/ujXblQobE8JCD3RJfHcLFda wrl6tdbNv3+dPHky
sYtdu3bpJ164cCGycskZWuekGyrLqNH/itEy/iWiErKHotrerVqwHZbdhLzc 1s0nHnT/r/kv1Pv2
7euurK8iXn/99byuNNRX66YXnfKHX5988snQuepTJfS4A6uYX758OfL5DIZH KKRvX/+NzhkzZqS5
TIXKRL0jQ19WV52lhblz54aqzZw5U4XR0LIKZuRE7KYTAAAAALzCdgEZulMl tLV58MEH8+3Oqr5+
w0Pn57DjuOeee0L10zzX7ty5c5E/RNUhbudle+FpWugwbdo0837h0KFD+tel lyxZEldfD4uiv78/
za+c7NmzR/8yqWGbZhUW2/e3zGuxupAcybHfyAfw9vX1nTlzxnDW7NmzQ6eo wZb4fIYDBw7oYzLf
R3aXfK5ercOkSZPMj1tUnxi6QWS+Q6/MDK1z0g2VYtTov8PVuvm2Wj0XtASy h6La3q1acBiWATdu
3NAzLmD06NGJp+ufXQFpnj1udaX6TeMTJkxIvBn+8OHDugGufxfDSsmQ/fMZ 0re/ceNGvbL5x+k6
RH7rxNyX7VU7t6DeBb3m9OnT4/4if/LkScPa0kEnAAAAAHiF7QIycnkfoF7N tzur+hMnTgxVfvnl
lw31N2zYoLdv/rLt1q1b1e7PEIG4u39tLzxNCwFqvxBnwW3fvl3fCJu/IXj2 7NnILwbOmTPHcCOi
2vM++eSTkT8Fsn///vQXZYiA7ftb5rVYXUiO5NuvGi16g+YH8B45ckQ/ZcSI ESpT4k7ZsmVLpD1i
ftBilist4Vy9WsDkyZPj/uiza9cu/fPEfDvcULkZWuekGyreqNm5c6deYdSo UadOnbLtqGiyh6La
3q1acBiW3SxdulTvrsP999+feHrkvdwd0jw5wepKIx3C8ePHG/6CtmPHjr6+ vtApvb29+jN7rZR0
iAyd6jHjlaoPjch4Pvfcc3GnqDXPXXfdFXmWuS+Hq3ZuYeXKlXrlnp4etc5U H2udP3ip6XXv3r0r
VqyI/PTLohMAAAAAvMJ2Aan24HHPBBsxYkTi129tu7Oqr98zpvaAnW9ZqvWz 7rtevHhRv7+ldfNW
sS1btqitUOdy1LkHDx586qmnzLdVdHjxxRdzufA0LXSLV/9W+0q14+tovnr1 6s6dO+O+saiuztxX
5LfmWze/Fqo2tmorF3xtXAVHbVLWrl2rb7c7mN1yq7DYvr9lXovVheRI7v0+ +OCDepvme/JDP7YY
MHfu3BdeeCG4zUz9Q/2v/mXVDg8//HBxV1rCuZEXFaAGm9q8q9HVSc9r166p 9Fy0aFFk5TQ+VWkZ
Wuekiwx7YuisWtBdslywFel2IQXhEEY3/YbKbsMyINK075DmwTKbN2+OO10t FfK9UsWaNWsi+1q4
cKG6kOAvQefOndu2bZv+MPMOkY+xtVUyZPl8Bqv21eVEKldThrquYB5RHx3q A0R9jHR7oZE2b1xH
Dlft3IL6qJ81a1bkdTlgqxMAAAAAvMJhAak/Ia1DmptebLuzqr9q1Srz2li/ gy7yW7cpWbdu3eTJ
k0MH47wI2wtP00LkvceJJNpoHdTVOTQeYv78+eavY+unGCo7vL+lXYvVheRI 7v26PYBX//UfKxYt
WlTolZZwrl4tzq40s379+pTCysnQOidd+nfHuYXslxCJrUi3CylTfPZrtGrB eVh20H8NNiDNAzfO
nz8fee6YMWNyv9IOGT9g49ZmDkqGop4THteFVfsnT55MvHk1kvHjx1+4cCF9 X25X7dyCGi1Tpkyx
vSj987O3t9dWJwAAAAB4hcNCN/Lr2610N73YdmdVP/I7jGaFN27ciLvXxUzn TphHH300dHzq1Km5
XHjKFuKc9jgeeuih9D2qa7RqPER/f3/isxAjLyoOh/e3tGuxupAcKaLf06dP 67csmh/AOzg4aDsU
A5YuXZrmiaxZrrSEc/Vqx48fNz/FRUft6NMLGyolQ+ucdJFhtwpgYgtZ9Buw Fel2IWWKz36NVi1k
GZYdIp8OPXv27JRqI2/IXL58ee5X2iHLB+ySJUvivlTloKRDyucz2Lb//PPP 217d2LFjO897Sd+X
81U7t3Dx4sV58+alvKLe3t7Ot6v047Y6AQAAAMArHBa6AwMD+i0W6siVK1dy 7862vtrIGJbNkV8w
v3z5spXBO2HChOAH3M+fP68/pyLygXi2F5KyhfSbPrU1MDzCLg51Lfr9yYmo mGzcuNH5ogw4vL/l
XIvtheRFQf1G/gVn+vTpZrdNBSryUSdxjB49+oUXXkgpKcuVlnBuZLXjx4+n vIN37NixVg8ODSg6
Q4dqnHRDuLvFS00pPvs12raQZVgO3Xz6t37W448/nlLtY489pp+eMoWdY2X7 AasqRz6QIbsStWoa
N25c6Fz9+QwO7asZIe7ZXzozZ84MHiacvi/nq87YwubNmxOng7vvvjt4pnfo JRUWW50AAAAA4BVu
y9QFCxaEzlJHiujOtv7g4GDkg0M73HnnnZFn3bhxY/369YmPWFSbl3Xr1l29 erX7XLUZSRMKtzin
bOH555833yV47733Ov8MkArOc889N23aNHNwOqgYrl69OvEXvdNcVCRu728J 12J7IXlRXL8OD+BV
qL32ihUr4r71HDBq1Kg1a9ak+RJ0QJYrLeHcuGqXL19WATGEQu3ZH3vsMVUt vaQQhWboUI2Tbgh3
t3ipKcVnv0bbFjIOy4sXL+p/pD58+HBKtQcOHAid29vbm/i7A25X2o36gF25 cmXiB6y6tKVLl549
e7Y4JS+//LJ+euj5DG7tv/nmm8uXLzc/pWHMmDFqzdYd8PR9ZbnqjC0owXv2 7FHvoBqf6pNfvY/q
MtWH3t1337127druH51UNfVLttUJAAAAACCdY8eOrVq1atasWWr93HuT0aNH q/XzihUrDGddu3Zt
27ZtS5YsmTlzZnDiqFGjFixY8Mgjj+zduzfl3q0SlPjnn39+8eLF48ePD5Qv WrRI7YAMX6i34sSJ
Exs2bFDbtxkzZgTxUf+YPHlyf3//mjVrSguR2/vbTX2upZEMDAxs37596dKl c+fOVeOwE161h503
b556j3bu3Nm82Jr3+2fPnlWbd3X5KggqFCNGjJg2bZr6qFEfOIkPH0hPoaOa pIMakn1YSkR9wL74
4ovLli1THynBB6yKgIqD+lTZsmXLxYsXq9aYFXUJmzZtUh8XU6ZMUR+YnQtU a7MHHnhATS7Xr1+v
WmCxqHkhNKHcddddVYsCAAAAAAAAaDLZ7wcDAAAYunkDc2hC6e/vr1oUAAAA AAAAQJPB3QUAgFzY
vXt3aEJJfCwSAAAAAAAAAGQBdxcAADr09fUtWrRo+fLlW7du3b17t+0TeNav Xx+aUFQ7BUkFAAAA
AAAAgCHcXQAA+AEjRowIzQhWP52p/wzlsWPHilMLAAAAAAAAALi7AADQYebM maEZ4YUXXkh57vbt
20Pnjh07tlC1AAAAAAAAAIC7CwAAHZYvXx6aEaZNmzY4OJh44unTp0ePHh06 d/Xq1SVoBgAAAAAA
APAZ3F0AAOiwd+9efVK4++67L168aDhr3759Y8eODZ01cuTICxculKYcAAAA AAAAwE9wdwEAIGD6
9On6vNDX1/fQQw/t2rUreAzv4ODgiRMnNm/ePH/+fL2+YtOmTdVeCAAAAAAA AIAP4O4CAEDA0aNH
e3p6Ig3b9Cxfvrzq6wAAAAAAAADwAtxdAADoZseOHcOGDcPaBQAAAAAAAKg/ uLsAABDiyJEjU6ZM
sfV1R48evXXr1qq1AwAAAAAAAHhEr0bVigAAoHoGBwc3bNgwadKkNL7umDFj 1q5de+nSpapVAwAA
AAAAAAAAAMA/cfjw4XXr1i1evHjKlCkjR47s/B1Q/WPSpEn9/f2PPvrovn37 bty4UbVMAAAAAAAA
AAAAAKgXrZukqROQe/sAAAAAAAAAAAAAYIvZfW3Fk75x3F0AAAAAAAAAAACA fDG7r3GvpvRsnW/3
BQAAAAAAAAAAAIA40tyI6/ZSZBdZ5QIAAAAAAAAAAABA1PMWDNVsXwpVwN0F AAAAAAAAAAAAyIWQ
qRvnvqb3b80v4e4CAAAAAAAAAAAA5ELIbs3d3Q3dD4y7CwAAAAAAAAAAAFAE Bbm76dsBAAAAAAAA
AAAAAAfydXf1g7i7AAAAAAAAAAAAAEWQo7sbeiZDynYAAAAAAAAAAAAAwIHc 3V2rdm6//XYbsdFc
/d619r7/SKFQKBQKhUKhUCgUceX131qt9o2dElfnGxuePf/hjwyOuO3d4cPV f9W/1ZFcKufYwjeO
/WX27S0AAIAtebm7bu3kcluvaHf3O2+8UbkGlEspcpWr8o1vfKNyDb6FHeWI tyokKco9ES9XOUmK
+KYqf+XLu97+8R8P3N1I5acfWBZU6C7qeMbKkcWtBaUcdxcAACohF3c38pkM adrB3T137lzlGlAu
pchVrsprr71WuQbfwo5yxFsVkhTlnoiXq5wkRXwjlb+yY/ffT53W7aDqyo9/ 5ncjvdZOOf47a50r
RxbnFpRy3F0AAKiEfN1dM5GNZL8E3F2Uo7z+hT0pyn1QLlo8SYpyT8TLVU6S Ir55yg//69//3tj/
PmSfhpTvfuXVa2M+0HnpnVtv/eaTX1QH1X9v9PR0DqpXVR2HypElSwu4uwAA UBW4u9UWEesulNek
yFXeZk+Kcj+UixZPkqLcE/FylZOkiG+S8gNb/t3f/cIvRd4cG1J+9PNPBy/9 zX2fCI5/u//jwfFv
rf+CQ+XIkqUF3F0AAKgKg4vr9pJVTdzdmq+7UF6rIld5mz0pyv1QLlo8SYpy T8TLVU6SIr5Jyrvt
3O+/v8/g7n7nY/3BS0c//3Rw/FvrvxAc/86vLHaoHFmytIC7CwAAVYG7W22p +boL5bUqcpW32ZOi
3A/losWTpCj3RLxc5SQp4pukPHBK3/7xHz/4b7cY3N3vfvBDwUtf374jOP7K l3cFx1Udh8qRJUsL
uLsAAFAViRau/qrhSQtW7Q/h7tZ+3YXyWhW5ytvsSVHuh3LR4klSlHsiXq5y khTxTVLesUkv/q9z
9r30lfaP3sobUn7tJ8YEL+3+6oHguPp3cPz6qFEOlSNLlhZwdwEAoCoS3df0 D9F1a99asQbuLspR
Xv/CnhTlPigXLZ4kRbkn4uUqJ0kR3yTll//Fz3Q/98Dg7r7T2xu8FGokOK7q OFSOLFlawN0FAICq
SGPVuvm6adrH3a35ugvltSpylbfZk6LcD+WixZOkKPdEvFzlJCniG6zc4O6+ e8stiXbru8OHO1SO
LFlawN0FAAA/wd2Vte5COcqdC3tSlPugXLR4khTlnoiXq5wkRXyDlePuAgAA yAV3V9a6C+Uody7s
SVHug3LR4klSlHsiXq5ykhTxDVZucHdv9PSkf1SCVeXIkqUF3F0AAPAT3F1Z 6y6Uo9y5sCdFuQ/K
RYsnSVHuiXi5yklSxDdYucHd/f77+9L/zJlV5ciSpQXcXQAA8BPcXVnrLpSj 3LmwJ0W5D8pFiydJ
Ue6JeLnKSVLEN1i5wd397gc/FLy076WvBMe/9kd/GhxXdRwqR5YsLeDuAgCA n+Duylp3oRzlzoU9
Kcp9UC5aPEmKck/Ey1VOkiK+wcoN7u7fLvzl4KVvrf9CcFz9Ozj+7f6PO1SO LFlawN0FAAA/wd2V
te5COcqdC3tSlPugXLR4khTlnoiXq5wkRXyDlRvc3T//7OcibdWzv/prwfFv PvlFh8qRJUsLuLsA
AA2jdZM0dQJyqSkO3F1Z6y6Uo9y5sCdFuQ/KRYsnSVHuiXi5yklSxDdYucHd 3f3VA2/fPrrz0o2e
nqOff1od/OZTv/dOb2/n4LUxH9j9yqsOlUP9urUQijnuLgBAkzDbsK14nGsK BXdX1roL5Sh3LuxJ
Ue6DctHiSVKUeyJernKSFPENVm5wd1U5sfoz3RVC5fhnfte5su7u2rYQijnu LgBAYzAbsIlGrkNN
ueDuylp3oRzlzoU9Kcp9UC5aPEmKck/Ey1VOkiK+wcrN7q4qpz/16Uiv9cwn PpmlcqS7a9tdd8xx
dwEAGkCa22vTv+TWiCxwd2Wtu1COcufCnhTlPigXLZ4kRbkn4uUqJ0kR32Dl ie6uKof+zR+cv+uj
gyNHvjt8+OCI285/+CPf2PBsXIMpK8e5u7bdBTHH3QUAkE7Khyfg7naDuytr 3YVylDsX9qQo90G5
aPEkKco9ES9XOUmKeJTXvODuAgBIJ2Tqxrmvia5sYgvpmxIB7q7o1UvlGlAu qLAnRbkPykWLJ0lR
7ol4ucpJUsSjvOYFdxcAQDopb7vF3Q2Buyt69VK5BpQLKuxJUe6DctHiSVKU eyJernKSFPEor3nB
3QUAaBi4uynB3RW9eqlcA8oFFfakKPdBuWjxJCnKPREvVzlJiniU17zg7gIA NAzc3ZTg7opevVSu
AeWCCntSlPugXLR4khTlnoiXq5wkRTzKa15wdwEAGgbubkpyuITvfGfwsc/+ 9Sd/XWi58tu/XbkG
lEspcpWr8nfLl1euwbewoxzxVoUkRbkn4uUqJ0kRj/KaF6X8zd/439X+NId9 MgAA1ADc3ZRkv4T3
nnjivVaLQqFQKBQKhUKhUCiUissTT+SyUwYAgMrB3U2J0Ht3P+c00auzSvvb tOrrS78827aos/5w
3jzbos56dd4y2xIZjdL+ql5V194q/2vuOEK5H8pFiydJUe6JeLnKSVLEo7zm hXt3AQAaBu5uSoQ+
d/e/ybYvitKeK6X6mv2lFbZFnTXvc5+zLeqsz33uVdsSGY3SnohVVdfeKm/z tECU+6FctHiSFOWe
iJernCRFPMprXnjuLgBAw8DdTQnuLu5uJeuuqrr2VnmbPSnK/VAuWjxJinJP xMtVTpIiHuU1L7i7
AAANA3c3Jbi7uLuVrLuq6tpb5W32pCj3Q7lo8SQpyj0RL1c5SYp4lNe84O4C ADQMg/Wa/iW3RmSB
u4u7W8m6q6quvVXeZk+Kcj+UixZPkqLcE/FylZOkiEd5zQvuLgBAw8DdTQnu Lu5uJeuuqrr2Vnmb
PSnK/VAuWjxJinJPxMtVTpIiHuU1L7i7AAANI9GY1V/Vj6evKRfcXdzdStZd VXXtrfI2e1KU+6Fc
tHiSFOWeiJernCRFPMprXnB3AQAahtl9bcXjXFMouLu4u5Wsu6rq2lvlbfak KPdDuWjxJCnKPREv
VzlJiniU17zg7gIANIw0Bmx6t7aRvm4H3F3c3UrWXVV17a3yNntSlPuhXLR4 khTlnoiXq5wkRTzK
a15wdwEAwE9wd3F3K1l3VdW1t8rb7ElR7ody0eJJUpR7Il6ucpIU8SivecHd BQAAP8Hdxd2tZN1V
VdfeKm+zJ0W5H8pFiydJUe6JeLnKSVLEo7zmBXcXAAD8BHcXd7eSdVdVXXur vM2eFOV+KBctniRF
uSfi5SonSRGP8poX3F0AAPAT3F3c3UrWXVV17a3yNntSlPuhXLR4khTlnoiX q5wkRTzKa15wdwEA
wE9wd3F3K1l3VdW1t8rb7ElR7ody0eJJUpR7Il6ucpIU8SivecHdBQAAP8Hd xd2tZN1VVdfeKm+z
J0W5H8pFiydJUe6JeLnKSVLEo7zmBXcXAABqS+tHybc+7i7ubiXrrqq69lZ5 mz0pyv1QLlo8SYpy
T8TLVU6SIh7lNS+4uwAAUENaMeRVfwh3F3e3onVXVV17q7zNnhTlfigXLZ4k Rbkn4uUqJ0kRj/Ka
F9xdAACoG3HebJxhG1k/jSGcXSrubqRC3F3Duquqrr1V3mZPinI/lIsWT5Ki 3BPxcpWTpIhHec0L
7i4AANQNgytr5eKaDV7cXdzdStZdVXXtrfI2e1KU+6FctHiSFOWeiJernCRF PMprXnB3AQCgVtg+
USHNExvStOMG7m6kQtxdw7qrqq69Vd5mT4pyP5SLFk+SotwT8XKVk6SIR3nN C+4uAADUijTubneF
xPqGdhzOCoG7G6kQd9ew7qqqa2+Vt9mTotwP5aLFk6Qo90S8XOUkKeJRXvOC uwsAALXCyt11tnaH
cHdxdytad1XVtbfK2+xJUe6HctHiSVKUeyJernKSFPEor3nB3QUAgFqRxd1t dZGmo4xSh3B3YxTi
7hrWXVV17a3yNntSlPuhXLR4khTlnoiXq5wkRTzKa15wdwEAoFa4ubutGMzt ZFeLuxupEHfXsO6q
qmtvlbfZk6LcD+WixZOkKPdEvFzlJCniUV7zgrsLAAB1w2DMhmxbg5GbaPDi 7uLuVrLuqqprb5W3
2ZOi3A/losWTpCj3RLxc5SQp4lFe84K7CwAAdSPRsNXdXUM7hl6yS736vWuH XisVZ3e3TIX1d3dL
iwYAAAAAAEBxqA0p7i4AANQQw5MWdHc3sZ24l7Lr5N7dSIX1d3cr/Kt6VV17 q7zNHUco90O5aPEk
Kco9ES9XOUmKeJTXvODuAgBAbYl88ALuLu4u7i7KrQp7UpT7oFy0eJIU5Z6I l6ucJEU8ymtecHcB
AEAWuLu4u7i7KLcq7ElR7oNy0eJJUpR7Il6ucpIU8SivecHdBQAAQRju401T P/RSdj24u5EKcXcN
666quvZWeZs9Kcr9UC5aPEmKck/Ey1VOkiIe5TUvuLsAAFArzIat/qpt/e6X nEUG4O5GKsTdNay7
quraW+Vt9qQo90O5aPEkKco9ES9XOUmKeJTXvODuAgBArdAftKu/aj6S5qUh 3F3c3YrWXVV17a3y
NntSlPuhXLR4khTlnoiXq5wkRTzKa15wdwEAoG5EGrwG1zfyuNklHsLdxd2t aN1VVdfeKm9XsSdt
SaDM66p/DIN+RQ/1kPjs0SitYByh3BPxcpWTpBLF5zhL2s4dcsMuWjnuLgAA 1I24ZUNe9Ydwd3F3
K1p3VdW1t8rbFbm7bnk6NPQl26LO+tJ/GrItblngnKduff3JfffZlpufCdal 1Vx3d/aKIdtSySck
xhHKPREvVzlJKlF8VTOp6LCLVo67CwAANSS9T+tcP7tI3N1Ihbi7hnVXVV17 q7yNu4u7i7uLu1tW
zAUVucpFi5ernCSVKB53t/yYV6scdxcAADwEdxd3t5J1V1Vde6u8jbuLu4u7 i7tbVswFFbnKRYuX
q5wklSged7f8mFerHHcXAAA8BHcXd7eSdVdVXXurvI27i7uLu4u7W1bMBRW5 ykWLl6ucJJUoHne3
/JhXqxx3FwAAPAR3F3e3knVXVV17q7yNu4u7i7uLu1tWzAUVucpFi5ernCSV KB53t/yYV6scdxcA
ADwEdxd3t5J1V1Vde6u8jbuLu4u7i7tbVswFFbnKRYuXq5wklSged7f8mFer HHcXAAA8BHcXd7eS
dVdVXXurvI27i7uLu4u7W1bMBRW5ykWLl6ucJJUoHne3/JhXqxx3FwAAPAR3 F3e3knVXVV17q7yN
u4u7i7uLu1tWzAUVucpFi5ernCSVKB53N6+Y737l1b9a9duXZs56p7f33eHD r/7k+O98rP/r2/4k
rpFvbHj2/Ic/MjjiNlVZ/Vf9Wx2xkuHQAu4uAAD4Ce4u7m75pWFrXSkFdxd3 F3cXd7ecmAsqcpWL
Fi9XOUkqUTzubi4xf+XLu/5+6jR92fbOrbd+a91TegunH1gWucxTx1NqcGsB dxcAwDdaP0rKarl4
obUCdxd3t/zSpLWuoIK7i7uLu4u7W07MBRW5ykWLl6ucJJUoHnc3l5hf/hc/ E7dye/eWWw7/69/v
rnz8M79rWOkd/521iQKcW8DdBQDwB92wjbNt09eUC+4u7m75pUlrXUEFdxd3 F3cXd7ecmAsqcpWL
Fi9XOUkqUTzubvaYd3ut//hTEw5s+Xe7X3n1+O+sfae3t3NwYOJPB5XVS9fG fCC4s/ebT35RHVT/
vdHT0zmoXlV1DL1naQF3FwDAE+IcWv1gZM3mGby4u7i75ZfGrHVlFdxd3F3c XdzdcmIuqMhVLlq8
XOUkqUTxuLvZY35h7s8H67RvPvV7wfFTn/7N4Pg3vvh/dg4e/fzTwcG/ue8T QeVv9388OP6t9V8w
9J6lBdxdAABPMHiz3S8lVmuMwYu7i7tbfmnMWldWwd3F3cXdxd0tJ+aCilzl osXLVU6SShSPu5s9
5oMjbgvWad03ze7743+v27Df+Vh/cPDo558OKn9r/ReC49/5lcWG3rO0gLsL AOADia5sGnc3TTuC
wN3F3S2/NGatK6vg7uLu4u7i7pYTc0FFrnLR4uUqJ0klisfdzR7zd2+5JVin hWoGx//LHXd2jnz3
gx8KDn59+46g5itf3hUcV3UMvWdpAXcXAMAH0ri7adxO3N0QuLuRCnF340pj 1rqyCu4u7i7uLu5u
OTEXVOQqFy1ernKSVKJ43N3sMQ+er6vKn+3ZHxzf/dUDwfG3bx/dOXjtJ8b8 8Ebfrx6IrHx91ChD
71lawN0FAPAB3F0d3F3c3fJLY9a6sgruLu4u7i7ubjkxF1TkKhctXq5yklSi eNzd7DH/r//Lzwbr
tL/4V58Njn9r3VPB8Xd6ezsHu63gULN65ciSpQXcXQAAH8Dd1cHdxd0tvzRm rSur4O7i7uLu4u6W
E3NBRa5y0eLlKidJJYrH3c0e87966JHue3QPP/OcOnjo2ee7b7J9d/jwTuU0 j3EIKkeWLC3g7gIA
+EAu7m6TrN0h3F3c3SpKY9a6sgruLu4u7i7ubjkxF1TkKhctXq5yklSieNzd 7DHf/cqr//DT/8y8
fsPdBQCAMjF4s60f4NyCRHB3cXfLL41Z68oquLu4u7i7uLvlxFxQkatctHi5 yklSieJxd3OJ+de3
7/jHn5oQWrMNjrhtYMLEzr/fufXWTs0bPT2J3qz5yQxZWsDdBQDwhDgLt9VF 4ulFCiybvNzdQ6+V
irNrVKbC+ru7pUUD/ESEu+t2XW556tZXmXtSNxyuq0yc3d2qhQMAQA6UPJNW fbkFcuRrXzv367/+
vYkT373llnduvfW7//Jf/qc//uO//+AHO+u3t3/yJzvVBvv6gkXd4YMHg9PV v4Pj3x81ytCRcwtq
Q4q7CwDgD3H706Ek87Z51u4Q9+5y724VpUl3Mggqr3HvLvfuJu1JVSBtS4Wf JHGFe3crj7mgIle5
aPFylZOkEsWXPJM2I+zplb9z662d9dv5D3+kc+S7H/xQsKjb99JXgppf+6M/ DY6rOoY2s7SAuwsA
4BshX7f7oKF+WerKA3cXd7f84sNat4YFdxd3F3cXd7ecmAsqcpWLFi9XOUkq UTzubnEx/w9/+GKw
fjv16d/sHPzbhb8cHPzW+i8EldW/g+Pf7v+4odksLeDuAgDAULyF21Rrdwh3 F3e3itL4tW49C+4u
7i7uLu5uOTEXVOQqFy1ernKSVKJ43N3sMf+7X/ilC3N//tqYD7zT29t9M+3p B5YF67f/8H9v7xz8
889+LtKDPfurvxYc/+aTXzT0nqUF3F0AAPDQ2h3C3cXdraI0Zq0rq+Du4u7i 7uLulhNzQUWuctHi
5SonSSWKx93NHvP/8vN3Beu0C3N//pUv79r9yqsnVn/m3eHDg4NB5d1fPfD2 7aM7x2/09Bz9/NPq
4Def+r13ens7B6+N+YA6PajfvQh0ayGkHHcXAKDxmH3ayFebbe0O4e7i7tZg xSioyFXext3F3cXd
xd0tK+aCilzlosXLVU6SShSPu5s95q9t/LeGldvbt4/++vYd3fVPrP6Mof7x z/xud2Xd3bVtIaQc
dxcAoPG0foDhVfOR5oG7i7tbfmnMWldWwd3F3cXdxd0tJ+aCilzlosXLVU6S ShSPu5tLzE99+jcj
l23/+FMTgmcydJfTn/p0ZP0zn/hkqGaku2vVQkg57i4AgA9EGryGg+WqqwDc Xdzd8kuT1rqCCu4u
7i7uLu5uOTEXVOQqFy1ernKSVKJ43N28Yn7o3/zB+bs+Ojhy5Lu33PJOb++l mbP+atVv/9me/XGN
/LD+8OGDI247/+GPfGPDs3q1OHc3fQsh5bi7AACe0IohTZ24+nLB3cXdLb80 bK0rpeDu4u7i7uLu
lhNzQUWuctHi5SonSSWKx90tP+bVKsfdBQDwh0SfFnfXCtzdSIW4u4Z1V1Vd e6u8jbuLu4u7i7tb
VswFFbnKRYuXq5wklSged7f8mFerHHcXAAA8BHcXd7eSdVdVXXurvI27i7uL u4u7W1bMBRW5ykWL
l6ucJJUoHne3/JhXqxx3FwAAPAR3F3e3knVXVV17q7yNu4u7i7uLu1tWzAUV ucpFi5ernCSVKB53
t/yYV6scdxcAADwEdxd3t5J1V1Vde6u8jbuLu4u7i7tbVswFFbnKRYuXq5wk lSged7f8mFerHHcX
AAA8JBd3d2jUqPdare4y+P73B5Os+nfur3Zco/eiSuAR6S+91fohb5X46sBt 7wv8W/Vvw6v6uf94
662BO6T+Hflqx919+9ZwrNSRwMvVX60qGrxqO9rlvqpf73vGDH2vy9197/bb wq/eflvg5eqvvtXl
7n6/7/bQq+qI4dUs72CaDO0Ut3e/dXNPOtjTE361pyfYgeqvvtW1J3371nC/ 6ojh1fdu+6Fzq/5t
9WodRp3+6ltd7u7A+8LvvjpieLWeV8SrOb4aOBjOLVc4a7z7Yz9mpZnZSvqr Wd5BNVpqqKqcMRlx
rnEO7bzaarnMoW91ubv1GTm+vfpOX18O21sAAABRtDy7d7fMewLrf+9u/e8J DC+a0xT1H3tujg3r
0pJzT2Cbe3drkKduMax/nlYyng2Fe3crj7mgkl15yUnqIN55Mq1z2KsqgmbS 0mLOTMq9u7Uq3LsL
AAB+grvbDNcIdxd3N7EI2pM2NU/dYlj/PK1kPBsK7m7lMRdUcHdxd62KoJm0 tJgzk+Lu1qrg7gIA
QG1p/Sg5Vh7C3W2Ka4S7i7ubWATtSZuap24xrH+eVjKeDQV3t/KYCyq4u7i7 VkXQTFpazJlJcXdr
VXB3AQCghrTiyVi5+6zsOnF3K3eNcHdxdxOLoD1pU/PULYb1z9NKxrOh4O5W HnNBBXcXd9eqCJpJ
S4s5Mynubq0K7i4AANSQSG/W7O6mrNxdIaPIIdzdGrhGuLu4u4lF0J60qXnq FsP652kl49lQcHcr
j7mggruLu2tVBM2kpcWcmRR3t1YFdxcAAOqGwZjVX7KqHHo1i8gOuLuVu0a4 u7i7iUXQnrSpeeoW
w/rnaSXj2VBwdyuPuaCCu4u7a1UEzaSlxZyZFHe3VgV3FwAA6gburqHgGoXW uri7uLuJRdCetKl5
6hbD+udpJePZUHB3K4+5oIK7i7trVQTNpKXFnJkUd7dWBXcXAADqBu6uoeAa hda6uLu4u4lF0J60
qXnqFsP652kl49lQcHcrj7mggruLu2tVBM2kpcWcmRR3t1YFdxcAAOoG7q6h 4BqF1rq4u7i7iUXQ
nrSpeeoWw/rnaSXj2VBwdyuPuaCCu4u7a1UEzaSlxZyZFHe3VgV3FwAAakik MRvn1lpV7q6QUeQQ
7m4NXCPcXdzdxCJoT9rUPHWLYf3ztJLxbCi4u5XHXFDB3cXdtSqCZtLSYs5M irtbq4K7CwAA9aQV
RS6Vg1Oyi8Tdrdw1wt3F3U0sgvakTc1TtxjWP08rGc+GgrtbecwFFdxd3F2r ImgmLS3mzKS4u7Uq
uLsAAFBDIt3aOM/WqnL3Wdl14u5W7hrh7uLuJhZBe9Km5qlbDOufp5WMZ0PB 3a085oIK7i7urlUR
NJOWFnNmUtzdWhXcXQAAqBtx3mzkcavKoQrZpV793rVDr5UKrlForYu7K8vd LTddKoM8DeWpWwzr
n6e5j5x8IU+hUEpOUjeFbpNp7rECB5xn0jIVMpNmTFLIC7Uhxd0FAIC6YXBl 49xd23aGuHe3Ka4R
7q4sd7eSmxlek3PHUVPz1C2G9c/TSsazoXDvbuUxF1S4d5d7d62KoJm0tJgz k2ZP0hoW0cpxdwEA
oD6YLdlQBavK+kvOIgNwdyt3jXB3cXcTi6A9aVPz1C2G9c/TSsazoeDuVh5z QQV3F3fXqgiaSUuL
OTMp7m6tCu4uAADUCtxdc8E1Cq11cXdxdxOLoD1pU/PULYb1z9NKxrOh4O5W HnNBBXcXd9eqCJpJ
S4s5Mynubq0K7i4AANQK3F1zwTUKrXVxd3F3E4ugPWlT89QthvXP00rGs6Hg 7lYec0EFdxd316oI
mklLizkzKe5urQruLgAA1ArcXXPBNQqtdXF3cXcTi6A9aVPz1C2G9c/TSsaz oeDuVh5zQQV3F3fX
qgiaSUuLOTMp7m6tCu4uAADUDbMlG3rJqnLo1SwiO+DuVu4a4e7i7iYWQXvS puapWwzrn6eVjGdD
wd2tPOaCCu4u7q5VETSTlhZzZlLc3VoV3F0AAKgbrR+Q5rhV5VCF7FJxdyt3 jXB3cXcTi6A9aVPz
1C2G9c/TSsazoeDuVh5zQQV3F3fXqgiaSUuLOTNpPknqRHEDT26S4u4CAEAN MczmGSt3n5VdJ+5u
5a4R7i7ubmIRtCdtap66xbD+eVrJeDYU3N3KYy6o4O7i7loVQTNpaTFnJiVJ a1VwdwEAoLakt2pt
Kw/h7jbFNcLdxd1NLIL2pE3NU7cY1j9PKxnPhoK7W3nMBRXcXYwjqyJoJi0t 5sykJGmtCu4uAAD4
Ce5uM1wj3F3c3cQiaE/a1Dx1i2H987SS8WwouLuVx1xQwd3FOLIqgmbS0mLO TEqS1qrg7gIAgJ/g
7jbDNcLdxd1NLIL2pE3NU7cY1j9PKxnPhoK7W3nMBRXcXYwjqyJoJi0t5syk JGmtCu4uAAD4Ce5u
M1wj3F3c3cQiaE/a1Dx1i2H987SS8WwouLuVx1xQwd3FOLIqgmbS0mLOTEqS 1qrg7gIAgJ/g7jbD
NcLdxd1NLIL2pE3NU7cY1j9PKxnPhoK7W3nMBRXcXYwjqyJoJi0t5sykJGmt Cu4uAAD4Ce5uM1wj
3F3c3cQiaE/a1Dx1i2H987SS8WwouLuVx1xQwd3FOLIqgmbS0mLOTEqS1qrg 7gIAgJ/g7jbDNcLd
xd1NLIL2pE3NU7cY1j9PKxnPhoK7W3nMBRXcXYwjqyJoJi0t5sykJGmtCu4u AAD4Ce5uM1wj3F3c
3cQiaE/a1Dx1i2H987SS8WwouLuVx1xQwd3FOLIqgmbS0mLOTEqS1qrg7gIA +EbrR7E9sThhJYO7
2wzXCHcXdzexCNqTNjVP3WJY/zytZDwbCu5u5TEXVHB3MY6siqCZtLSYM5OS pLUquLsAAP7Qiif9
uSXoLAfc3Wa4Rri7uLuJRdCetKl56hbD+udpJePZUHB3K4+5oIK7i3FkVQTN pKXFnJmUJK1Vwd0F
APCHSHs2jWdr5QNLAXe3Ga4R7i7ubmIRtCdtap66xbD+eVrJeDYU3N3KYy6o 4O5iHFkVQTNpaTFn
JiVJa1VwdwEAPMHgzSbatri7ceDuVu4a4e7i7iYWQXvSpuapWwwF5KkTxQ08 3N3yi2gfIGMLGEde
DRhBM6lDzJ0/z5lJu5PUEackdSNN0OQmKe4uAIAndCY125e6XzVXE0cu14K7 W7lrhLuLu5tYBO1J
m5qnbjFsap4WN/Bwd8svon2AjC2UnKQO4uufpIKKoJnUIebMpOJmUrcVb5qg yU1S3F0AAE9wc3e7
X8Ld1cHdrXyti7uLu5tYBO1Jm5qnbjFsap4WN/Bwd8svon2AjC3g7no1YATN pA4xZyYVN5Pi7kYq
x90FAPABB3e39QMSW5AI7m4zXCPcXdzdxCJoT9rUPHWLYVPztLiBh7tbfhHt A2RsAXfXqwEjaCZ1
iDkzqbiZFHc3UjnuLgCAJ0Tas+ldX9xdHdzdyte6uLu4u4lF0J60qXnqFsOm 5mlxAw93t/wi2gfI
2ALurlcDRtBM6hBzZlJxMynubqRy3F0AAH9oRWGoaT4iGtzdZrhGuLu4u4lF 0J60qXnqFsOm5mlx
Aw93t/wi2gfI2ALurlcDRtBM6hBzZlJxMynubqRy3F0AAE+ItHYjPdvI47i7 Ori7la91cXdxdxOL
oD1pU/PULYZNzdPiBh7ubvlFtA+QsQXcXa8GjKCZ1CHmzKTiZlLc3UjluLsA AD6Q3cjF3dW5+r1r
h14rFVyj0FoXd1eWu1tuulQGeRrKU7cYNjVPcx9vhhiSp1AcJSepm8KaJykY cJ5J3fpiJpU1k7qt
eN1i6IZDX1lQG1LcXQAAT2j9k3WQ/FJcTUMLEsnlWrh3t/K1Lu6uLHe3kpsZ XpNzx1FT89Qthk3N
0+IGHvfull9E3+WVsYWSk9RBfP2TVFARNJM6xJyZVNxM6rbiTRM0uTMp7i4A gA8kGrNBheAPjg6N
yAJ3txmuEe4u7m5iEbQnbWqeusWwqXla3MCTuyfF3ZWoHHfXqwEjaCZ1iDkz qbiZFHc3UjnuLgBA
43Fwd82UJbxAcHeb4Rrh7uLuJhZBe9Km5qlbDJuap8UNPLl7Utxdicpxd70a MIJmUoeYM5OKm0lx
dyOV4+4CADQe3F0d3N1muEa4u7i7iUXQnrSpeeoWw6bmaXEDT+6eFHdXonLc Xa8GjKCZ1CHmzKTi
ZlLc3UjluLsAAI0nvbubsY4gcHeb4Rrh7uLuJhZBe9Km5qlbDJuap8UNPLl7 Utxdicpxd70aMIJm
UoeYM5OKm0lxdyOV4+4CAPiAwZtNadvi7urg7la+1sXdxd1NLIL2pE3NU7cY NjVPixt4cvekuLsS
lePuejVgBM2kDjFnJhU3k+LuRirH3QUA8IHWD0h5PK6FYtRVAO5uM1wj3F3c 3cQiaE/a1Dx1i2FT
87S4gSd3T4q7K1E57q5XA0bQTOoQc2ZScTMp7m6kctxdAABPaMWT/vSiRZYG 7m4zXCPcXdzdxCJo
T9rUPHWLYVPztLiBJ3dPirsrUTnurlcDRtBM6hBzZlJxMynubqRy3F0AAK9w 8HW7TyxOWMng7jbD
NcLdxd1NLIL2pE3NU7cYNjVPixt4cvekuLsSlePuejVgBM2kDjFnJhU3k+Lu RirH3QUAAA/B3W2G
a4S7i7ubWATtSZuap24xbGqeFjfw5O5JcXclKsfd9WrACJpJHWLOTCpuJsXd jVSOuwsAAB6Cu9sM
1wh3F3c3sQjakzY1T91i2NQ8LW7gyd2T4u5KVI6769WAETSTOsScmVTcTIq7 G6kcdxcAADwEd7cZ
rhHuLu5uYhG0J21qnrrFsKl5WtzAk7snxd2VqBx316sBI2gmdYg5M6m4mRR3 N1I57i4AAHgI7m4z
XCPcXdzdxCJoT9rUPHWLYVPztLiBJ3dPirsrUTnurlcDRtBM6hBzZlJxMynu bqRy3F0AAPAQ3N1m
uEa4u7i7iUXQnrSpeeoWw6bmaXEDT+6eFHdXonLcXa8GjKCZ1CHmzKTiZlLc 3UjluLsAAOAhuLvN
cI1wd3F3E4ugPWlT89Qthk3N0+IGntw9Ke6uROW4u14NGEEzqUPMmUnFzaS4 u5HKcXcBAKCetH6U
HCsP4e42xTXC3cXdTSyC9qRNzVO3GDY1T4sbeHL3pLi7EpXj7no1YATNpA4x ZyYVN5Pi7kYqx90F
AIC60YonY+Xus7LrxN2tfK2Lu4u7m1gE7UmbmqduMWxqnhY38OTuSXF3JSrH 3fVqwAiaSR1izkwq
bibF3Y1UjrsLAAB1I9KbNRxMf7y7QnaduLuVr3Vxd3F3E4ugPWlT89Qthk3N 0+IGntw9Ke6uROW4
u14NGEEzqUPMmUnFzaS4u5HKcXcBAKBWGFxZ/SWryqFXs4jsgLtb+VoXdxd3 N7EI2pM2NU/dYtjU
PC1u4Mndk+LuSlSOu+vVgBE0kzrEnJlU3EyKuxupHHcXAABqBe5uEWvdprpG uLu4u4lF0J60qXnq
FsOm5mlxA0/unhR3V6Jy3F2vBoygmdQh5syk4mZS3N1I5bi7AABQK9Ibtmb/ NrGpLCI74O5WvtbF
3cXdTSyC9qRNzVO3GDY1T4sbeHL3pLi7EpXj7no1YATNpA4xZyYVN5Pi7kYq x90FAIBagbtbxFq3
qa4R7i7ubmIRtCdtap66xbCpeVrcwJO7J8Xdlagcd9erASNoJnWIOTOpuJkU dzdSOe4uAADUjUhX
Vj+Iu4trhLuLu5tYBO1Jm5qnbjFsap4WN/Dk7klxdyUqx931asAImkkdYs5M Km4mxd2NVI67CwAA
NaQVRWSdxEbiXsouEne38rUu7i7ubmIRtCdtap66xbCpeVrcwJO7J8Xdlagc d9erASNoJnWIOTOp
uJkUdzdSOe4uAADUjUhrV7dqcXdxjXB3cXcTi6A9aVPz1C2GTc3T4gae3D0p 7q5E5bi7Xg0YQTOp
Q8yZScXNpLi7kcpxdwEAoFZEGrmRx+vg7h56rVRwjUJrXdxdWe5uuelSGeRp KE/daGqeljkOydM4
nIdlzfsqk5KT1BGnJG3k+yWOlutM6tYXM6msmdRtxeuGiJlUbUhxdwEAoG50 ZtI0Lxlqpmkqi8gO
3Ltb+VoXd1eWu1v+nQxtUXcckac+5GlxA0/uHUeCktQc87i+3JK00AiIu3e3 /pNpOWGvqpCkzKQN
SNJmr3hxdwEAoFZYGba4u7hGrHVZ6yYWQXtS8tSHPC1u4OHulpCk5pjH9YW7 KytJ3SbTcsJeVSFJ
mUkbkKTNXvHi7gIAQK3A3S1orYtrxFrXz7VuW9SelDz1IU+LG3i4uyUkqTnm cX3h7spKUrfJtJyw
V1VIUmbSBiRps1e8uLsAAFArcHcLWuviGrHW9XOt2xa1JyVPfcjT4gYe7m4J SWqOeVxfuLuyktRt
Mi0n7FUVkpSZtAFJ2uwVL+4uAADUClvD1uzfGprC3cU1Yq3rw1q3LWpPSp76 kKfFDTzc3RKS1Bzz
uL5wd2UlqdtkWk7YqyokKTNpA5K02Ste3F0AAKgbVoYt7i6uEWtd1rrmImhP Sp76kKfFDTzc3RKS
1BzzuL5wd2UlqdtkWk7YqyokKTNpA5K02Ste3F0AA
Re: Birt 2.0RC little problems [message #104927 is a reply to message #104704] Thu, 05 January 2006 11:13 Go to previous messageGo to next message
------=_NextPart_000_0014_01C6121B.4BAAA790
boundary="----=_NextPart_001_0015_01C6121B.4BAAA790"
------=_NextPart_001_0015_01C6121B.4BAAA790
Hi Kurt,
Regarding the chart issue, there is a bugzilla entry filed for it: =
https://bugs.eclipse.org/bugs/show_bug.cgi?id=3D122739 . We will make =
sure that when using params[".."] or an invalid expression in =
databinding, it ignores the dataset's parameter binding inside the chart =
builder live preview table. During design there is indeed no access to =
params[...], which is a runtime expression. I think we should be able to =
fix this particular problem this week or early next week.
David
"Kurt Knippschild" <kurt@ingenieurbuero-knippschild.de> wrote in =
message news:dpipdk$8vo$1@utils.eclipse.org...
Hi all,
product.
without error.
b.. after the pagebreak there is no headrow,=20
c.. the columwidth is allways the same,=20
d.. the rowheight is on the 3. page wrong=20
e.. from the masterpage there fails the right column.=20
I have a verry important presentation with BIRT on 26.Jan.2006, what =
do you think, the problems in pdf are eliminated on this date?
Once moore thanks
Kurt
<HTML><HEAD>
<META content=3D"MSHTML 6.00.2900.2180" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Hi Kurt,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Regarding the chart issue, there is a =
bugzilla=20
entry filed for it: <A=20
href=3D"https://bugs.eclipse.org/bugs/show_bug.cgi?id=3D122739">https://b=
ugs.eclipse.org/bugs/show_bug.cgi?id=3D122739</A>&nbsp;.=20
We will make sure that when using params[".."] or an invalid expression =
in=20
builder=20
params[...],=20
which is a runtime expression. I think we should be able to fix this =
particular=20
problem&nbsp;this week or early next week.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thanks,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>David</FONT></DIV>
<BLOCKQUOTE dir=3Dltr=20
<DIV>"Kurt Knippschild" &lt;<A=20
href=3D"mailto:kurt@ingenieurbuero-knippschild.de">kurt@ingenieurbuero-kn=
ippschild.de</A>&gt;=20
wrote in message <A=20
href=3D"news:dpipdk$8vo$1@utils.eclipse.org">news:dpipdk$8vo$1@utils.ecli=
pse.org</A>...</DIV>
and i will=20
problems in=20
this is the=20
src=3D"cid:000f01c61212$e9e63f90$0301a8c0@david" align=3Dbaseline=20
binding I=20
can edit the chart without error.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I have attached two pdf's =
(birt20M3.pdf und=20
<DIV><FONT face=3DArial size=3D2>The rptdesignfile where I generated =
the pdf's are=20
<UL>
<LI><FONT face=3DArial size=3D2>after the pagebreak there is no =
headrow,</FONT>=20
same,</FONT>=20
wrong</FONT>=20
right=20
column.</FONT>=20
Birt2.0M3 is=20
<DIV><FONT face=3DArial size=3D2>The image of the chart are =
considerable=20
<DIV><FONT face=3DArial size=3D2>The template are works, the libary =
are works and=20
with BIRT=20
on 26.Jan.2006, what do you think, the problems in pdf are eliminated =
on this=20
date?</FONT></DIV>
<DIV><FONT face=3DArial =
size=3D2>Kurt</FONT></DIV></BLOCKQUOTE></BODY></HTML>
------=_NextPart_001_0015_01C6121B.4BAAA790--
Content-ID: <000f01c61212$e9e63f90$0301a8c0@david>
------=_NextPart_000_0014_01C6121B.4BAAA790--
Re: Birt 2.0RC little problems [message #105241 is a reply to message #104927] Fri, 06 January 2006 02:59 Go to previous messageGo to next message
------=_NextPart_000_0076_01C6129F.6F396410
boundary="----=_NextPart_001_0077_01C6129F.6F396410"
------=_NextPart_001_0077_01C6129F.6F396410
Hi David,
Thanks for your answer.
But what is with the pdf-problems?
Thanks=20
Kurt
"David Michonneau" <dmichonneau@actuate.com> schrieb im Newsbeitrag =
news:dpjgjt$ss0$1@utils.eclipse.org...
Hi Kurt,
David
Hi all,
the Birt 2.0 RC is verry verry good, and i will thanks for this =
great product.
without error.
I have attached two pdf's (birt20M3.pdf und birt20RC.pdf) here you =
Once moore thanks
Kurt
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
<DIV><FONT size=3D2>
<P>Hi David,</P>
<P>Thanks for your answer.</P>
<P>But what is with the pdf-problems?</P>
<P>Thanks </P>
<P>Kurt</P></FONT></DIV>
<DIV>"David Michonneau" &lt;<A=20
href=3D"mailto:dmichonneau@actuate.com">dmichonneau@actuate.com</A>&gt; =
schrieb=20
im Newsbeitrag <A=20
href=3D"news:dpjgjt$ss0$1@utils.eclipse.org">news:dpjgjt$ss0$1@utils.ecli=
bugzilla=20
We will make sure that when using params[".."] or an invalid =
expression in=20
databinding, it ignores the dataset's parameter binding inside the =
chart=20
params[...], which is a runtime expression. I think we should be able =
to fix=20
this particular problem&nbsp;this week or early next =
week.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>the Birt 2.0 RC is verry verry =
good, and i will=20
<DIV><FONT face=3DArial size=3D2>But I have tested it und this =
little problems=20
in the moment I found:</FONT></DIV>
this is the=20
src=3D"cid:007101c61297$0d6eba80$464da8c0@kommserver" =
align=3Dbaseline=20
<DIV><FONT face=3DArial size=3D2>when I delete the parameter from =
the binding I=20
the pdf's=20
are the same.</FONT></DIV>
<UL>
headrow,</FONT>=20
same,</FONT>=20
wrong</FONT>=20
<LI><FONT face=3DArial size=3D2>from the masterpage there fails =
the right=20
column.</FONT>=20
Birt2.0M3 is=20
considerable=20
are works=20
and also many other problems are repaired.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I have a verry important =
presentation with BIRT=20
on 26.Jan.2006, what do you think, the problems in pdf are =
eliminated on=20
this date?</FONT></DIV>
<DIV><FONT face=3DArial=20
size=3D2>Kurt</FONT></DIV></BLOCKQUOTE></BLOCKQUOTE></BODY ></HTML>
------=_NextPart_001_0077_01C6129F.6F396410--
Content-ID: <007101c61297$0d6eba80$464da8c0@kommserver>
------=_NextPart_000_0076_01C6129F.6F396410--
Re: Birt 2.0RC little problems [message #105314 is a reply to message #105241] Fri, 06 January 2006 04:43 Go to previous message
------=_NextPart_000_003C_01C612AD.FF5EC180
Content-Type: multipart/alternative;
boundary="----=_NextPart_001_003D_01C612AD.FF5EC180"
------=_NextPart_001_003D_01C612AD.FF5EC180
Content-Type: text/plain;
charset="iso-8859-1"
Hi Kurt,
I can't answer for the pdf problems, probably the other committers will =
assist you. The best is to repost a separate question in the newsgroups =
for that, or you can file bugzilla entries.
David
message news:dpl7uq$c7v$1@utils.eclipse.org...
Hi David,
Thanks=20
Kurt
Hi Kurt,
David
Hi all,
great product.
But I have tested it und this little problems in the moment I =
found:
A chart with parameter do not work, this is the error
when I delete the parameter from the binding I can edit the chart =
without error.
The rptdesignfile where I generated the pdf's are the same.
This are the problems in birt20RC.pdf
a.. The pagebreak is wrong,=20
f.. on the last page there fails the footrow.
The problems with the fonts in Birt2.0M3 is repaired.
The image of the chart are considerable better.
The template are works, the libary are works and also many other =
I have a verry important presentation with BIRT on 26.Jan.2006, =
what do you think, the problems in pdf are eliminated on this date?
Once moore thanks
Kurt
Content-Type: text/html;
<HTML><HEAD>
charset=3Diso-8859-1">
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>I can't answer for the pdf problems, =
probably the=20
other committers will assist you. The best is to repost a separate =
question in=20
the newsgroups for that, or you can file bugzilla entries.</FONT></DIV>
href=3D"news:dpl7uq$c7v$1@utils.eclipse.org">news:dpl7uq$c7v$1@utils.ecli=
<P>Hi David,</P>
<P>Thanks </P>
href=3D"mailto:dmichonneau@actuate.com">dmichonneau@actuate.com</A>&gt;=20
schrieb im Newsbeitrag <A=20
<DIV><FONT face=3DArial size=3D2>Regarding the chart issue, there is =
a bugzilla=20
expression in=20
chart=20
builder live preview table. During design there is indeed no access =
to=20
params[...], which is a runtime expression. I think we should be =
able to fix=20
week.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Hi all,</FONT></DIV>
good, and i=20
will thanks for this great product.</FONT></DIV>
little problems=20
<DIV><FONT face=3DArial size=3D2>A chart with parameter do not =
work, this is=20
the error</FONT></DIV><FONT face=3DArial size=3D2></FONT>
<DIV><FONT face=3DArial size=3D2><IMG alt=3D"" hspace=3D0=20
src=3D"cid:003701c612a5$9d980f90$0301a8c0@david" align=3Dbaseline=20
border=3D0></FONT></DIV>
the binding=20
I can edit the chart without error.</FONT></DIV>
birt20RC.pdf) here you can see my other problems.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>The rptdesignfile where I =
generated the pdf's=20
<DIV><FONT face=3DArial size=3D2>This are&nbsp;the problems in=20
birt20RC.pdf</FONT></DIV>
<UL>
<LI><FONT face=3DArial size=3D2>The pagebreak is wrong, </FONT>
<LI><FONT face=3DArial size=3D2>after the pagebreak there is no=20
headrow,</FONT>=20
<LI><FONT face=3DArial size=3D2>the columwidth is allways the =
same,</FONT>=20
<LI><FONT face=3DArial size=3D2>the rowheight is on the 3. page =
wrong</FONT>=20
the right=20
column.</FONT>=20
<LI><FONT face=3DArial size=3D2>on the last page there fails the =
footrow.</FONT></LI></UL>
<DIV><FONT face=3DArial size=3D2>The problems with the fonts in =
Birt2.0M3 is=20
considerable=20
better.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>The template are works, the =
libary are works=20
presentation with=20
BIRT on 26.Jan.2006, what do you think, the problems in pdf are =
eliminated=20
on this date?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Once moore thanks</FONT></DIV>
size=3D2>Kurt</FONT></DIV></BLOCKQUOTE></BLOCKQUOTE></BLOCKQUOTE ></BODY><=
/HTML>
------=_NextPart_001_003D_01C612AD.FF5EC180--
Content-Type: image/gif;
name="charterror.gif"
Content-ID: <003701c612a5$9d980f90$0301a8c0@david>
R0lGODlhHALXAfcAANfSyv///wAAAIKCgv8AAAAAgm2GypKy4zlFpiQtmllt vqLG74ai2xQYjn2a
10lZsl1xvpa25zVBpjE9onmW0gwQimF1wiAolqbK857C63WOzkFRrlVpuhwk lhgckj1JqnGKzoKe
1xAUji01noqq32V9xlFhtkVVrpq6546u4wgMhk1dtoqm33WS0hggkj1Nqpq+ 656+61Vluhwgki05
nggIhoIAAAQEghAUiml9xmF5wkFNqmmCyk1hto6q3zE5onmS0gwMiqbK7ygx nmV5xmmCxigxmig1
nkVVsllpunGOzpa656LC70VRroKe246u301dslFltoam2wQIhhQcjiAoml11 wjlJqpKu4yQxmlFl
unGKyiAklkldsmV5wjU9ojVBoklJkgAEggQEhmlZ64Ki232W0klVsoqm24Ka 1xAQii05ohQckqbG
7xAYjl1xwpq6622Cyn2W15a240FNrm2KylFFqlFJsk1Fpk1FolVJtkFBhlFF rkFBgkVBjoqi0lFJ
rlFRmnGKvllZojU1fVVJuiAgbU1FqkVBkklFmkVBijkxkoKaznWOwhgYZX2W xklBlklFnqam0teq
zk1FnhAQXSgodYaeznmSxklFloKaynmSwmltsj09isrK5+/b6+PC33Fxpn19 ss6y0mFlqlFRkpKS
xnl1ukVFjrKu17KOwo6Ovsqexte20klJmi0ogm1tsp6CukFBirqaxi0odUVF ilFNoq6awmFdotvO
58aOvo55rmVlqigtdcqiyj09hpJ9vlFJtqaCsuPX63Fxupp9uiQgbXl5qlFJ ihwcbYaGtiQkedLO
53VtspZ5ssaeykVBmsrG4+PC286uzraawl1ZpmVhqsaexv////////////// ////////////////
/////////////////////////////////////////////////////yH5BAEA ANgALAAAAAAcAtcB
AAj/AAEIHEiwoMGDCBMqXMiwocOHECNKnEixosWLGDNq3Mixo8ePIBNiGwkg gMmTKFOqXMmypcuX
MGPKnEmzps2bOHPq3Mmzp8+fQIMKHUq05QABJUMqXcq0qdOnUKNKnUq1asej Sa1q3cq1q9evYMOK
9Yg1gMACaNOqXcsWrZi3Ym7InTu3ht27d1Xo3Rukb5AKgAGrGYyjsGHDDRIr XqyYimMqHiJHduFi
huXLljto3tyBi+cLoEOLTkC6tOkERlKrTn2k9YjXsEfQmE2bxpofuH9M2L37 i2/fYIILByOhOILj
yJNfufKhefMX0F/smE59B50N2Dc02X6iu3fvZx6I/x9PXnyXLlDSq4fSo317 E/BNRJk/X4sWGfjx
c9jPIYn//woEKKACEBRo4IEQWKGgBQw2qMODXkQYIREUElHChTlkqGEORXTY YRwghhiHASSWaEAd
W6SoIggsKuGiBjDGqEELLQBh4404UkCBGTz2yKMDQAaZxpAhFGmkkWUkycCS TErhJBpQRhklCVT6
YKUPT2SpZZZYdInFAWCGCeYcZJZZ5hJoponCmmyiAAMMMcQZZwZ01mknE0ws oOeeC7ThpxCABiro
oIQKIVBZZ6FFxqKMNtooW3DFRRddeFW6F19+BSYYYYcdxtiniT0GmWQeUIYZ Zpxt5hkXorV6wWmw
rv+2WmtHxAZbbbTdlhtvvf32xXDCFSdBcsQisJxzz0VXHXXXZbddE99FG155 1J63nnruvRcfffXd
l58M/PX3n38DCojguQpa0aCDEEroRYUWYrhhhh5+KCKIJpaIooopsgiCi0rI GCONOBYMhI4++hik
kEQeeWSSZTDZ5JNSSkklCVdiuaWWXn4pZphmhpymmm2u+aacc9qpMp587uln G4XGXOihSJkFgKJ9
5LyHIn6ggkgmiVCSBx52hLFWpJNSWmlel6rg11+aDqZGp56CypiopJZa2amZ pdrZZ66GButpsqpG
q62v4TqbrrjxOoGvvwJLnHHFIncsstFJt6x12Wn/x1204FFbLXrXspdtfPJx a9+34PI3LrnlEnju
gemuy+CDOrj7boUXljAvvfXei2++J/Lbb4svCjxjjQbfiHDCPy7swJBpOPyw khIz4KQUFVtc5ZUb
c+zlxyCHfObIS5RsMpwoq7xyni33+WegMwkAKM1Z4ZyzLLUo8jPQQhNttFpI Jy3X0kxf+rSmFUhN
NWJWL4Y1qaZyPYPXX7MaNmhjm1Y2a65Bm9pskxvd8ApucpvbsOp2nLs5J297 45uz/ga4E0xLcOOx
VuGy1QPEcSsKi/tWuB6XhMhJbnIFqpzlMKc5eHXucxwKnehIVzrT+Qtgqltd 61y3I9iZQXaza5jt
/0IAsdzpjmK9Q8PFMhY8Lg2PeAcw3vFGpjw3MU9OzrsT9Fr2MkHZbCFHuR4A EHWzApAhZ6WgRitG
AYxTwKIathjaIcaXlvLRxSQ3wItJ0oepvrDPfe/DQfzk95is1Y9r+FvV/vjX P9L8zwhnE6Da2GZA
3iBQbsJiYAOZgzdl7a1Z2HlWBbtzQQw+QIPX4qAHFeet/IzwcSZEoYFUuC4W usuF8ppXvYoguhGR
bl/8umHqBEawHR6sh7ADIu2GWKQi5m53SYTSEoHXxI5BMYpSnAPykqe8kzUv i3RiWfS6SL2GhNFQ
Y6xZosiwh1pM4xO5kAQxOMGLQQTCFeJDS0rekv80POoxAHzUy/qixqn3DbIx haTf1hDpNUUuspGO
/F8kbTVASrrtksDKpCYdmCzoRBCUfoPWKEuJQVSuR5XbYiXjXjmuWMoyQQta YbskhEvPfW6XvaQh
MFeEuoCprpg7fF0yZbdMZjpTYtCM5jSt1MQnWBOK2dQm8qroTSyCMwPi5OL0 APVFASBlIF6lmRjJ
qChFCEMaw/CEJOhpzzD8AhpF02cACmDHufjzLnu0S9OclimCTi2QBw1VQiVz yFMlEmz7gyhqJBpA
ik6ygBf1VQI1ykCOfgCCn+ybKEdqygwSLpWHSyl9QuhKx8Eyci+Fqbpkmrlb ci6XG8LpDH9pui3/
CNOnxGRdUJGZMGUK0XZHnRjvlPo7plbzicSL6japesWUgTOrfCInVwkSVgBU N51jVWcZyYAKVkiD
GdFIhSlWoQxRHCMUuADE+ExCV7igRC4psUteUaIXkwQhAFALDCANGtj5EXah hm0oYsOm2EdONDYV
hewBJYtJulWWkw/05LJAutkKklRwJsVWaOHzQdLqx7QtRe1Lacmu1tL0tTbV pQzvpdPa3jaHQG2d
UHtL1N86LLhLSmoSl6qx4D01udlcbjebG4OrYnWL0d2qEL4oEK9eF7voJKsZ UTGJP/zhEozQxCMw
sYlGCEIQ6pXrScSAxxvg0Z97THMA6rtmlOR3/1N/5e9B/TsZAKNKwPpLLEQN 3FgEP3ZXC/7NZB1c
N8tidsKapSDgLjy4whnOPascbSs/vB8SulSWJL7cTCeEYhjKlsW0tWFPYaxb GfNWYTWunVFxh1Qk
9o7HTf3xx5Q71SGjrMhXha7LlMzkJn91IOfEns0UhYhJ6KIZ9QyEWwnRC2Mk I8wFYK97U2LmAORR
zTVQiQrs60e/BlKQ/R1sne13Pzwv8lV7ZmytJIkriwYaOA1e4IORdVkJV4fC ipZWZ83z2ZNuOHGS
XimIASRiTMe0lpveHIVeeNMVi6jFov7XMGUUY4PNGNULK+oQcXzE4e64uD3e mKzFRGsq2vqbz/9F
8q5hVk7qOpkgwU5n9syYiWtY+RKa0DKXvSyIO6x3rtOeFJoBquamcfvN7Sso 1QLbADprjdyHzTOB
0122A9/qz217d9wySuhiGdrezEq0SC2871P2W8OQFm23BF7p05YrtZm2gC1P vHDYaujTDw91MEf9
01Jb/NQ98q2qN85q4UZTiSCPNXJnHeRal6yqzs2irvUk3SW73NfAtl6Utauo RMTCF85Q9i+YbQxH
VGIRPpdre8ls7TtaO9tEj73R8dtt/Sq9U0x3emHvnCqH6rmRfF63Y9utYEsy mOvyLjSEO6o3RE9w
7Isue4bTg1IOq1SEA4fc20d88BK3sNMN91D/TvXOU4njluJ+L9jFA59qZhKx 8Dl2dcVgfdwuXbPk
JHs8kY08eemxfLqYB1ZfFXNSRgaUQAmqcA27gAqkZ3qvcAd68HOrx3onUW3X FnvyRV9H90e3VzVz
Jm5PZz9Rd24Fpm5oIxtYV0m9ImjxpknGsnz15lGZ9XyjZEHSd3bU928dNmmN 03Yhtn0Gt1oIZ2Kc
VncpFlsOFyIQt3fmR2rGdEw+9EPtt2oR80zy5zsYQ00+tngk13gmp3+3xn8q R3m8Zk6aJ2zrlAdq
WAyzcAvIQAvGsAyoFwwReDRwYT7ngz41sFcDZXtxtnTh5hiGZGeXMYIPRXWy YnVpk4KRxYLI/+eC
XyeDzhdK+fYdjFYe0/do2mJ9AYd9PkhwQIhCcTd3RRgvR3h3STg6+bJTp9OE ffeE6xc7GWdjt1OF
reZxr5Z49ecxQCZFQgaGKCd5Y+h/XmSG2TVzZIAHyogHh2AHdgAI0AiBelAI dOQWd4iHeriHTdOH
cPZtuQeCu1eI5naIwGeC7FYb7mZ8jjgclKV89HZo9yZ2NXiJ5JGJ1Qdwa+eJ 4vKDAwJ33adpRKhw
puhpqehLq+hifJdbsAh4ssgwgwdc8Ndxh0d/W2h/UOWF+dcmkIdrKRc9xEg9 AxCSIjmSI3mGMjds
ZmQHzeiM0AgIdyCNhUCNdshP2KiHfNhXfv/ojYE4Kv8FdeP4e/0TfCeYYICm jvD2iBsFg/AYdjTI
Wftmjzp4faX1idrXj9wnhN7nWkZIkOI3WwcZcTj0isYUi1I4iw95YxGpY7mY hcZVkbzIeL7oeBq5
f7k2jJXnZHiZl3h5jChZAGHwl4AZmIEJKddoPtl4k7XXjYC1k4Pok703YK5S glXXZ1dHfEW5gkfJ
jl1HLJHYfPHYlGT3lDioiR2kdiDEgywFilYZhJYjdwlXU1xpL6D2lUwYlgo5 lgxZlg7pfhynlvOn
i255fxiJJswVhnXpkZUnMzKDhmXUFs5JmDRpmDa5jTipmHI2SLpHiF3zmFIX mYg4K5S5iJZQmXVG
uXWamXxep5RgNx34Bn36JpqOdo87yHb7qJrmcpWtSYoCyXAq1pWzaSKsaFsJ iX4LGYWCx5tpeYVT
Apwix4XFE5dfOJfG2ZHjpGTKGTP/zDkWGrqhHNqhHvqhILqhZBSiJFqiJnqi KJqiJDqiKtqiLvqi
MBqjMvoQLDqjNnqjOJqjOsoVNbqjPvqjQBqkQsoQPTqkRnqkSJqkKVqkStqk TvqkUEoVTBqlVFql
VnqlEjGlWLqlXNqlVKqlXhqmYjqmOwqmZHqmaJqmJmqmatqmbvqmXcGmcDqn dFqnISGndpqnerqn
EIGnfPqngAqofhqohFqocDqohpqoiiqmiEoQNvCokPqoizqplCqkjQqpBJCp mpqpkFqpnvqpMoqo
NrCppEqqNuCmvxYRTwZWBZGqF7GqQeqqISGrO0qrCWGrJ+qnj1qqvKqpkgoR L3erdsH6cngpgMHa
ZAaBq6y6ELBKEcp6q9BKXRrxrNLKENSqEMV6ENSalw1Bq9eqqsDarNOqrcIq Ed+KrMyarNY6FXg6
qr36rpwKrti6rF/1a6l6reeKrfk6r+YarcuKEeeKrxZhr84qr0yxr9YVFbgq rvzqEAibsGL/Iafu
Cq/weqoPUa/Hiq4QW6//CrHVSqyrOqzWlbHoyrElG1bZOrIYW10ga6y+trIv a7Ii66oii6zDerMw
ixQwq7IvG7Md67E7q7MoS7OtSq8sC7Qbe7RBS7Iqu7M8q65PS7BPG7Uom7BC y7KwKrNGu7I6a7Vb
u7E9+7UkO7NMCxISS7EUawMDcLEae6/HarIeG7c2W61027VSS69tG7d3O7d8 y7EEe7ddO7d/u7BI
C7iFK4B5a7hSS7M167Vaa6xwS7SB67iserR8q7eVm7n+ermSS7cjy7lyi7eH +69Cm7jSCren67mm
u7d3ql0LMbGaGgDwKrumurbdmreke7Ih/6uu1yWr3Dq5RAu2Nmu4TTu6flus 9oq8mfu72kqsmlu4
ytu20du0wIsQg+u8j6uxz6u8f0u9QDu991q5yEu4xeu1Ptu7dTu6UVuy4pu7 int5AXi6rOu91csU
Zgq7mXoSvaq/puqwuIu72au90hu6nau9eom0mNe9oKu1wSu33dvA7ru9z/u/ DVzB1jvB5ou6viu8
lCu4RSvAe6vAreqtCBy4gDu56ovCkFu1AyzCImy+8fu9BFy08/sR90uqKVGq Obypanu7CAzA/zvD
GHy4IZy6BpzCxrvAEezBl7vEMOzCPwzFoOvAEmzCRwy1RLy8EjzFpnvFNJy7 QYzCUEzCW/+sxF3M
vh0bvhvMxKFrw66bEPhLADucvyhRqmpru8Javz7Ls+ErwFbbu4zrt2n8sSAb ueeruTJruWGrwI3r
cljLwnv8tmIMyIssupDrshlswCnrtiwcvY3cuIG8tIF8yZo8tMlbvZsMwVw7 tdNbvs67x+KbvCMs
yH7sxlkBx/tbx3Ksy3aMx6C6FA/7ywabp2Aax7HbEu/aw8IMEmW7zBwRzF5a zLO7EhUbks58zdhs
FdI8zbzcq3eczeAczk2xze+qEmlrzRUBwa8KzcDcouq8EQw7Fir8EfNMz9b7 sOycq298EMZ8zOac
zOh8z2X7zgXrv+s6sK+MxaobswIbrgP//cEOTb5Kwa0ZUc8dIcbp3LDpC6xD Ss46jMzeHNDkqtFt
PBEB68MF/bPpqtD2TNIIW8Ml/cweYdEync8qvdAxfdBB6tGbusNzXLu+zNJU a7kzO8uJ+8iinMGP
vMjNTMWUe7VOC8KSXLWpvMaOHMmVjLpRvNTrK8qnXMmpa8JKW8uwXNRD/blh C7UZW9VpHclLDdWY
XL47vc/8/NH8S8d37asiqa8JjcrQC61S/MQyjMRcnKxjjdZ+bdiK7NeBzdBI jMqsu7hlXLqPnb7Z
irVHfdNB/Me8y77PWs9jjMWJLdiN/aM33NPdjNcmAdRBDdGO/cCtfMmBDdV6 zLyvrdny/+vEwAvJ
Z2y3sWzKDgy+f5zQzQvIfQ2+ws3JvB3FQ3zBujvJnTy885q1VSza9FvFwm2p dG0QcZzXqE27PCzS
I/2zD+zavc3cFgzC5I3bWlzZLB3aL2zeFqzCymrIGw3GTuzU+B3f/jrajDzA 4/1koQ3R9F3d9w2k
bNrds9vL4v3e1c3fA+7e6K3bZJ3JEa668F3G6q3EL5zesz3hTRzfxAvDMR3h /425443ipG3dJk7Y
Ng2iZ4u2AL3XJL2+favIjrzKyp3WvC3JYM3BWB2/cB3D1/3cgj21Kg3KSavB rh20V623i83UXKvH
Nl7hVQ3dVjzcgL27uou4Of7j9TvVWjudozEu47x6x63NoS9+sBddqWsuzjS6 3QjRz2iL5iDa1GCx
5ngeqG8O52Z4yw2xq2ZOAI86kn5+6IieEf+DOgB0ztoNnuiQHulgJOcKweiC bseFbuiv6hQ0nefD
nNGevumSTuaUDkaWHqmZrukmTdw4Dc2d/uUV3cjk+q0Yi7ivXuFNXK64rtOK 3ay3Hte93tCjrhSN
eigkeeyPbtDsLdRsS+vLruzC7sOUvOvUntNebu0rne3MHuA1vrnDbsu9NhHI nuafLsh2i7OH3OVK
Hdlfu+49G+VDXrzxntxPzdXnbtzD6+S+veTv/tXL7u9ize64zslHPebffhHF 3hRmfdhHvuIeLNkH
ztlfDLaXXdkt7tugjdgP7r60XMC0/MPc/vCWvNkEjrdMfvAbkfBPQdkSPsbc 673FfcpYLrz/jL3x
ZkzzJJ7dw03VK1zCS57ltM3eMo/xKVvy/b3Jz47yFKHynJ7JN3/hHezSk43z 5c3hBk71IK6+he3z
if3xOO3FbNzfDUvG2K704l7qXWHFLf70Ua/V873EH7/vK7727U3Yc0/hCYzI XOz2JS/3fI/GRk/x
YG/2FcH0swrK1yvLrozu7r7hX77jDGzWP3/kFU/FtS7vpGzj9k66Oo7Gb0ve l33Yn2/UtUzwJWzw
hB8Rhs8V0R6r1Y6iMD2rqf8Vq78VrV+rAn6jsc/Ms0/7aN/7wB/8mQfowl/8 xn+SscrzAAvPWq7m
fT7TG/r82+4Vwezr5h2itf+hsG3rZf/Z/90P8vdNwuz80OP6+sqe67G+3N5e sGSf4uFa/p+O4Sia
/R66/UKO0t3e2WQ94tN//gABQCAAAQMNHkSYUGBBhQ0dGmT4UKLEiBMhWsSI sKLGjBA3drwI8uPA
jSNBnkR5cEDBACldOhQQM6LMhQQXxrxZEGdOmxx12tS5kyZQgkOLMgyKVGjP gyZnkuQJVOhSpR+r
Vo36k+bOozyxHp05lWvNnkNlXiUptmTTqB7Fei1pVC7Os2mTZjUKtazerXPR duVq9i1YsmaZvkTc
cCWAlokdM107tibSySHZaiXqk3Llyk8nO22IeTNRz1LJHt7LGXLRwqdV/3y9 unTmp7Wh2u523TXz
Ydy0Xc/eLdty77WpgwOH7Xt3cuLLWT+GbnBx4+guPdetiL114ISbMdtlflt7 2K2hzX8/+x0s87oh
m8dOrT12bfm8S4enXz737fXD+3v3j7DsxNPrvwJbk+2+nPDbrr70hHvQpOpe mm5C6/iDT7mwUENQ
vfeCc84yjhQSLbfwAuzutBNDpKw5F9n6zTgGVVORRBALTK5D/3pb7aYecXRL P8hmdA7A4lCz7UgL
HatwyZNerBFADGHkT0ErqwRSwtFQTDJLIN2b8r0WwxRuvgPHNDNNDjs7k0wp o5zyxxDn5E1OImdE
c04GeXSS/0KW+hTJrxzla3GpETFUa8jADB1My/3sZPSr7CQTclBD41vQR0n5 unTAz0Y70bDfRM0r
U93e7LG9SnV7TtQ6OaWr00xx8+7SUxG1FdCUmtTVIgkT+7XXjoIVtlhjj0U2 WWWXrY5XZg+srtRn
SZRsWmuvxTZbbbeVyFluvwU3XHHHJbdcbr01N11112W3XXfJRfddEeWlt157 78V3oHjBJRbafP8F
OGCBp933234fHThhhRdm2KWClRXsrfZOjfg5iqttOGONN173YWShLLPI7cjk uGSTT97W42MjJFmq
VY10EGWZZ6a5WJWNPXLFHMvMs8aafwY6aD8ZyxZkozEVU99opZdmWqU/i5aV tetkldLVLZvGOmuU
b9a6a6+/ppdrsMcmu+xznzY7bbXXxlZstt+GO+6hqSv5YMTsthdvvIVV8iWM p917277FdVvXiakM
7XDzDn1M77+BTZFakTIi1iqKYFLcRMfs7jfwpoRE3N/+Lqc8cyTTLRxQ4DDa 2/MnJy9Wy8D1fv1C
mEJPifOJXNec9ciXDHbwcFPvc+pCgwrd+DQNk1RaVRcdadPCoPeKtIphBBUv uljcvqyxsCqV+fA1
StT7nm/91NSKYbs+YkfBFO16aCcezy/Gta8VTd4n/yTeSVWxNA5h5EQaAJom ZJ4S2eJaRqNJqQl7
cMpS9gZ0NQYeykNBulORHPWhO0nQSwi7lVIcCB4IEjBDC8ogfla3rP4BTzzl QZXlyHPBpHTPQDH6
VKwW978ZWgyBHawagUrIo0Vpxl8sm01cXnbDz9lQZ0ycIXtW9RDkDVFRpzNT fmK1M5Z1pj7aaqGF
+MQ+HF7Eg11Ckc9K6JEUXUdGaXlVAps4Ram1bFD2Gc7OTpfE5BVwP0ej0Y9y RqXKKUeO83oRnxBJ
SBDtr09hnFAiEfSoK6FRT3ZaYPQE+aUKjjBGfOTgqxBYJ8uxqYxWJNIHLxnK DIXqPGrSIxZF9qHe
zf8yTo6MDiSjZT8NYfBM+iGUraw2R+01kYSj2qJdElREEaFFUPaR2DFfCEe3 nNAqVMtKd9wHza/U
UZk+Ql8ABbihHFITPKGCIazuF072CbNtaJObuHAJt3mqLjr1xJcu49krfJpN Wtyq5z9lps99FtSg
aiPoQRW6UK0lNHb9NNya7inRiWqzdgzF6EkcCiyBUrRxpnsdRNs4L8rdzoLD ymhKO7LRu4nOo5uL
1kshF1CT4s53KsVpt+AJOBw1iir4+6ar2LQpCkqTecWkXuTyQr/BHHN9AmQV SHM6VQCw1G98sWOr
3LQjwYCTPi4dYBXNOLLbadKTRwMkVdWqr50+i6mVlXJQzCYFuk0GUoHODBLS fiVWVepRiymM2VoF
a1XbIWd+h+0kYjd5sLSScUg2AicqTzrIMYJVsBklbO6w2srF3jJOdT3OXQ+I qFM2c0efHS1aN3tZ
nGYWJZ4Samyj1r7AZhOsb7VU9453HkqpM7Lqw+b0eihT1u7TtUITaXGVy67j Bi25y4VuuZobXepW
t1fTtW52tQv/Hey2NKLPjWlJvYstXIJ3u9nqbqBsaFPexVKbjxuWUEe6u8hu r3NUJC53NEutf7r3
vYnrKEnPu6T0itey6/QdYw/sqwUTl1PmvC/pqLjCm+IXshLea4UH/Mi2Wqs4 JXoeXoXLGbkwMoRI
PeMza0jCLmmlUS4jT/pO7Nj1xfjANm6nYUEIzSjlasOPKXDp9JenJ0rSjWk0 4Fj3wsOtqrZERkzt
YvV3GbIO0MQEPDInf+fGLZn3vEGenH7l6KLxjI580MstjSHU5K3qKM1STicK U2U+NT9ox1G0nkAp
rCL6NfjHc5OnITM4QvUo0IokziKbYTmyK62RTnPGk10pOkoT/9Y0w5T08593 1eGiLbnNUR7qamtZ
5CrTsICDPnVWLcnBSF9SlnByZYDMCunSahoxYN6d1bRIzRATtS2D+yKhysk9 +8IKVbQRMVRJJb3H
CqhDYlbii7t5zRXO1Wc+trXDOJ2uCGusqHnLNEyznbJtm6vbC1sqwPYsxnGf jWjthne8E4Nredf7
svT+WLHH29K72Nvf/Ct3vpK0If8KWMn4Xfe/FQ4SfK+sSuTML30vl/CFV3wi DT8zjs0HF2VqEsTS
VjZVQI5gi5f84gF3uOaqVWcBg3hNVZRkjy9scpqf/N3XMt6bYSY6I3ETzvpm IslrPnTpoBxnn6YV
n1/O6L5+di1FIPQy0b9s9NghnbSk/J0pR5toRxtc6kTHODFnlVeYFTUyXoVr UkUYTqF/veaRYfc6
5MztdroLBO7hVu+4Alx3i9+d73+vmd8BP/iTCZ7wh9eY4RG/eIUpnvGPB5jj IT95e0me8pd3l+Ux
v3nUUZ3zn1ea5kE/enfTjfSnZ5roUb96Zqme9a8/luthP3tdyZ72t7eQ7Q2M e94nRPCU3n3vhW93
z/Mz7hYefvJ/P9bmxfiteE8+4pcvRND8cM7RP//99F8z1zvmMOrY73vxI+r0 VCoS/NkXvz1RW36S
ff/89jb8/3791BHv+P2M1/399V/0m+/f//BKv/8TQGTJvwE8vwLMGNfBGOF5 LfczQEBxvAALsZBL
N5uyQDaSO5SaOQeTsA40tAc0FskLns3iIw9sQHHTwKzjQOQzQRUEQWERQVP5 kuw5IrhQomEDk1TZ
IhyrsaDyqUg5n2HapotBtuaTwRcEsgA0PkjRrxI8OA5ZtQcKmbDimUXjuiTz CVULEw86NCRkEiUc
PyfMH2DzoYy7oBz8qmtboiWLqyXqImIKpTfEszmEPi9UDDBUPzHUEZIiuPt5 uvTQmRS6Oi5SrEJt
g0KrCyQFQTKKs0OLiEFM2sM4apNSqrRR+kNQ66U4TDVKRLVO1MJJakSNwkP/ caK8AgwkcxlzyiYn
pDN2GjtE2zge4xls6zWfi6rc4rXZCsVN6z/ec8BdRAkEtK69A8ZnEcZiZL1j REbUU8ZlJGO9ZnRG
0IPGaOS8aaRGzLPGa6S8bNRGyOPGbsS/UQTHZfzGcTy8cjTHwUPHdPy7dWTH unPHd3S7eJRHqaPH
ehy6e8RHmtPHfSy5fvTHigPIgFS4gSRIfzPIg6y3hFTIeGPIhmxjt4eEyGyT yInUtIq0yB/DyIwc
sI3kyO3yyI/MrpAUyeoiyZKMrpNEyeVSyZUsrpZ0yXsTx5gUPpikSbWyyZuc qpzUydaayZ6kPZ4E
Ssz6yaF8PaE0yoVCyqQ8qKVkyoJyyqeMY6eolMq4ocqqfJurxMq10cqtTJuu 9MqyAcuwHJuxJMuv
Mcuz7Jq0VMusYcu2bJq3hMulkcu5FJq6tEugwcu8DLyi5Mtz9Mu/VMfAFMx2 JMzChMfDRMx5VMzF
tMfGdMx8hMzI5OrHyaTMf7TMyxTIzNTMguTMzkTIzwTNhRTN0XTI0jTNiETN 1KTI1WTNi3TN19TI
2JTNjqTN2gTJ28TNkdRNygyA3wTO4BTO4STO4jTO40RO44w2QGTO5nTO54TO 6HTOh9hLEDQ95iqJ
5NTO7eTO7gRO+Kqq3ozM6+yY7HyXlQiW6nxA8lSXxYAI9pQu8FRPA4RPc3FP kqAOl9NPLOPP/fRP
okBP6hRPx6zP+GyKxvhF7pLPAV3MAgXAA9UWBQtQh5jPAXTQBlREBYXQFcSc x9mgjJjQO+zF3ayO
C4UdTGkW89SwNkGYEaSvEFX/iAoVQBMNPkNMwg0NnmtCHCM8MVaJ0QUdURKF DhpdUb7KJRXFHPLJ
ulTCkkKCUd9jUMQkUgYzI/C6z4VA0A2EuioFnTIDT+JLzygtzCmVOD/S0Pek CB1lHEKENVVkiydF
CBn9PzIt02P7QhydMCWVNS0EPqcJ0yAVUseg01zL0BtF0xVFJmtDu2KTwPD8 00ENVImA1HfC0/J8
1EidkEm9lislCE01wy/VLDh1GkDFVJfwVIJR0QRNwkst1SENGyT9z1jtz1mV 1YIQVf471VYdiFxt
PSTFTlbV1cTgVRbKzgEw1mNF1mRV1mVl1mZ11mdVViAd1lYNAGi11mvF1mxF X9bllM5u9dZvlU4B
JdVgjS9wNddzRdc5Qtd1ZdfppFAxJVeVktN4JRx4pVeMmtd7/ZZ81VdyG9d+ XTh+BVhKLVBtNdiD
RdiEVdiFZdiGddiHhdiIldiJpdiKtdiLPdiC/w049GzXjvXYjwXZkBXZkSXZ kjXZk0XZlFXZlV3X
f/WYlfDOmJXZmaXZmrXZm8XZnNXZneXZnvXZnwXaoBXa7nTZjRWAoUXapFXa pWXapnXap4XaqJXa
5Czaoi3Oo51a4sTam93arPXarwXbsBXbsfXaqtXY3zwLtPXOrh3OtF1b4WTb 40yPtg2AuCXbu8Xb
vNXbvcVbsxVQtVVbu6XZrRVc7ixculVOvlXcxWXcxnXcnvXbdwXcuqVcwkVb mYDbusXc4LTco8Xa
ze3cy40J0Q1cwI1bzPVczR1d0lVdrV3d1FXdw33c2aXd2rXdmI3cO5zc1A3d yS1d3+3cz/1Oyv8t
3d6tXMuNXeCt3OHtWuQd3sAVXt+93eml3uqt3tz9UdEVXuP13NGFXeLV3t19 Xtj93u5FXa3NXOYF
3+79Trd93uUVX+uV3/mlX8XFXiiV3vJd38x1XvCNX+Il3/1lW7sdYM6F3/X9 XsQ94P6t3wZ24Ad+
2vuN0+hV39/13wU24AzeX/HlXv+lYOXV3woGYA5+X9mF4BNG4RSmWQl2mvwN 3+Q14P4t4PZt3vEF
3dfN4LltXd69YcJdXQT+YPdV4SEm4iLWThYuupk1YcVd4sE14ieG4ihGYrZa 2x++3SauYiyO4i3m
4tudYuLr4jAW4zEmY+H84vAs4zRW4zVO4TOuhln0ZeM4luM55ls3/lzQfVvl ZGAl7mEYjt3m3Vw4
llshTlw6NuRD9lk7JmGd/WEtLuQR3mDpjeT0lVtEtuRLZlpFFuANJmTzLeDo 7eNGbuT4peAapmQA
ft1UnmEa9mHv9eNAxuRYlmVNDt0OjuH3hd9PNl1OfmFI9mAFvuAExmW37WD9 3WNZRmY6pmU8LmZX
luHfTVtQ/mNKBmVYvuBfTl5AtuJVNmYBJuRkBuc4/6Zl/hVhXVbe5e3d7X1k aQ5mYO7m/21nC+Zd
EQ7nep7jcb5leSbnc9bcTR5h5C3lXebnEl7kSebmTbZle1boMsZnG1Zlc8bm fs5mgQ7kO1bliD5d
WCZmi9ZmVzbd8wVoK17oke5iTY5ZR+ZilCbplX5ik95Oa2ZjmGbpmSZjl6bp m8ZpMbbpnObpnibi
nZbkx1XpU5bZofbpo75ejbVaGHbkw0VdmfZZYc5jXL5mog5qpMZq621oqbbZ gB5ao6ZqYBZkDc7q
stZqpT5bhHboT4bpIN5dHObothXleXbfPoZbZj7ejL7o1uVrs/Zrx91qDGbg EB7fHOZgryboGn5n
eMlG6A8m6Hy26r+W7L5F679lan/Oaww2bKpO6AGO5lsOXlY+aMLW4Lju6MlG bb1taH0e7En25XjW
bNgG4Uj2aEGe56Au5sdO7d0W29UWbM52bcQOaOdl5wNG52HmZbU+59xmbN52 bqn17bj2Y32m4elu
ZeDFY9bd4by26Or+aLjm3FLu4Tvu5ec2b6gFau0E665W4vN27zRObz1ebz42 6vl+7/s+a3FNa/zm
7/6W2fj27wAXcOAE8AE3cP4ObMM9aZHW7vC27wOH8Pn/TfCfbW0XvuoIx/Cf rmzJ5WTw3m6+rmux
rvCqzvASb+MN111oZl63tuVV1u3mNvEYh2CTJt/Pvtxydm3cBu4Ll/Eel18a f+1gvu3YDmvGPmYf
R/Kk1m/L/l+pHvIQdmxfLu4HT/IqD1uX1ua3rmav5mjxJm4Gt/Iwp90CF/My t2cyN/M0R2Y0V/M2
t2Q2d/M4v2cUz171juyiVnA513OyXWaZdvGaxWICjuosduxWBvOppvI9f3M6 x18S33GuzfM7Z9pj
PvL2VvSy9m0Qz2681nRD125P7/QG9+66BumKZvBazuyDDnWm9ujxvnSS7vPa 7ubQxmjMnvJ9Jmrm
Pm7qqWZl6NXydC5tWxf2V1fo6LZxdD52UxbsTl5rD7bmuc3t4H129SVu23Zw WRf2Sid2TI5uajZu
g8bxwtX1ES/oJ3d0VIfxZw72cd/2M2f0Cbbw307obC9seiflclduzR5u2qZb t2btcC/yduf2d2/h
a87uXMbhUZ/r7v71F35oLSdlkHboZjdu70121nX1G2d4bRf4Q4bzE070ng35 jl/0JefwKIbqrx15
kvf/eIJPYpaHeSl2eSqO+ZovYjb/c0sPeEQeajDP+cFdeb4NerGGYC2m8lgX dLJ2YqVfcKcOZVPX
aKKX+rvOWZUWd0mf6uRcYrD+Zh7X3q0f66rvzpSH9KmX6LFHe+Q8XeLM9FzH 2Z/PemuXcqYPez4W
+5N+ZK+PdK2386V3dLWPe6BF6aG/Wj3G+71H/N/M9Izf+FS/blTGdlJPeMhX dcQ2eNJ9drhua4GG
/Fd++B1+fLsmZowX8uH+/FDu/FUP8WAHcdB3++/+99bf+La2677O4cln+FCn 69qv95A2bX1v9Qbv
bmtGenqndWlG99+mboAe5oqG57VX9sQObs5P4NYG/3blN/4VT9zOtvV9x/fS 3/fivmwXnnXtH3Z8
d2pch2hnj33E9f7DLuhcRt/oR1tjP9/ivfh//mx232PLBwgBAQYKDFBQAMKC Aw0uXCgQocOGBBM+
ZEhQ4sGLFyFqtEjRIsOMIT8qpFhxo0GSEidCLAnSpcmXDlWybBlxpcyYJ0V2 jFgyYUifKYH+JHqz
40OSClceBBq0ZsqjOYWy1Mgz6dGTU2dyxRi1J0EAAQCQLWsWwAABYs+yTQt2 6VS4Lj2CRGn3KV64
dHvOFSmXKVe9f+fWtIlUK+KtGf++Fcq4IUyqW7NKlQm5MuXBVi97vZoXL1Kv fCVD1vv5KWHDoSMz
1f+ZNXHqulq/Hq4bdixbs2nX5i7r1jbroMH9xpUM+2Zfqcktg5Vtu/ho45eH K76b2PpnwdJjU1+d
Gbno7HuXmuYO/TT6yeRxXme+fj328tOVqyfN0znp2719q8W9/7dgHLHm1HJN +UWgUVYRWBVhQxmI
33NJ/YSRgMzhp5RnDlbnUYUzefbgcxpqSB6CE5I44VChAedUiqjx9dGLhtG0 oIcqeggii1VBFaOE
NcLEIkf0jRgkTTsmKKJPRMLF23/97UfWbzhJOSWVVVpZpWlXarkll116+SWY YXKZpZhlmnkmmmmi
SaaabWrJZG+7+Rcnm26mmaOdeeq5J58U1tknoIGMChrmn4OqCWducj6JVqGG OvoopJFKOimllVrq
KKJtOflklJd6+imooYo6KqmlWpnpWYpy2qiprbr6Kqyxyhoqqrpt2uSsueq6 K6+9+gpmrfwFCyWr
vxp7LLLJKtvnsIw22+my0Uo7LbXVVvnsrXRauy233Xq7K7bYfjsuueWaG2m4 cyZa7LntuvsuvA21
pbsotPHaey++5s67ar79+vsvtfviCjDBBRs8q8DaHrwwww1fmvC6Dks8McXM qqupuBVrvDHHX0Ks
acchizyyvBenmm3EJKu88sQfn8wyzDEX7LKtMtt8s70084czzz2TqzOxPgs9 dMAm25ox0Ukr7SvQ
jC79NNSyNl1v1FVb/bDRwmYd9NVdez3p1Ox+PTbZYoZdNtppu3m22m27DezW zsZN9dt12y0R23fr
vfdYc6MMMt+B1/+dt+CFo0244Yl7jbjijUfNuOORJw255JX3TLnlmcuMuead q8y556F3DLropVNM
uumpM4y66q0TzLrrsecLu+y1w0u77bnr6zfSuvuOb9iLmqWW8MUbfzzyyDvZ 91rMO9889M9LHz31
01tfPfbXa58999t73z3434sfPvnjm18++uernz773xv/98npWikntW61f//6 +eO/v/798/+//wII
wAEKsIDgE8v84Hc03sVNbsl7IAQjuCoCUtCAFqwgBi+owQxycIMeHCC9FKi1 EDbLgRI8IQqTZ78P
srCDLmwhDF8owxjSEIQNVFWTPka8Eaawhz6k0wyDWMMhCrGIRDxBohFBSJYd LpCEDDwLQuLXwB9S
UYUCSSISs4jFLWqxi1ykIJyiKEUnkrEsCRljFdOYQkV5sY1fdCMc3yhHL5pR jDz/zOETl3jGJqqx
jxFc4RwDGcdBCrKQhNRfGPdIrODNSZGLnKIfI9nEQxqykpS8pCUzWUcmmhCP ZawjGiUpyhBispSZ
NCUqTynDRGIsj56EYihHKctWqjKVtqwlLm+JyCWui5HCw+Esgxm0XBJTl8U8 pjGZV0Jg9tKVrxSm
MNmIzGkmk5rWjOMngehMbUITmoCsJjivKc5wxnCZInwkCQegznWyk51qaSc8 4ynPedKznva8ZzuX
N859kpOf/tQfPs/ZSTqZpKAGPShCE6rQhTK0oQjtJ0T/KdGIns+hAmVmW7qp 0Y1ytKMe/ShIQyrS
UW6TLb87qb+yOdKVsrSlLn0paUxjKlMIYnSmNr0pTnOq053ylJY9/SlQgyrU oRJ1jQItKlKTqtSl
MtWjNW0qVKMq1alSFXlPrSpWs6rVrQb1qlz9KljDKtaOenWsZj0rWtMqwbKq ta1ufWta2QrXudK1
rlKVq13zqte98nMUr3z9K2ADK1K/Crawhj2sJAmL2MUytrEPVKxjIyvZyQ6U spa9rGUhi9nNcpau
mu0saENr1t3gs7SmPS1qU6va1bK2ta59LWxjK9vZ0ra2tr0tbnFr0d3ytre+ /S1wgyvc4RK3uMY9
LnKTq9zlMre5yQ0IADs=
------=_NextPart_000_003C_01C612AD.FF5EC180--
Previous Topic:BIRT log files
Next Topic:Configurable Data Sources without binding
Current Time: Sun Aug 31 13:32:11 EDT 2025
Powered by FUDForum. Page generated in 0.03555 seconds
