ERROR- to view the report [message #104667] |
Thu, 05 January 2006 04:36 |
can any body help me ,what is the error is this?
2006-01-05 02:52:35 Message [Extension loading error]
Exception [org.eclipse.birt.report.model.metadata.MetaDataException:
Message:Duplicate extension name when adding the extension [Chart] to the
meta-data dictionary. Error code:DUPLICATE_EXTENSION_NAME
org.eclipse.birt.report.model.metadata.MetaDataDictionary.ad dExtension(MetaDataDictionary.java:749)
org.eclipse.birt.report.model.metadata.PeerExtensionLoader$P eerExtensionElementLoader.loadElement(PeerExtensionLoader.ja va:189)
org.eclipse.birt.report.model.metadata.PeerExtensionLoader.l oadExtension(PeerExtensionLoader.java:74)
org.eclipse.birt.report.model.metadata.ExtensionLoader.doLoa d(ExtensionLoader.java:112)
org.eclipse.birt.report.model.metadata.ExtensionLoader.load( ExtensionLoader.java:63)
org.eclipse.birt.report.model.metadata.ExtensionManager.init ialize(ExtensionManager.java:39)
org.eclipse.birt.report.model.api.DesignEngine.initialize(De signEngine.java:107)
org.eclipse.birt.report.model.api.DesignEngine.newSession(De signEngine.java:148)
org.eclipse.birt.report.engine.parser.ReportParser.parse(Rep ortParser.java:79)
org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDesign(ReportEngineHelper.java:87)
org.eclipse.birt.report.engine.api.ReportEngine.openReportDe sign(ReportEngine.java:216)
at Parameter.getReport(Parameter.java:46)
at Parameter.main(Parameter.java:141)
FUDForum. Page generated in 0.07475 seconds
