Home » Archived » BIRT » 2.0 Candidate Release
2.0 Candidate Release [message #103583] Tue, 03 January 2006 10:47 Go to next message
Originally posted by: mlorenz.nc.rr.com
Any prognosis when the 2.0 Cand Rel will be available?
Thanks, Mark
Re: 2.0 Candidate Release [message #104074 is a reply to message #103583] Wed, 04 January 2006 12:19 Go to previous messageGo to next message
Mark,
This is available now.
Jason
"Mark Lorenz" <mlorenz@nc.rr.com> wrote in message
news:e375552977cdf61770b3afa9c7006e83$1@www.eclipse.org...
> Thanks, Mark
Re: 2.0 Candidate Release [message #104144 is a reply to message #104074] Wed, 04 January 2006 12:42 Go to previous messageGo to next message
Hi jason,
RC is not working in eclipse-3.2-M4. I know the reference platform is
3.1 but M3 had no problems with 3.2-M4 where as if you install birt on
3.2-M4 eclipse even refuses to start. Should i file a bug for this?
Tom
Jason Weathersby wrote:
> Mark,
> Jason
>>Thanks, Mark
Re: 2.0 Candidate Release [message #104168 is a reply to message #104144] Wed, 04 January 2006 13:09 Go to previous messageGo to next message
Just for reference that's the exception thrown in eclipse-3.2-M4:
-----------------8<-----------------
!ENTRY org.eclipse.ui 4 0 2006-01-04 15:46:17.640
!MESSAGE The action set must reference at least one menu element
!STACK 0
java.lang.IllegalArgumentException: The action set must reference at
at org.eclipse.jface.menus.SActionSet.define(SActionSet.java:11 3)
org.eclipse.ui.internal.menus.LegacyActionPersistence.readAc tionSets(LegacyActionPersistence.java:858)
org.eclipse.ui.internal.menus.LegacyActionPersistence.read(L egacyActionPersistence.java:1553)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1041)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1695)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:397)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:106)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:109)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:379)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:338 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:282)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Although I think that this is on the one hand side a bug of
eclipse-platform maybe there's also something wrong in one of your plugins.
Tom
Tom Schindl wrote:
> Hi jason,
> Tom
>>Mark,
>>Jason
>>>Thanks, Mark
Re: 2.0 Candidate Release [message #104208 is a reply to message #104168] Wed, 04 January 2006 13:55 Go to previous message
Tom,
Please file a bug.
Jason
"Tom Schindl" <tom.schindl@bestsolution.at> wrote in message
news:dph32a$loo$1@utils.eclipse.org...
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> plugins.
> Tom
> Tom Schindl wrote:
>> Hi jason,
>> Tom
>>>Mark,
>>>Jason
>>>>Thanks, Mark
Previous Topic:CSV export in BIRT 2.0RC
Next Topic:Is it possible to set DataSource Connection parameters at runtime?
Current Time: Thu Jul 17 16:15:25 EDT 2025
Powered by FUDForum. Page generated in 0.09559 seconds
