Home » Archived » Test and Performance Tools Platform (TPTP) » Using TPTP AGR across multiple platforms
Using TPTP AGR across multiple platforms [message #103238] |
Fri, 06 July 2007 06:57  |
Originally posted by: nicholas.young.microfocusNOSPAM.com
Apologies if this is a dumb question or in the wrong newsgroup, I wasn't
quite sure where to ask this question. We have a product that is a series of
plugins upon the eclipse ide. My task is to test this product, which we have
been doing (more-or-less) successfully at the level we have currently chosen
to automate (mainly Junit/Junit PDE tests).
Now, we need to automate testing of certain parts of the IDE, and the
decision was made to use tptp agr due to it's cross-platform support. Our
product will run across all windows and multiple unix/linux platforms and
various versions of eclipse, so it is essential that we have automated tests
that will run on all platforms. I thought that TPTP could do this, but it
seems my problem may be in the eclipse ide itself. It seems that despite
being the same version of eclipse, the IDE behaves differently on different
platforms.
On Windows, "File > New" for instance, displays a shortcut of Alt + Shift +
N. On Linux it shows Shift + Alt + N. On AIX, it seems to not display a
shortcut key at all. This means that for each platform we will have to have
a different object mine (or at least different entries in the object mine)
and possibly different versions of the tests.
My questions are as follows:
Is there a way of making eclipse behave the same on all platforms?
Is there a tidy way of grouping the object mine information for the
different platforms that makes it obvious to which platform the object's
belong?
We're currently using tptp 4.3.1 on eclipse 3.2.1.
Many thanks for any input,
Nick Young
Re: Using TPTP AGR across multiple platforms [message #103291 is a reply to message #103238] |
Fri, 06 July 2007 08:28   |
Hi Nick,
Unfortunately, there is no way for users to change the behavior of
Eclipse (e.g. file menu shortcuts). Also, there are several cross-platform
support issues with the AGR, including the problem you reference:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=170375
Improved cross-platform support is an important theme for the AGR in the
next release, however we constrained by resource limitations. If
interested, we appreciate any contributions from the user community.
Noteworthy, TPTP (and the AGR) is only supported on Windows and Linux,
so cross-platform support is limited to these platforms:
http://www.eclipse.org/tptp/home/project_info/releaseinfo/4. 4/support.html#Workbench
Also, as noted in a previous post ('[AGR] Compatibility between AGR 4.3
and AGR 4.4'), Eclipse versions are not downward compatible:
http://www.eclipse.org/eclipse/development/eclipse_project_p lan_3_3.html#Compatibility
Paul
"Nick Young" <nicholas.young@microfocusNOSPAM.com> wrote in message
news:f6l77g$i78$1@build.eclipse.org...
> of plugins upon the eclipse ide. My task is to test this product, which we
> have been doing (more-or-less) successfully at the level we have currently
> chosen to automate (mainly Junit/Junit PDE tests).
> tests that will run on all platforms. I thought that TPTP could do this,
> but it seems my problem may be in the eclipse ide itself. It seems that
> despite being the same version of eclipse, the IDE behaves differently on
> different platforms.
> + N. On Linux it shows Shift + Alt + N. On AIX, it seems to not display a
> have a different object mine (or at least different entries in the object
> mine) and possibly different versions of the tests.
> belong?
> Nick Young
Re: Using TPTP AGR across multiple platforms [message #104035 is a reply to message #103291] |
Tue, 10 July 2007 10:40   |
"Paul Slauenwhite" <paules@ca.ibm.com> wrote in message
news:f6lci7$tp6$1@build.eclipse.org...
> Hi Nick,
> cross-platform support issues with the AGR, including the problem you
> reference:
Many thanks for the response Paul. It's good to know that at least it's not
something I'm doing wrong!
I'm not a great programmer, but I am an experienced software tester with
plenty of tools under my belt, so I generally know what works and what
doesn't with regard to testing. If I can help out with anything I will, as
it's in our interests to be able to test our software well, especially
across multiple platforms as we extend our product.
Nick
Re: Using TPTP AGR across multiple platforms [message #104474 is a reply to message #104035] |
Thu, 12 July 2007 06:48  |
Thanks Nick,
Certainly using and testing TPTP, including opening defects/features, is
a great asset to the project and the wider user community.
Paul
news:f705pk$7rr$1@build.eclipse.org...
>> Hi Nick,
>> reference:
> not something I'm doing wrong!
> Cheers,
> Nick
Current Time: Fri Jul 18 06:43:49 EDT 2025
Powered by FUDForum. Page generated in 0.06430 seconds
