help launching eclipse [message #104388] |
Thu, 31 July 2003 16:15  |
Originally posted by: soni29.hotmail.com
hi,
i'm using eclipse, i believe it's 2.0, can't get it started. it was
working fine with jdk 1.3.1 but i update it today to 1.4.2 and now i keep
getting the following error when i start it:
JVM terminated. Exit code=1
c:\j2sdk1.4.2\bin\javaw.exe
-cp c:\opt\eclipse\startup.jar org.eclipse.core.launcher.Main
-os win32
-ws win32
-arch x86
-showpath c:\opt\eclipse\eclipse.exe -showpath 600
i've trying changing the target for the properties with the shortcut to:
C:\opt\eclipse\eclipse.exe -vm c:\j2sdk1.4.2\bin\javaw.exe
but this results in the same error. i do not have any java.exe or
javaw.exe in my system32 directory, so i'm not sure why this is happening.
i had a similar problem with another pc going from 1.4 to 1.3.1, resolved
that by changing the target property but here it's not working.
Any ideas??
Thank you.
Re: help launching eclipse [message #104413 is a reply to message #104388] |
Thu, 31 July 2003 16:37   |
hi,
i got it to work, just changed to sdk 1.4.1, uninstalled 1.4.2 using
eclipse
Version: 2.1.0
Build id: 200303071024
it works fine, does anyone know which eclipse version support 1.4.2?
Thank you.
soni wrote:
> hi,
> c:j2sdk1.4.2binjavaw.exe
> -cp c:opteclipsestartup.jar org.eclipse.core.launcher.Main
> -os win32
> -ws win32
> -arch x86
> -showpath c:opteclipseeclipse.exe -showpath 600
> C:opteclipseeclipse.exe -vm c:j2sdk1.4.2binjavaw.exe
> Any ideas??
> Thank you.
Re: help launching eclipse [message #106516 is a reply to message #104413] |
Tue, 05 August 2003 04:08  |
Hi Soni,
JSDK 1.4.2 is supported by eclipse 2.1.1 or later.
Ralf
soni schrieb:
> hi,
> eclipse
> Version: 2.1.0
> Thank you.
> soni wrote:
>>hi,
>>-os win32
>>-ws win32
>>-arch x86
>>Any ideas??
>>Thank you.
FUDForum. Page generated in 0.41138 seconds
