"Error trying to set new file into editor" problem [message #104253] |
Tue, 30 August 2005 03:45  |
Hi all,
When I try to open a java class with VE or try to create a new visual
class I get the following error message:
Error trying to set new file into editor.
Reason: java.lang.NullPointerException
Has anyone face something similar?
I use Eclipse SDK 3.1 with the following features:
- JDT 3.1
- EMF 2.1
- GEF 3.1
- JST 0.7
- WST 0.7
- UML2 1.1
- JEM 1.1
- XSD 2.1
- VE 1.1
jfeid
Re: "Error trying to set new file into editor" problem [message #105038 is a reply to message #105032] |
Fri, 02 September 2005 09:02   |
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Thanks, can you please open a defect so that we can track this down with
WST and see what the conflict is?
Also, add in the defect what steps you used to reproduce the problem.
When creating the web project, what options did you choose. when
creating the VE class what options did you choose.
jfeid wrote:
> Rich Kulp wrote:
>> I have no idea. That shouldn't be occuring. Can you try it with a new
>> configuration of just Eclipse, GEF, EMF, and VE, and on a new
>> workspace.? That way we can narrow it down to see if it is VE or
>> something colliding with it.
> Well, it seems to be a collide with the WST feature. I'm working a
> Dynamic Web Project under WST in which a package is a standalone Swing
> application developed with VE. The "Error trying to set new file into
> editor" error message displays only when I try to access java files with
> VE which exists under the Web Project. If I create another standard Java
> Project (in the same workspace) VE works ok. Moreover, the problem is
> reproducible. If I create a new workspace and CVS checkout the Web
> Project or create a new one, behaves similarly.
> jfeid
Rich Kulp
Re: "Error trying to set new file into editor" problem [message #105042 is a reply to message #105038] |
Fri, 02 September 2005 09:58  |
>> with VE which exists under the Web Project. If I create another
>> standard Java Project (in the same workspace) VE works ok. Moreover,
>> the problem is reproducible. If I create a new workspace and CVS
>> checkout the Web Project or create a new one, behaves similarly.
>> jfeid
Ok, bug submitted.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=108671
Re: "Error trying to set new file into editor" problem [message #610455 is a reply to message #104329] |
Wed, 31 August 2005 05:25  |
Rich Kulp wrote:
> Could you please attach the .log file? That will give where the error
> occurred.
Ok, here is the log:
!ENTRY org.eclipse.ve.java.core 4 0 2005-08-31 12:23:09.187
!MESSAGE Exception thrown.
!STACK 0
at org.eclipse.emf.ecore.impl.EClassImpl.getFeatureID(EClassImp l.java:661)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDynamicFeatureI D(BasicEObjectImpl.java:215)
org.eclipse.jem.internal.instantiation.base.JavaObjectInstan ce.eDynamicFeatureID(JavaObjectInstance.java:282)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDynamicGet(Basi cEObjectImpl.java:493)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:488)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:483)
org.eclipse.ve.internal.jfc.core.JLayeredPaneProxyAdapter.ge tCurrentOrder(JLayeredPaneProxyAdapter.java:86)
org.eclipse.ve.internal.jfc.core.JLayeredPaneGraphicalEditPa rt.getModelChildren(JLayeredPaneGraphicalEditPart.java:58)
org.eclipse.gef.editparts.AbstractEditPart.refreshChildren(A bstractEditPart.java:716)
org.eclipse.gef.editparts.AbstractEditPart.refresh(AbstractE ditPart.java:684)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.refresh( AbstractGraphicalEditPart.java:554)
org.eclipse.gef.editparts.AbstractEditPart.addNotify(Abstrac tEditPart.java:232)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.addNotif y(AbstractGraphicalEditPart.java:212)
org.eclipse.gef.editparts.AbstractEditPart.addChild(Abstract EditPart.java:195)
org.eclipse.gef.editparts.AbstractEditPart.refreshChildren(A bstractEditPart.java:734)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.setRootModel(JavaVisualEditorPart.java:506)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.initializeViewers(JavaVisualEditorPart.java:987)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$12.run(JavaVisualEditorPart.java:1977)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3057)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2716)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
!ENTRY org.eclipse.ui 4 4 2005-08-31 12:23:09.234
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2005-08-31 12:23:09.234
!MESSAGE Failed to execute runnable (java.lang.NullPointerException)
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable
at org.eclipse.swt.SWT.error(SWT.java:2942)
at org.eclipse.swt.SWT.error(SWT.java:2865)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:126)
Caused by: java.lang.NullPointerException
... 18 more
Re: "Error trying to set new file into editor" problem [message #610457 is a reply to message #104507] |
Wed, 31 August 2005 10:03  |
That shouldn't be happening. We've fixed a lot of bugs with 1.1.0.1. We
have a release candidate of it available. It is Maintenance build
M20050830.
Try:
1) installing that
2) start with -clean
3) Bring up a VE. If it still fails, then
4) Close the editor
5) Run Project->Clean...->Clean All
6) Wait for the build to finish
7) Try the VE again.
Rich Kulp
Re: "Error trying to set new file into editor" problem [message #610471 is a reply to message #104538] |
Thu, 01 September 2005 05:46  |
> M20050830.
> Try:
> 1) installing that
> 4) Close the editor
Thanx for the response.
1) I've downloaded VE-runtime-M20050830.zip and extracted in eclipse's dir.
2) Launch eclipse with -clean.
3) VE fails again with the same error.
4) Closed the editor->Clean All projects->Wait for build to finish
5) VE fails again with same error.
Here is the new log:
!ENTRY org.eclipse.ve.java.core 4 0 2005-09-01 12:39:10.390
!STACK 0
org.eclipse.emf.ecore.impl.EStructuralFeatureImpl.getSetting Delegate(EStructuralFeatureImpl.java:790)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSettingDelegate (BasicEObjectImpl.java:822)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDynamicIsSet(Ba sicEObjectImpl.java:609)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eIsSet(BasicEObj ectImpl.java:600)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:951)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElementID(XML SaveImpl.java:2272)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElement(XMLSa veImpl.java:889)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveContainedMany (XMLSaveImpl.java:2001)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:1221)
org.eclipse.emf.ecore.xmi.impl.XMISaveImpl.writeTopObjects(X MISaveImpl.java:78)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.traverse(XMLSaveI mpl.java:478)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.save(XMLSaveImpl. java:206)
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doSave(XMLRes ourceImpl.java:193)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:893)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:813)
org.eclipse.ve.internal.java.codegen.util.VEModelCacheUtilit y.doSaveCache(VEModelCacheUtility.java:158)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.doSave(JavaSourceTranslator.java:1357)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or$2.doRun(JavaSourceTranslator.java:922)
org.eclipse.ve.internal.java.codegen.util.ReverseParserJob.r un(ReverseParserJob.java:56)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
!ENTRY org.eclipse.ve.java.core 4 0 2005-09-01 12:39:10.859
!STACK 0
org.eclipse.jem.internal.instantiation.base.JavaInstance.eDy namicFeatureID(JavaInstance.java:281)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.setRootModel(JavaVisualEditorPart.java:505)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.initializeViewers(JavaVisualEditorPart.java:986)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$13.run(JavaVisualEditorPart.java:2001)
!ENTRY org.eclipse.ui 4 4 2005-09-01 12:39:10.906
!ENTRY org.eclipse.ui 4 0 2005-09-01 12:39:10.906
!STACK 0
... 18 more
Re: "Error trying to set new file into editor" problem [message #610476 is a reply to message #104622] |
Thu, 01 September 2005 10:08  |
Rich Kulp
Re: "Error trying to set new file into editor" problem [message #610617 is a reply to message #104654] |
Fri, 02 September 2005 07:39  |
jfeid
Re: "Error trying to set new file into editor" problem [message #610621 is a reply to message #105032] |
> jfeid
Rich Kulp
Re: "Error trying to set new file into editor" problem [message #610624 is a reply to message #105038] |
>> jfeid
Ok, bug submitted.
FUDForum. Page generated in 1.76461 seconds
