Home » Language IDEs » Java Development Tools (JDT) » Installing Eclipse
Installing Eclipse [message #103439] Sun, 12 October 2003 15:13 Go to next message
Originally posted by: jgold03.swbell.net
I am a newbie who is having trouble getting Eclipse to run. I am using
Red Hat 9.0. I downloaded the most recent Java SDK and JRE rpms, and ran
them. I then downloaded eclipse, and extracted the folder into my home
directory. I then ran eclipse, and I got the following error:
A Java Runtime Environment (JRE) or Java Development Kit (JDK)
must be available in order to run Eclipse. No Java virtual machine
was found after searching the following locations:
/root/eclipse/jre/bin/java
'java' in your current PATH
However, when I run this command:
# echo $PATH
/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin :/usr/X11R6/bin:/root/bin:/usr/java/j2sdk1.5.1_05/bin:/usr/j ava/j2re1.4.2_01/bin
Any ideas?
Re: Installing Eclipse [message #103453 is a reply to message #103439] Sun, 12 October 2003 15:55 Go to previous messageGo to next message
> # echo $PATH
> Any ideas?
Try to setup the JAVA_HOME variable in your .bashrc like:
export JAVA_HOME=/usr/java/j2sdk1.5.1_05
export PATH=$JAVA_HOME/bin:$PATH
/jens
P.S. Try to look at the other redhat/Eclipse thread in the SWT newsgroup
Re: Installing Eclipse [message #103467 is a reply to message #103453] Sun, 12 October 2003 16:23 Go to previous messageGo to next message
> > # echo $PATH
> > Any ideas?
> /jens
Another question, since you know what you are talking about. When I set
my $PATH variable and then restarted, the $PATH variable was reset. How
to I make it permanent?
Re: Installing Eclipse [message #103480 is a reply to message #103467] Sun, 12 October 2003 16:30 Go to previous messageGo to next message
>>># echo $PATH
>>>Any ideas?
>>/jens
You should open the .bashrc file in your home folder and add:
then save the .bashrc file. Then you type the following in your terminal.
.. .bashrc
next time you login or open a terminal the JAVA_HOME and PATH should be
set permanent.
Jens ;-)
Re: Installing Eclipse [message #103491 is a reply to message #103480] Sun, 12 October 2003 17:45 Go to previous messageGo to next message
> >>># echo $PATH
> >>>Any ideas?
> >>/jens
> .. .bashrc
> set permanent.
> Jens ;-)
ok I added the stuff to my .bashrc file, but when i go to the terminal and
type in:
#.. .bashrc
- or -
# .bashrc
It says command not found.
Re: Installing Eclipse [message #103505 is a reply to message #103491] Sun, 12 October 2003 17:48 Go to previous messageGo to next message
>>>>># echo $PATH
>>>>>Any ideas?
>>>>/jens
>>.. .bashrc
>>set permanent.
>>Regards,
>>Jens ;-)
> type in:
> #.. .bashrc
> - or -
> # .bashrc
you must type . .bashrc [dot space dotbashrc]
Re: Installing Eclipse [message #103524 is a reply to message #103491] Sun, 12 October 2003 18:13 Go to previous messageGo to next message
ran
> > >>># echo $PATH
> > >>>Any ideas?
> > >>/jens
> > .. .bashrc
> > set permanent.
> > Regards,
> > Jens ;-)
> type in:
> #.. .bashrc
> - or -
> # .bashrc
Also, even when I set my temp env variables to work for java, i still
can't run eclipse... I get the same error.
Re: Installing Eclipse [message #103536 is a reply to message #103524] Sun, 12 October 2003 18:16 Go to previous messageGo to next message
> ran
>>>>>># echo $PATH
>>>>>>Any ideas?
>>>>>/jens
>>>.. .bashrc
>>>set permanent.
>>>Regards,
>>>Jens ;-)
>>type in:
>>#.. .bashrc
>>- or -
>># .bashrc
What if you type:
java
in your konsole - does it work?
Re: Installing Eclipse [message #103551 is a reply to message #103536] Sun, 12 October 2003 18:20 Go to previous messageGo to next message
> > ran
> >>>>>># echo $PATH
> >>>>>>Any ideas?
> >>>>>/jens
> >>>.. .bashrc
> >>>set permanent.
> >>>Regards,
> >>>Jens ;-)
> >>type in:
> >>#.. .bashrc
> >>- or -
> >># .bashrc
> What if you type:
> java
yes
Re: Installing Eclipse [message #103562 is a reply to message #103551] Sun, 12 October 2003 18:22 Go to previous messageGo to next message
using
> > > ran
home
> > >>>>>># echo $PATH
> > >>>>>>Any ideas?
> > >>>>>/jens
newsgroup
set
How
terminal.
> > >>>.. .bashrc
> > >>>set permanent.
> > >>>Regards,
> > >>>Jens ;-)
and
> > >>type in:
> > >>#.. .bashrc
> > >>- or -
> > >># .bashrc
> > What if you type:
> > java
> yes
OK, when i
# ./eclipse
It opens eclipse
but when I try and use a launcher I get the error
Re: Installing Eclipse [message #103577 is a reply to message #103551] Sun, 12 October 2003 18:26 Go to previous messageGo to next message
>>>ran
>>>>>>>># echo $PATH
>>>>>>>>Any ideas?
>>>>>>>/jens
>>>>>.. .bashrc
>>>>>set permanent.
>>>>>Regards,
>>>>>Jens ;-)
>>>>type in:
>>>>#.. .bashrc
>>>>- or -
>>>># .bashrc
>>What if you type:
>>java
> yes
Hmmmmm. Try starting eclipse by typing:
../path/to/your/eclipse-folder/eclipse -vm /path/to/your/j2sdk/bin
Re: Installing Eclipse [message #103588 is a reply to message #103562] Sun, 12 October 2003 18:29 Go to previous messageGo to next message
> using
>>>>ran
> home
>>>>>>>>># echo $PATH
>>>>>>>>>Any ideas?
>>>>>>>>/jens
> newsgroup
> set
> How
> terminal.
>>>>>>.. .bashrc
>>>>>>set permanent.
>>>>>>Regards,
>>>>>>Jens ;-)
> and
>>>>>type in:
>>>>>#.. .bashrc
>>>>>- or -
>>>>># .bashrc
>>>What if you type:
>>>java
>>yes
> OK, when i
> # ./eclipse
> It opens eclipse
What error - what does it say? By the way - you should try starting
eclipse by typing ./path/to/your/eclipe/eclipse -vm
/path/to/your/j2sdk/bin/java. Is you pointing to your JRE or SDK?
Re: Installing Eclipse [message #103601 is a reply to message #103588] Sun, 12 October 2003 18:34 Go to previous messageGo to next message
> > using
and
> >>>>ran
> > home
> >>>>>>>>># echo $PATH
> >>>>>>>>>Any ideas?
> >>>>>>>>/jens
> > newsgroup
> > set
> > How
> > terminal.
> >>>>>>.. .bashrc
be
> >>>>>>set permanent.
> >>>>>>Regards,
> >>>>>>Jens ;-)
> > and
> >>>>>type in:
> >>>>>#.. .bashrc
> >>>>>- or -
> >>>>># .bashrc
> >>>What if you type:
> >>>java
> >>yes
> > OK, when i
> > # ./eclipse
> > It opens eclipse
Well, I restarted and now it works. Thanks :)
Re: Installing Eclipse [message #103612 is a reply to message #103601] Sun, 12 October 2003 18:37 Go to previous messageGo to next message
>>>using
> and
>>>>>>ran
>>>home
>>>>>>>>>>># echo $PATH
>>>>>>>>>>>Any ideas?
>>>>>>>>>>/jens
>>>newsgroup
>>>set
>>>How
>>>terminal.
>>>>>>>>.. .bashrc
> be
>>>>>>>>set permanent.
>>>>>>>>Regards,
>>>>>>>>Jens ;-)
>>>and
>>>>>>>type in:
>>>>>>>#.. .bashrc
>>>>>>>- or -
>>>>>>># .bashrc
>>>>>What if you type:
>>>>>java
>>>>yes
>>>OK, when i
>>># ./eclipse
>>>It opens eclipse
You are welcome - happy hacking :-)
Jens
Re: Installing Eclipse [message #103626 is a reply to message #103612] Sun, 12 October 2003 18:53 Go to previous messageGo to next message
Originally posted by: muelleimer.usenet.katzien.de
Hallo!
Just for this onliner you needed to quote *two* *hundred* lines of
other stuff, which wasn't relevant *at all* for the reply. I've no
idea, how you read news, but on my terminal, I needed lots of
scrolling to get to the point, just to discover, that nothing
essential was added. Thats *very* annoying!
Guys, whatever you do next, please *first* read http://learn.to/quote/
Jan, seriously pissed.
Re: Installing Eclipse [message #103639 is a reply to message #103626] Sun, 12 October 2003 19:07 Go to previous messageGo to next message
Then I'm very glad that you didn't read the xdoclet thread above ;-)
Thanks for letting me know :-)
Jens, very happy
Re: Installing Eclipse [message #106735 is a reply to message #103639] Thu, 16 October 2003 16:24 Go to previous message
Yes, guilty as charged. It's been a while since I posted, and in the
interim I became a Usenet heathen. The first step is admitting I have a
problem... :)
Derek
> Jens, very happy
Previous Topic:Extension point for "Show Logical Structure" in Debug Variables view
Next Topic:sticky bootclasspath
Current Time: Sun Aug 31 23:28:26 EDT 2025
Powered by FUDForum. Page generated in 0.05765 seconds
