Home » Eclipse Projects » Remote Application Platform (RAP) » CellEditor in Properties view
CellEditor in Properties view [message #104685] Thu, 11 September 2008 14:56 Go to next message
Originally posted by: felix.mayer.erdas.com
I found that the classes org.eclipse.jface.viewers.CellEditor and
org.eclipse.jface.viewers.DialogCellEditor as well as the method
PropertyDescriptor.createPropertyEditor() do not exist in RAP. This limits
the customization options for the Properties view very much since I cannot
pop up any dialogs. It there a workaround in RAP for this?
Re: CellEditor in Properties view [message #104738 is a reply to message #104685] Fri, 12 September 2008 03:43 Go to previous messageGo to next message
Originally posted by: rherrmann.innoopract.com
Felix,
JFace Cell Editors are planned. They will probably be available in
1.2 M3.
Check back on the plan [1] for updates.
Rüdiger
[1]
http://www.eclipse.org/projects/project-plan.php?projectid=t echnology.rap
Re: CellEditor in Properties view [message #104784 is a reply to message #104738] Fri, 12 September 2008 07:30 Go to previous messageGo to next message
Sorry to hijack this thread but in the light of this plan.
I read there that you want to close the gap between RWT and SWT, do you
also plan to close the gap to e.g. JFace-Databinding where some of the
methods available like SWTObserval#observeDelayed are not available in
RAP? I noticed this when i tried to RAPify my EMF/Teneo/CDO-Databinding
application [1].
Would it e.g. help RAP if those bundles are switched to import-package
instead of require-bundle?
Another related question is how to best setup a project so that it runs
on both platforms. I tried using import-package but failed and now
switched to Require-Bundle but marked the rap/rcp ones as none mandatory.
Tom
[1] http://tom-eclipse-dev.blogspot.com/2008/09/exploring-new-te chnologies-part-of.html
Rüdiger Herrmann schrieb:
> Felix,
> JFace Cell Editors are planned. They will probably be available in 1.2 M3.
> Cheers,
> Rüdiger
> [1]
>> limits the customization options for the Properties view very much
>> since I cannot pop up any dialogs. It there a workaround in RAP for this?
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: CellEditor in Properties view [message #104863 is a reply to message #104784] Mon, 15 September 2008 03:15 Go to previous messageGo to next message
Tom,
please see my comments below.
Rüdiger
Tom Schindl wrote:
> application [1].
We aim to *reduce* the gap between RWT and RWT. Closing it is an
unrealistic goal for 1.2.
The SWTObservables#observeDelayedValue() relies on
Display#timerExec() which is yet missing from RWT. Once timerExec()
is in place it should be an easy task to enable its use in
JFace-Databinding. Implementing timerExec() is currently not on our
plan. Feel free to file an enhancement request and we will try to
squeeze it in if time permits.
Frank is currently working compiling material about RCP/RAP
single-sourcing. We will publish its availability on the common
channels.
> Tom
>> Felix,
>> Cheers,
>> Rüdiger
>> [1]
Re: CellEditor in Properties view [message #104900 is a reply to message #104863] Mon, 15 September 2008 07:56 Go to previous message
> Tom,
> Cheers,
> Rüdiger
> Tom Schindl wrote:
>> application [1].
> The SWTObservables#observeDelayedValue() relies on Display#timerExec()
> which is yet missing from RWT. Once timerExec() is in place it should be
> an easy task to enable its use in JFace-Databinding. Implementing
> timerExec() is currently not on our plan. Feel free to file an
> enhancement request and we will try to squeeze it in if time permits.
Done https://bugs.eclipse.org/bugs/show_bug.cgi?id=247278
> single-sourcing. We will publish its availability on the common channels.
Great.
Tom
Previous Topic:Extension point documentation
Next Topic:DateTime Widget
Current Time: Sun Aug 31 10:30:55 EDT 2025
Powered by FUDForum. Page generated in 0.04311 seconds
