Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [CDO][0.8.0] Changing Model
[CDO][0.8.0] Changing Model [message #104666] Sun, 16 December 2007 09:58 Go to next message
Hi Eike,
I would like to know what is the expected behavior of the following.
I have model A.
I generate my code through genmodel.
It creates me Static classes.
I instantiate ModelA... so I have objectA.
Persist it in my Store.
My store will receive the new packages.
Now I stop everything and change my model(I added one attribute). Generate
the code again.
Create a new object and persist it.
It failed (client side) because it doesn`t know what changed.
Should the change be detected and propagate back to the server ?
Thank you
Re: [CDO][0.8.0] Changing Model [message #104730 is a reply to message #104666] Sun, 16 December 2007 11:15 Go to previous messageGo to next message
Originally posted by: stepper.sympedia.de
Hi Simon,
You're talking about what I know under the term "model evolution" and it
is clearly not supported by CDO.
That said, while designing and implementing several persistence systems
over the last 10 years (some of them were orthogonally persistent) I
thought about model evolution many times but always came to the
conclusion that the effort needed to properly (consistently) implement
it is too high for me.
I strongly suggest to regard deployed packages as immutable and the
redeployment of changed packages (under the same URI) as sabotage. I
think it's better to include a version identifier into the package URI
and technically think of the old and the new package as of totally
different packages (which they are in fact). Another solution are
extension packages which use EClass inheritance to add features.
Eike Stepper
http://wiki.eclipse.org/CDO
http://wiki.eclipse.org/Net4j
Simon McDuff schrieb:
> Hi Eike,
> I have model A.
> the code again.
> Thank you
Re: [CDO][0.8.0] Changing Model [message #104743 is a reply to message #104730] Sun, 16 December 2007 11:30 Go to previous messageGo to next message
Thank you Eike,
If the client change the version in the URI... would it be possible for him
to still accessing the data from the old version ?
How CDO framework will behave ?
Is it the responsability of the back-end to migrate the data ?
"Eike Stepper" <stepper@sympedia.de> a
Re: [CDO][0.8.0] Changing Model [message #104751 is a reply to message #104743] Sun, 16 December 2007 11:40 Go to previous message
--------------070806020300070400060002
> Thank you Eike,
Only via the "old" model (URI + generated classes).
From the point of CDO these models don't have a relation. So it should
behave as usual.
I'd say if the back-end pretends to provide model evolution it should
provide means for automatic data migration.
You remember that I explicitely said "CDO does not provide for model
evolution" ;-)
Eike Stepper
Re: [CDO][0.8.0] Changing Model [message #612824 is a reply to message #104666] Sun, 16 December 2007 11:15 Go to previous message
Hi Simon,
Eike Stepper
> Hi Eike,
> I have model A.
> the code again.
> Thank you
Re: [CDO][0.8.0] Changing Model [message #612826 is a reply to message #104730] Sun, 16 December 2007 11:30 Go to previous message
Thank you Eike,
Re: [CDO][0.8.0] Changing Model [message #612829 is a reply to message #104743] Sun, 16 December 2007 11:40 Go to previous message
> Thank you Eike,
behave as usual.
evolution" ;-)
Eike Stepper
Previous Topic:[CDO][0.8.0] Release StoreReader
Next Topic:[cdo][0.8.0]
Current Time: Thu Nov 06 09:46:24 EST 2025
Powered by FUDForum. Page generated in 0.03951 seconds
