new style component - code generation with jjet? [message #104492] |
Wed, 31 August 2005 05:06 |
Originally posted by: remus.gmx.org
I'm using eclipse 3.0.2. I want to extend the ve with a new style
component and wrote a plugin with a jjet file, containing the template
code to generate for the new component and a SourceCode Contributor to
deliver the correct path.
My problem now: ve seems to modify the code i deliver through the
contributor. While debugging i see that in
"NewVisualClassCreationWizard.applyContributor" the correct code will
be generated but the result differs a lot. Perhaps
"workingCopy.reconcile(...)" does that but i dont understand how and
why. Is there a way to force ve to use my code?
A very easy example:
The jjet want to generate a comment right above the class. This
comment will never be generated. Instead you will find the default
"created on" and "author" comments.
Any hints?
thanks,
Karsten
FUDForum. Page generated in 0.03742 seconds
