stop parsing a method [message #103249] |
Wed, 24 August 2005 07:49  |
Originally posted by: eldzino.gmail.com
hello,
is there any way to stop VE from parsing certain method in a class? i
have a visual class where a long method is called within initialization.
this method sets labels on certain conditions.. VE hangs with message:
An internal error occured during: "Setup Java Visual Editor"
If I comment the block of code in the method, everything is ok, but I
can't do it everytime I want to modify the appearance...
This is the log generated:
!SESSION 2005-08-24 13:44:22.504
eclipse.buildId=I20050627-1435
java.version=1.5.0_03
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=sk_SK
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.core.runtime 4 2 2005-08-24 13:45:28.719
!MESSAGE An internal error occurred during: "Setup Java Visual Editor".
!STACK 0
java.lang.StackOverflowError
at java.lang.String.valueOf(Unknown Source)
org.eclipse.ve.internal.java.codegen.model.BeanPartDeclerati on.createDeclerationHandle(BeanPartDecleration.java:273)
org.eclipse.ve.internal.java.codegen.model.BeanPartDeclerati on.createDeclerationHandle(BeanPartDecleration.java:283)
org.eclipse.ve.internal.java.codegen.util.CodeGenUtil.getBea nPart(CodeGenUtil.java:931)
org.eclipse.ve.internal.java.codegen.java.ConstructorDecoder Helper$CGResolver.resolveToBean(ConstructorDecoderHelper.jav a:222)
org.eclipse.ve.internal.java.codegen.java.ConstructorDecoder Helper$CGResolver.resolveName(ConstructorDecoderHelper.java: 173)
org.eclipse.jem.workbench.utility.ParseTreeCreationFromAST.v isit(ParseTreeCreationFromAST.java:518)
Re: stop parsing a method [message #105685 is a reply to message #103376] |
Thu, 08 September 2005 04:48  |
I installed new version of VE 1.1.0.1 and the problem is gone. thankx :)
eldzi wrote:
> if you want I can provide the whole class but it is much longer :))
> the block of code:
> private void setItemTypeInfos(DefaultMutableTreeNode node) {
> if(node == null) {
> labelItemDescription.setText("");
> labelPriceForUnit.setText("");
> labelTaxRate.setText("");
> labelUnit.setText("");
> labelQuantity.setText("");
> labelPrice.setText("");
> labelPriceWithoutTax.setText("");
> labelPriceWithTax.setText("");
> labelDiscount.setText("");
> labelTax.setText("");
> panelDivider.setVisible(false);
> // panelDivider2.setVisible(false);
> labelLabelQuantity.setVisible(false);
> labelLabelPriceForUnit.setVisible(false);
> labelLabelDiscount.setVisible(false);
> labelLabelPrice.setVisible(false);
> labelLabelPriceWithoutTax.setVisible(false);
> labelLabelTax.setVisible(false);
> labelLabelPriceWithTax.setVisible(false);
> labelMultiply.setVisible(false);
> labelEqual.setVisible(false);
> return;
> DBItem itemType = (DBItem) node.getUserObject();
> labelItemDescription.setText(itemType.getItemTypeCaption());
> DecimalFormat s = (DecimalFormat) DecimalFormat.getCurrencyInstance();
> s.setMaximumFractionDigits(2);
> s.setMinimumFractionDigits(2);
> labelPriceForUnit.setText(s.format(CalcNumberFormatter.round (itemType
> .getPriceForUnit()))
> s = (DecimalFormat) DecimalFormat.getPercentInstance();
> s.setMaximumFractionDigits(0);
> s.setMinimumFractionDigits(0);
> labelTaxRate.setText("(" + s.format((double) itemType.getTaxRate() /
> 100) + ")");
> labelUnit.setText(itemType.getItemType().getUnit());
> labelQuantity.setText(new Integer(itemType.getQuantity()).toString());
> double y = itemType.getPriceForUnit();
> double price = CalcNumberFormatter.round(itemType.getQuantity() * y);
> Double c = new Double(price);
> labelPriceWithoutTax.setText(s.format(CalcNumberFormatter.ro und(c)));
> labelDiscount.setText(s.format(CalcNumberFormatter.round(ite mType.getDiscount())));
> price -= itemType.getDiscount();
> labelPrice.setText(s.format(CalcNumberFormatter.round(c)));
> y = price * itemType.getTaxRate() / 100;
> double tax = CalcNumberFormatter.round(y);
> c = new Double(tax);
> labelTax.setText(s.format(CalcNumberFormatter.round(c)));
> price += tax;
> labelPriceWithTax.setText(s.format(CalcNumberFormatter.round (c)));
> panelDivider.setVisible(true);
> // panelDivider2.setVisible(true);
> labelLabelQuantity.setVisible(true);
> labelLabelPriceForUnit.setVisible(true);
> labelLabelDiscount.setVisible(true);
> labelLabelPrice.setVisible(true);
> labelLabelPriceWithoutTax.setVisible(true);
> labelLabelTax.setVisible(true);
> labelLabelPriceWithTax.setVisible(true);
> labelMultiply.setVisible(true);
> labelEqual.setVisible(true);
> Sri Gunturi wrote:
>>Hello,
>> Could you please paste the block of code which is causing a hang -
>>we would like to make sure this doesnt happen.
>>Regards,
>>Sri.
>>eldzi wrote:
>>>hello,
>>>Thanks :)
>>>!STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
Re: stop parsing a method [message #610368 is a reply to message #103249] |
Wed, 24 August 2005 10:08  |
Could you please paste the block of code which is causing a hang - we
Sri.
eldzi wrote:
> hello,
> Thanks :)
> !STACK 0
> at
> at
> at
> at
> at
> at
Re: stop parsing a method [message #610373 is a reply to message #103320] |
Wed, 24 August 2005 11:52  |
the block of code:
if(node == null) {
return;
100) + ")");
price += tax;
Sri Gunturi wrote:
> Hello,
> Sri.
> eldzi wrote:
>> hello,
>> Thanks :)
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
Re: stop parsing a method [message #610699 is a reply to message #103376] |
> the block of code:
> if(node == null) {
> return;
> 100) + ")");
> price += tax;
> Sri Gunturi wrote:
>>Hello,
>>Regards,
>>Sri.
>>eldzi wrote:
>>>hello,
>>>Thanks :)
>>>!STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
FUDForum. Page generated in 0.04725 seconds
