CDT2.0M9: Cannot launch CDI debugger [message #104304] |
Wed, 02 June 2004 07:20  |
Originally posted by: holger.casties.siemens.com
I am using CDT2.0M9 with Eclipse3.0M9 under Windows 2000 (with Cygwin).
The following trace appears when starting the debugger:
Failed Launching CDI Debugger
org.eclipse.cdt.debug.core.cdi.CDIException: Unable to set working
directory: mi_cmd_env_cd: Usage DIRECTORY
org.eclipse.cdt.debug.mi.core.cdi.RuntimeOptions.setWorkingD irectory(RuntimeOptions.java:101)
org.eclipse.cdt.launch.internal.LocalCLaunchConfigurationDel egate.launch(LocalCLaunchConfigurationDelegate.java:94)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:569)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:150)
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:796)
org.eclipse.debug.internal.ui.DebugUIPlugin$6.run(DebugUIPlu gin.java:959)
org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
Unable to set working directory: mi_cmd_env_cd: Usage DIRECTORY
What am I doing wrong?
Is there a special configuration necessary for the used GDB?
(-> Unable to set working directory: mi_cmd_env_cd: Usage DIRECTORY)
Best regards
Holger
FUDForum. Page generated in 0.09472 seconds
