Home » Archived » M2M (model-to-model transformation) » [ATL] can we "cast" an EMFModel to an ASMModel?
[ATL] can we "cast" an EMFModel to an ASMModel? [message #103169] |
Thu, 09 April 2009 06:09  |
hi,
i am trying to develop a High Order Transformation as a first step of a
transformation chain, for this, i need to compile the result of the High
Order Transformation (ATL .ecore) before using it in the second simple
transformation.
I wanted to avoid saving the result to an .ecore file then re-inject it
and then compile, so i modified a little bit the LauncherServie.launch
method so that to get a Map<String, IModel> that contains the output
models, these are EMFModels in my case. But the compiler only accepts
ASMModels, so the problem is to "cast" an EMFModel to an ASMModel. Is this
possible?
I wanted to avoid saving to .ecore then re-injecting to reduce errors,
because after re-injection, the compilation of the ATL model is not
working. I tried to manually extract the .ecore model with AM3 to .atl
file and to compile it and this worked well. So i suppose that maybe the
injection from the atl.ecore file caused this problem.
So is it possible to convert an EMFModel to an ASMModel?
thanks
Re: [ATL] can we "cast" an EMFModel to an ASMModel? [message #103278 is a reply to message #103169] |
Fri, 10 April 2009 05:25   |
At this time, the best way to do that is:
- to extract the EMFModel as an OutputStream
- to reload it using the EMFModelLoader.loadModel(String name, ASMModel
metamodel, InputStream in) method
Note that at least, the compiler will be rewrited to conform to the new
IModel/EMFModel API.
Best regards
William
Skander a écrit :
> hi,
> transformation.
> this possible?
> thanks
Re: [ATL] can we "cast" an EMFModel to an ASMModel? [message #103438 is a reply to message #103278] |
Tue, 14 April 2009 05:26   |
Hi William, i tried to use pipes to convert the OutputStream to
InputStream, but i have an error before that in the extract method, here
is my code, i hope you can help me out, it seems the EMF extractor is not
the one i need:
public ASMModel injectATLModelFileToATLModel (IModel atlEMFModel){
System.out.println("Model Loading Started!");
ASMModel atlASMModel = null;
try
// initialisation
AtlModelHandler amh = AtlModelHandler.getDefault(AtlModelHandler.AMH_EMF);
ASMModel atlMM = amh.createModelLoader().getATL();
//Maybe the IExtractor is not the one i need?!!!
IExtractor extractor = CoreService.getExtractor("EMF");
OutputStream streamOut = new ByteArrayOutputStream();
// extraction from file to outputstream (crushes down)
extractor.extract(atlEMFModel, streamOut, null);
// connecting outputstream pipe to inputstream pipe
PipedOutputStream pipedOut = (PipedOutputStream)streamOut;
PipedInputStream streamIn = new PipedInputStream(pipedOut);
// reload the model from the inputstream pipe
atlASMModel = amh.createModelLoader().loadModel("MarteToAAXL", atlMM,
streamIn);
catch (Exception e)
e.printStackTrace();
return atlASMModel;
Thanks .
Re: [ATL] can we "cast" an EMFModel to an ASMModel? [message #103465 is a reply to message #103278] |
Tue, 14 April 2009 10:22   |
hi, i changed the code, it was an error in the method call, not in the
extraction itself, now i extract the model to an Outputstream but,
apparently, the Inputstream tries to read it with a different coding, in
fact the file is encoded with encoding="ISO-8859-1":
<?xml version="1.0" encoding="ISO-8859-1"?>
<xmi:XMI xmi:version="2.0"
And the error message i get is : Invalid byte 2 of 3-byte UTF-8 sequence.
it seems more like a Java problem than an ATL problem, i'll look in the
Java forums for a solution, here is the new code causing the coding error :
try
// extract the EMFModel as an OutputStream
final OutputStream streamOut = new PipedOutputStream();
PipedInputStream((PipedOutputStream)streamOut);
new Thread(
new Runnable(){
public void run(){
IExtractor extractor;
try {
Map<String, Object> options = new HashMap<String, Object>();
extractor.extract(atlEMFModel, streamOut, options);
} catch (ATLCoreException e) {
).start();
// reload it using the EMFModelLoader.loadModel method
streamIn);
thanks..
Re: [ATL] Is this a bug in ATL ? [message #103525 is a reply to message #103502] |
Wed, 15 April 2009 05:23   |
I don't know how to change the emf4atl driver loading encoding, but here
is how to change the EMFModel extraction encoding:
By default, the EMFExtractor saves the EMF Resource using the option:
extractOptions.put(XMLResource.OPTION_ENCODING, "ISO-8859-1");
But you can override that option:
options .put(XMLResource.OPTION_ENCODING, "UTF-8"); // (I guess)
William
Skander a écrit :
> i don't know if this is a bug in the ATL API but the problem is :
> in the package org.eclipse.m2m.atl.drivers.emf4atl in the EMFModelLoader
> class, the encoding is set to "ISO-8859-1", so the EMFModelLoader.save
> method will always store the model with the "ISO-8859-1" encoding. In
> the other hand the EMFModelLoader.load method tries to load it with the
> UTF-8 encoding, what causes the load method to crash for me with the
> message :
> com.sun.org.apache.xerces.internal.impl.io.MalformedByteSequ enceException:
> Is this a bug, or is it possible to force the load methos to use the
> "ISO-8859-1" encoding? Or maybe the use of pipes to convert from an
> Outputstream to an Inputstream causes this problem?
> thanks in advance!
> Skander.
ATL model do not have a root element?!! [message #103568 is a reply to message #103525] |
Thu, 16 April 2009 05:31  |
thanks william for your reply, it worked for me to add the options.put
instruction.
I also added two instructions that close the pipes otherwise i get an
error.
Now the EMFModelLoader.loadModel from the inputstream only populates the
"extent" field (i explore the ASMEMFModel in the debugger after the
loading) , so in the extent field of the ASMEMFModel i find all the data
that comes from the model, but the ModelElements field is completely
empty, i noticed that this is sometimes the case in other model loadings
so i don't think this is a problem.
The problem is that the compiling method now causes this error:
OclUndefined has no property
ATL VM Stack:
J.process() : ??#8 null
local variables = {self=OclUndefined}
local stack = ['Error: could not find matching node for Void at ']
I don't know where the problem comes from. But i wonder if it is normal
that a model conforming to the ATL metamodel do not have a root element,
in fact there are many elements in the first level of its hierarchy, only
the module element contains other elements. Here is an example of an the
ATL model:
<a href="http://www.flickr.com/photos/skanderturki/3447267160/"
title="ATLModel de skanderturki, sur Flickr"><img
src=" http://farm4.static.flickr.com/3344/3447267160_1a1f7fc611.jp g"
width="500" height="444" alt="ATLModel" /></a>
Current Time: Wed Aug 13 12:19:41 EDT 2025
Powered by FUDForum. Page generated in 0.29483 seconds
