Home » Eclipse Projects » GEF » Escape to go to default tool
Escape to go to default tool [message #104650] Wed, 12 November 2003 10:30 Go to next message
When you select a tool from the palette, there is no way to go back to the
default tool (selection tool) unless explicitly selecting it. Should there
be support for the Esc key in tools to go back to the default tool?
Maged
Re: Escape to go to default tool [message #104682 is a reply to message #104650] Wed, 12 November 2003 12:32 Go to previous messageGo to next message
Escape works for me, provided that the graphical viewer has keyboard focus.
"Maged Elaasar" <melaasar@ca.ibm.com> wrote in message
news:botjjq$ghb$1@eclipse.org...
> Hello,
> Maged
Re: Escape to go to default tool [message #104692 is a reply to message #104682] Wed, 12 November 2003 12:44 Go to previous messageGo to next message
Can't it be supported also if the palette viewer has a focus, since the
normal use case would be to select a tool, hover on the graphical viewer and
then pressing Esc to cancel. Currently, the user has to use the "tab" key to
give focus first to the graphical viewer before Esc works. What do you
think?
"Randy Hudson" <none@us.ibm.com> wrote in message
news:botqp3$pub$1@eclipse.org...
focus.
> > Hello,
the
there
> > Maged
Re: Escape to go to default tool [message #104701 is a reply to message #104692] Wed, 12 November 2003 12:53 Go to previous messageGo to next message
You could map a key->action in the palette's keyhandler.
Or, create a ResetToolAction and add it to the keybinding service, so that
ESC is received regardless of focus. But, this would interfere with
celleditors, which need to receive ESC
news:botrep$qpk$1@eclipse.org...
and
to
> think?
> focus.
> > > Hello,
> the
> there
> > > Maged
Re: Escape to go to default tool [message #104723 is a reply to message #104701] Wed, 12 November 2003 14:47 Go to previous messageGo to next message
The first solution seems more reasonable (i.e: let the palette key handler
do it).
Shouldn't that be done in the default PaletteKeyHandler in GEF?
news:botrvv$rgp$1@eclipse.org...
> and
key
> to
> > think?
> > focus.
> > > > Hello,
to
> > the
> > there
> > > > Maged
Re: Escape to go to default tool [message #104733 is a reply to message #104723] Wed, 12 November 2003 16:58 Go to previous message
Sure, why not? Open a bugzilla. For 2.1.x you'll have to add it yourself.
news:bou2lm$3jp$1@eclipse.org...
> do it).
that
the
viewer
> > and
> key
> > to
> > > think?
> > > focus.
> > > > > Hello,
back
> to
> > > the
Should
> > > there
tool?
> > > > > Maged
Previous Topic:How can I remove "run" menu?
Next Topic:Show root TreeEditPart in outline view
Current Time: Tue Jul 08 09:30:40 EDT 2025
Powered by FUDForum. Page generated in 0.05378 seconds
