Home » Archived » Maven Integration (M2E) » m2eclipse will require Java 5 to run
m2eclipse will require Java 5 to run [message #9443] Fri, 23 May 2008 13:43 Go to next message
Hi all,
Please note that due to dependencies on several components that
require Java 5 (one of them is the Maven core, that been recently moved
to Java 5), starting from 0.9.4 version, m2eclipse will require Java 5
to run.
We are also considering to reduce support of Eclipse 3.2, mostly due
to the limited testing resources and also because of new dependencies on
WTP/XML components used for POM editor.
Please let us know if you have comments or opinions on those issues.
Eugene
Re: m2eclipse will require Java 5 to run [message #9491 is a reply to message #9443] Fri, 23 May 2008 18:11 Go to previous message
Hi Eugene,
congratulations to this, by some considered a bold move. My opinion is covered in my blog:
http://thhal.blogspot.com/2008/05/transition-agony.html
Buckminster made the same decision a while back.
Thomas Hallgren
Eugene Kuleshov wrote:
> Hi all,
> Please note that due to dependencies on several components that require
> Java 5 (one of them is the Maven core, that been recently moved to Java
> 5), starting from 0.9.4 version, m2eclipse will require Java 5 to run.
> We are also considering to reduce support of Eclipse 3.2, mostly due to
> Thanks
> Eugene
Previous Topic:global Maven settings.xml
Next Topic:IP Process
Current Time: Mon Jul 14 06:28:08 EDT 2025
Powered by FUDForum. Page generated in 0.02965 seconds
