Home » Modeling » GMF (Graphical Modeling Framework) » how do we use editorProviders ext. point?
how do we use editorProviders ext. point? [message #104681] Fri, 16 February 2007 15:36
Originally posted by: NOSPAM.xyz.com
I an trying to plug a simple extension of the generated diagram editor
via org.eclipse.gmf.runtime.common.ui.services.editorProviders.
I extend
org.eclipse.gmf.runtime.common.ui.services.editor.AbstractEd itorProvider
and implement
org.eclipse.gmf.runtime.common.core.service.IProviderPolicy
Is this the right way to contribute to this ext. point?
The documentation is not clear, it just says that the Policy
is required, but there's nothing about who should it subclass.
So, nothing in my provider gets called.
Marian
Previous Topic:Problem in getting the underlying figure
Next Topic:how to execute a dialog from popup bar menu item
Current Time: Mon Jul 21 22:14:29 EDT 2025
Powered by FUDForum. Page generated in 0.02585 seconds
