Home » Archived » M2M (model-to-model transformation) » UML2 state machines : Transition transformation
UML2 state machines : Transition transformation [message #103691] Fri, 17 April 2009 04:41
I am working on transforming state machines defined by UML2.ecore
metamodel.I have no problem to manipulate states and transitions. The
problem occurs in the following helper testing if a transition outgoing
from a state is alone:
helper context UML!Transition def: isAlone() : Boolean =
let srce : self.source in srce.outgoing->size = 1 ;
or
self.source.outgoing->size = 1 ;
I tried with a cast : let srce : self.source in
srce.outgoing->asSet()->size()=1
Result is always false.
Thanks for your help!
Anne-Lise
Previous Topic:[ATL]
Next Topic:Headless configurations
Current Time: Fri Jul 18 03:32:20 EDT 2025
Powered by FUDForum. Page generated in 0.08908 seconds
