Home » Archived » EPF » Two new integration builds of EPF Composer
Two new integration builds of EPF Composer [message #9394] Tue, 25 April 2006 12:49 Go to next message
Hi. There are two new integration builds of EPF Composer available for
download and testing.
1.0-M3-I20060422: This build is the 1.0-M2 code plus a working
integration of the org.eclipse.team.* plug-ins for using version control
from within the tool.
1.0-M3-I20060424: This is the first build against the Eclipse 3.2 RC1
infrastructure and related dependencies (EMF, GEF). Compilation issues
moving from Eclipse 3.1.x to 3.2.x were addressed in this build.
Please see the tool download page for Bugzilla records fixed for each
integration build. Please use Bugzilla for reporting problems with
either of these builds.
http://www.eclipse.org/epf/downloads/tool/tool_downloads.php
Thanks!
Re: Two new integration builds of EPF Composer [message #9517 is a reply to message #9394] Wed, 03 May 2006 16:40 Go to previous message
Hi.
Beginning with build 1.0-M3-I20060424 (under Eclipse 3.2), I was not
required to set the MOZILLA_FIVE_HOME environment variable to run EPF
Composer under Linux.
Can another user help verify setting this variable is no longer
necessary? I am running on RHEL 4, but checking under any distribution
will help.
Thanks.
> Thanks!
Re: Two new integration builds of EPF Composer [message #562935 is a reply to message #9394] Wed, 03 May 2006 16:40 Go to previous message
Hi.
will help.
Thanks.
> Thanks!
Previous Topic:EPF Composer 1.0-M3-I20060503
Next Topic:ClearCase support?
Current Time: Tue Jul 15 14:00:09 EDT 2025
Powered by FUDForum. Page generated in 0.24930 seconds
