Home » Language IDEs » C / C++ IDE (CDT) » Eclipse debugger implements an external debugger
Eclipse debugger implements an external debugger [message #104016] |
Fri, 28 May 2004 09:43  |
Originally posted by: soranom.ar.ibm.com
I write with a little urgent because a I have to implement a plugin
Debugger that it'll use an external debugger.
And looking for some examples, I found that CDT is closer to my debug
model.
But the only problem is there are so many classes and interfaces that I
can't understand its design model. :(
Could anybody explain me:
1) which are the package or classes or interfaces that implement the
communication between the plugin and the external debugger?
2) how do you implement, i.e. the interaction with Variable view?
Thanks a lot for your help!
María de los Angeles Sorano
Re: Eclipse debugger implements an external debugger [message #104032 is a reply to message #104016] |
Fri, 28 May 2004 11:35   |
Originally posted by: mikhailk.qnx.com
Please, see my comments inline.
"Angeles Sorano" <soranom@ar.ibm.com> wrote in message
news:c97fml$he$1@eclipse.org...
> Hello,
> model.
To integrate a C/C++ debugger into CDT you can you should implement the
so-called CDI interface. It's in the "org.eclipse.cdt.debug.core.cdi",
"org.eclipse.cdt.debug.core.cdi.event",
"org.eclipse.cdt.debug.core.cdi.model" and
"org.eclipse.cdt.debug.core.cdi.model.type" packeges of the
"org.eclipse.cdt.debug.core' plugin.
You also have to extend the "org.eclipse.cdt.debug.core.CDebugger" extension
point.
You can use as an example the "org.eclipse.cdt.debug.mi.core" plugin which
is a debugger implementation based on gdb.
The Eclipse platform provides a group of interfaces that you need to
implement to interact with the generic views. The CDT implements these
interfaces, so if you provide the implementation of CDI, you will get the
interaction with all views automatically. And, of course, you can extend the
behavior by contributing your own actions.
> Mar
Re: Eclipse debugger implements an external debugger [message #105493 is a reply to message #104032] |
Tue, 08 June 2004 14:31   |
Thanks Mikhail for anwser me.
I have one more question: do you know how is the communication between
Eclipse and the external debugger??...by JNI, sockets??
Thanks!!!!
Angeles
> > Hello,
> > model.
> point.
Re: Eclipse debugger implements an external debugger [message #105506 is a reply to message #105493] |
Tue, 08 June 2004 17:27   |
The CDI implementation provided by CDT is based on the GDB/MI interface. It
sends gdb commands directly to the gdb input and reads the gdb output.
But there are implementations that use JNI to communicate directly to OS and
libraries..
news:ca50lj$h9$1@eclipse.org...
> Thanks!!!!
> Angeles
> > > Hello,
> > > model.
I
extension
> > point.
which
the
the
> > > Mar
Re: Eclipse debugger implements an external debugger [message #105538 is a reply to message #105506] |
Wed, 09 June 2004 08:35   |
Ok,
do you have any material/documents thats explain GDB/MI interface?
Because there are so many classes and interfaces that i cannot understand
the model.
I'd like to know if MI architecture is the correct model that I have to
use.
Thanks!
Angeles
> libraries..
> > Thanks!!!!
> > Angeles
> > > > Hello,
> > > > model.
> I
> extension
> > > point.
> which
> the
> the
Re: Eclipse debugger implements an external debugger [message #105549 is a reply to message #105538] |
Wed, 09 June 2004 10:27   |
http://sources.redhat.com/gdb/current/onlinedocs/gdb_25.html #SEC215
news:ca706v$4vi$1@eclipse.org...
> Ok,
> the model.
> use.
> Thanks!
> Angeles
It
and
> > libraries..
> > > Thanks!!!!
> > > Angeles
> > > > > Hello,
plugin
debug
> > > > > model.
that
> > I
the
the
> > extension
> > > > point.
> > which
these
get
> > the
extend
> > the
> > > > > Mar
Re: Eclipse debugger implements an external debugger [message #106497 is a reply to message #104016] |
Wed, 16 June 2004 11:31  |
I wonder if you know if the Windows Toolkit Debuger (WinDgb)
can be used as an External Debugger.
Here's a link to it:
http://www.microsoft.com/whdc/devtools/debugging/default.msp x
On Fri, 28 May 2004 13:43:49 +0000 (UTC), soranom@ar.ibm.com (Angeles
Sorano) wrote:
>Hello,
>model.
Current Time: Sun Aug 31 21:04:56 EDT 2025
Powered by FUDForum. Page generated in 0.04382 seconds
