Home » Eclipse Projects » Remote Application Platform (RAP) » How to getRealPath?
How to getRealPath? [message #103516] |
Fri, 29 August 2008 10:30  |
my actual question is how to resolve
ServletContext#getRealPath("/something")?
It returns null if I call
ServletContext sc = RWT.getRequest().getSession().getServletContext();
System.out.println("sc.getRealPath " + sc.getRealPath("/BIRTImages"));
what is solution here?
Nikolai
Re: How to getRealPath? [message #103884 is a reply to message #103812] |
Tue, 02 September 2008 04:14   |
Hi Rüdiger,
thank you for the answer.
I tryed 2 ways, but the code is the same (starting my RAP-App):
public int createUI() {
System.out.println("ContextProvider.getWebAppBase() " +
ContextProvider.getWebAppBase());
System.out.println("sc.getRealPath(\"/\") " + sc.getRealPath("/"));
... my app code
1. Printout Running from eclipse:
ContextProvider.getWebAppBase() C:\Programme\Eclipse\eclipse 3.4
canymede\workspace\.metadata\.plugins\org.eclipse.rap.ui\con text
sc.getRealPath("/") null
2. Printout Running on tomcat:
C:\Projekte\Servers\apache-tomcat-6.0.16\apache-tomcat-6.0.1 6\work\Catalina\localhost\myApp\eclipse\workspace\.metadata\ .plugins\org.eclipse.rap.ui\context
sc.getRealPath("/")
C:\Projekte\Servers\apache-tomcat-6.0.16\apache-tomcat-6.0.1 6\webapps\myApp\
I see, that on tomcat getWebAppBase and getRealPath give me differenced
"working paths". I think, that getRealPath in Eclipse return null, because
webapp-folder does not exist, but only working-folder. And for my work
(I'm trying to integrate BIRT-Reporting in my RAP-Application), I want to
save session dependent report (chart-)images in working directory and
delete it if session ends. How can I do that, without
ContextProvider.getWebAppBase()?
Nikolai
Rüdiger Herrmann wrote:
> Nikolai,
> the return value of getWebAppBase() itself is based on
> ServleContext.getRealPath( "/" );. Not sure what goes wrong. Did you
> try both appraoches in the exact same environment?
> The JavaDoc for getRealPath says:
> [...] This method returns null if the servlet container
> cannot translate the virtual path to a real path for any
> reason (such as when the content is being made available
> from a .war archive)
> HTH
> Rüdiger
> Nikolai wrote:
>> I found ContextProvider#getWebAppBase() in package
>> org.eclipse.ui.internal.service, bundle org.eclipse.ui.workbench.
>> This give me the real path of the webapp context. But it is an INTERNAL
>> class, if I call it, i "break" the access restriction...
>> knows someone an alternative?
>> regards,
>> Nikolai
Re: How to getRealPath? [message #103925 is a reply to message #103884] |
Tue, 02 September 2008 09:46   |
Originally posted by: fappel.innoopract.com
here is just an alternative idea that may work in your case. You could
use the statelocation of a bundle to save the reports to disk. Here is
an example to get the statelocation of the org.eclipse.rap.ui bundle:
Bundle bundle = Platform.getBundle( PlatformUI.PLUGIN_ID );
IPath stateLocation = Platform.getStateLocation( bundle );
To create the path to a session unique folder you could use
IPath sessionLocation = stateLocation.append(
RWT.getSessionStore().getId() );
and afterwards create that folder on disk. You can use a
SessionStoreListener to remove the folder and its content from disk on
session timeout.
To show the chart on the client you can use the browser widget that
requests the chart to show by addressing a IServiceHandler. The
servicehandler reads the file from disk and delivers it to the
requesting browser widget. There should be several threads in this
newsgroup for more detail on how servicehandlers are used.
Surely there may be several downside on this approach, but if it fits or
not depends on your needs...
Ciao
Frank
-----Ursprüngliche Nachricht-----
Von: Nikolai [mailto:nikolai.raitsev@gmail.com]
Bereitgestellt: Dienstag, 2. September 2008 10:15
Bereitgestellt in: eclipse.technology.rap
Unterhaltung: How to getRealPath?
Betreff: Re: How to getRealPath?
Hi Rüdiger,
... my app code
ina\localhost\myApp\eclipse\workspace\.metadata\.plugins\org .eclipse.rap
..ui\context
sc.getRealPath("/")
App\
because
to
Nikolai
> Nikolai,
> HTH
> Rüdiger
> Nikolai wrote:
INTERNAL
>> regards,
>> Nikolai
Re: How to getRealPath? [message #103967 is a reply to message #103925] |
Tue, 02 September 2008 15:55  |
Hi Frank,
thank you for the tipp, I will test it, but I dont know whether
IServiceHandler is suitable way for me (now). At the moment I generate
Reports to ByteArrayOutputStream, convert it to String, and set it to
browser-widget with setText and it works in RCP and in RAP. I think, if
the reports become larger, I get a problem with, but now my focus is on
the BIRT integration in RCP an RAP, its unfortunately unstable on my
environment (I get sometimes unexplainable ClassNotFoundErrors:
http://www.eclipse.org/newsportal/article.php?id=4195&gr oup=eclipse.technology.rap#4195)...
Gruß,
Nikolai
Frank Appel wrote:
> session timeout.
> Ciao
> Frank
Current Time: Sat Jul 19 11:37:08 EDT 2025
Powered by FUDForum. Page generated in 0.25205 seconds
