Home » Eclipse Projects » GEF » DirectedGraphLayout
DirectedGraphLayout [message #103957] Fri, 07 November 2003 06:53 Go to next message
I am using a DirectedGraphLayout to add components that have multiple anchor
points. Is it possible to order the components providing the inputs so that
they have the same order as the anchor points. At present I am getting a
large number of crossed connections.
Thanks for any help,
John.
Re: DirectedGraphLayout [message #104082 is a reply to message #103957] Fri, 07 November 2003 13:32 Go to previous messageGo to next message
I've tried changing the values of weight, offsetTarget and sourceTarget, but
none of these changes have the desired effect. The question I have is is
this the right approach or is there something else I should be looking at.
John.
"John Howard" <john.howard9@btinternet.com> wrote in message
news:bog117$ff8$1@eclipse.org...
anchor
that
> John.
Re: DirectedGraphLayout [message #104094 is a reply to message #103957] Fri, 07 November 2003 14:29 Go to previous messageGo to next message
Can you not re-position the anchor points to match the nodes? The point of
graph layout is to arrange the nodes in the "best" way possible. But what
you're saying is the anchors themselves determine the node ordering. So do
you need to skip the minCross step?
Can you post a picture of your graph? For 3.0 we are adding constraints to
nodes, but currently I've done this by defining an overall ordering of a
subset of the nodes.
anchor
that
> John.
Re: DirectedGraphLayout [message #104131 is a reply to message #104094] Fri, 07 November 2003 16:04 Go to previous messageGo to next message
Attached is a fairly extreme example of the problem normally there would
only be 2 or 3 anchor points. The left hand side is not a problem as we can
handle this by duplicating the attribute nodes, it is the right hand side
that is the issue. The graphs are all relatively simple and it would be
good if we could use the GraphLayout as it saves us having to write our own
algorithm. I'd prefer to not have to re-order the inputs as I suspect the
user would expect them to be in a fixed order. There are ceratin attributes
of the Edges that look that they might be appropriate, just not sure how to
use them. What is the layout policy if we skip the minCross step?
John.
"Randy Hudson" <none@us.ibm.com> wrote in message
news:bogroe$g8c$1@eclipse.org...
of
do
to
> > Hi,
> anchor
> that
a
> > John.
Re: DirectedGraphLayout [message #104229 is a reply to message #104131] Sat, 08 November 2003 20:56 Go to previous messageGo to next message
I think you can get good enough results with a simple "peephole"
optimization that runs after MinCross. Look at the class LocalOptimizer.
This class swaps two adjacent nodes if doing so reduces the number of
crossings. You can do the same thing, except you have customize the
shouldSwap(node, node) method for your own purposes.
In order to replace the LocalOptimizer with your own, you'll have to use
internal API. If you create something based off LocalOptimzer, please
submit it to us in a bugzilla so we can consider releasing it. Thanks!
news:boh1a3$m02$1@eclipse.org...
can
own
attributes
to
> John.
> of
what
> do
> to
> > > Hi,
> > anchor
so
> > that
getting
> a
> > > John.
Re: DirectedGraphLayout [message #104476 is a reply to message #104229] Tue, 11 November 2003 09:27 Go to previous message
Thanks, I will take a look at it. At present I have implemented a
workaround, but it is not very elegant and what you are suggesting makes a
lot more sense. If I come up with something useful, I'll submit it.
John.
news:bok6pg$6fu$1@eclipse.org...
> can
side
> own
the
> attributes
> to
> > Thanks,
> > John.
point
> > of
> what
So
> > do
constraints
> > to
a
> > > > Hi,
multiple
> > > anchor
> so
> > > that
> getting
> > a
> > > > John.
Previous Topic:Connecting connections to connections ...
Next Topic:Deleting compound connections
Current Time: Mon Jul 14 23:59:43 EDT 2025
Powered by FUDForum. Page generated in 0.10367 seconds
