Home » Modeling » GMF (Graphical Modeling Framework) » Adding the geoshapes
Adding the geoshapes [message #104227] Thu, 15 February 2007 06:57 Go to next message
Originally posted by: martin.tauber.t-online.de
How do I add the geoshapes to my palette? I tried by adding the plugin
org.eclispe.gmf.diagram.runtime.ui.geoshapes, but they don't show. What
else do I have to do?
Martin
Re: Adding the geoshapes [message #104260 is a reply to message #104227] Thu, 15 February 2007 09:07 Go to previous message
Martin,
The solution is in the online help:
http://help.eclipse.org/help32/topic/org.eclipse.gmf.doc/tut orials/diagram/paletteConfigurationTutorial.html
Take a look at the section titled "Separating the Definition and
Contribution of a Palette Entry"
Having said that, I'm not sure if this will work with the generated code
as the last time I checked the generated code wasn't using the palette
service. You could work around this somehow I am sure if this is the
case. See XXXDiagramEditor.createPaletteRoot() in the generated code to
see what is happening.
Cherie
> Regards
> Martin
Previous Topic:Zoom Problem
Next Topic:How to add more tabs to property window of an eclipse
Current Time: Sun Jul 13 22:42:11 EDT 2025
Powered by FUDForum. Page generated in 0.03157 seconds
