[Teneo] Text mapping instead of VarChar [message #103060] |
Sun, 18 November 2007 15:46  |
Originally posted by: irbull.cs.uvic.ca
I am creating my Database schema directly from my ECore model (by
passing my ePackage to the hdbs and then calling initialize). All my
String attributes get mapped to columns of type VarChar(255). I have
one attribute that needs more room than this. Is there any easy was to
say (maybe through an EAnnotation) that this database column should be
Text instead of VarChar?
Ian
Re: [Teneo] Text mapping instead of VarChar [message #486828 is a reply to message #486810] |
Sat, 19 September 2009 11:51  |
Hi Vincenzo,
The title of the post and the content don't seem in sync....
Also support for Teneo is given on the emf newsgroup: eclipse.tools.emf
gr. Martin
Vincenzo Caselli wrote:
> Thank you very much Ian, your post is great!!
> I was beginning to think that editing the ecore xml was the only way.
> I attached an image to make your steps more clear (if possible). I
> didn't find any documentation about handling these options with the
> ecore Editor. Do someone have some useful link about this?
> Thank you
> Vincenzo Caselli
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Text mapping instead of VarChar [message #612582 is a reply to message #103060] |
Sun, 18 November 2007 15:56  |
You can set the @Lob annotation on the efeature. If the edatatype is a string (its instanceclass ==
String.class) then the system should map this as text.
Another way is setting a @Column(length=1000) annotation.
gr. Martin
> Cheers,
> Ian
The Netherlands
Re: [Teneo] Text mapping instead of VarChar [message #612584 is a reply to message #103080] |
Sun, 18 November 2007 16:34  |
WOW! Thanks for the quick response Martin!
Just in case someone else stumbles upon this post, to do this (on your
Ecore file)
1. Select the EAttribute you wish to add the annotation to
2. Add an EAnnotation (with source set to teneo.jpa)
3. Add a details entry
4. set the key to "value"
5. Set the value to "@Lob"
(and don't forget to regenerate your model :) )
Thanks again Martin,
Ian
> string (its instanceclass == String.class) then the system should map
> this as text.
> gr. Martin
>> to say (maybe through an EAnnotation) that this database column should
>> be Text instead of VarChar?
>> Cheers,
>> Ian
Re: [Teneo] Text mapping instead of VarChar [message #621384 is a reply to message #103096] |
Sat, 19 September 2009 08:39  |
I didn't find any documentation about handling these options with the ecore Editor. Do someone have some useful link about this?
Thank you
Vincenzo Caselli
Re: [Teneo] Text mapping instead of VarChar [message #621385 is a reply to message #621384] |
Hi Vincenzo,
gr. Martin
> Thank you
> Vincenzo Caselli
The Netherlands
FUDForum. Page generated in 0.05637 seconds
