Home » Archived » M2M (model-to-model transformation) » [ATL] get header from .asm or .atl in Java
[ATL] get header from .asm or .atl in Java [message #104680] Wed, 06 May 2009 10:42 Go to next message
I look for a method from a .asm or .atl to get all infos from header (IN, OUT, metamodel).
I can read a .asm with ASMXMLReader class but I can get only ASMOperation and ASMField.
Thanks.
Re: [ATL] get header from .asm or .atl in Java [message #104742 is a reply to message #104680] Thu, 07 May 2009 05:02 Go to previous messageGo to next message
Esteban DUGUEPEROUX a écrit :
> Thanks.
I found how to get header infos with ATL 2.0/3.0 by looking for in ATL launchConfiguration. It uses AtlParser in ATL 2.0 and AtlSourceManager in ATL 3.0.
But concerning .asm file I don't found solution, I could use ASMXMLReader but which tag value use?
Thanks.
Re: [ATL] get header from .asm or .atl in Java [message #104778 is a reply to message #104742] Thu, 07 May 2009 08:38 Go to previous message
When a .atl file is compiled into a .asm one, it is converted into a
suite of operations.
An .asm file is usually compiled from ATL, but conceptually it could be
compiled from any other language: that's why you will only find the
module name and some operations into it.
So you won't be able to retrieve the complete header from a .asm, the
only inforrmation you can get by anaysis would be the metamodels names.
William
>> Thanks.
> in ATL 3.0.
> Thanks.
Previous Topic:[ATL] What's new in the 3.0.0M7 (2009/05/05) ATL version API?
Next Topic:merging models
Current Time: Sun Aug 31 17:34:59 EDT 2025
Powered by FUDForum. Page generated in 0.03060 seconds
