Home » Language IDEs » ServerTools (WTP) » EL Support
EL Support [message #103003] Thu, 12 May 2005 09:18 Go to next message
Originally posted by: bernhard.slominski.zooplus.de
as it looks to me, there is no support for EL in the JSP Editor in
concerns of code completion etc.
E.g. code like this:
<jsp:useBean id="test" type="test.TestBean"/>
${test.}
When I have the cusromer on the . after ${test.} I except to get the
properties of the bean.
Is this just missing or do I have to setup something to be able to do this?
Bernhard
Re: EL Support [message #103055 is a reply to message #103003] Thu, 12 May 2005 10:23 Go to previous messageGo to next message
Originally posted by: pavery.us.ibm.com
Bernhard Slominski wrote:
> ${test.}
> properties of the bean. Is this just missing or do I have to setup
> Thanks
> Bernhard
Hi Bernhard,
This functionality is currently under development for M5. Initial
support should be there soon (content assist, as-you-type validation,
syntax highlighting...). Once it's there, it would be helpful for users
such as yourself to test it out. It's usually hard for us to catch all
use cases. I was looking for a feature request/bug that that was
tracking it, but dont see it. I'll post here when I find it.
thanks
-phil
Re: EL Support [message #103066 is a reply to message #103055] Thu, 12 May 2005 10:41 Go to previous messageGo to next message
phil avery wrote:
> Hi Bernhard,
> thanks
> -phil
Hi Phil,
thanks for the answer, once it's there be sure I'll test it out.
Believe me, just the feature I mentioned (code completion of bean
properties) would save you a lot of time. I'm waiting for it in IntelliJ
for one year now.
So just this feature would be a reason to switch to Eclipse, so I'm really
looking forward to it.
Bernhard
Re: EL Support [message #103141 is a reply to message #103055] Thu, 12 May 2005 16:22 Go to previous messageGo to next message
Originally posted by: thisisnot.mymail.com
Will there be support for the getters of the implicit objects?
"phil avery" <pavery@us.ibm.com> wrote in message
news:d5vpdv$9hm$1@news.eclipse.org...
>> ${test.}
>> Thanks
>> Bernhard
> Hi Bernhard,
> This functionality is currently under development for M5. Initial support
> should be there soon (content assist, as-you-type validation, syntax
> highlighting...). Once it's there, it would be helpful for users such as
> yourself to test it out. It's usually hard for us to catch all use cases.
> I was looking for a feature request/bug that that was tracking it, but
> thanks
> -phil
Re: EL Support [message #103706 is a reply to message #103066] Fri, 13 May 2005 17:49 Go to previous messageGo to next message
OK so there was no feature request (that I could find)
so I've opened:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=95237
Progress/suggestions on initial EL support (M5) can be tracked here.
thanks,
phil
> phil avery wrote:
>> Hi Bernhard,
>> users such as yourself to test it out. It's usually hard for us to
>> catch all use cases. I was looking for a feature request/bug that
>> that was tracking it, but dont see it. I'll post here when I find it.
>> thanks
>> -phil
> Hi Phil,
> for one year now.
> really looking forward to it.
> Bernhard
Re: EL Support [message #103718 is a reply to message #103141] Fri, 13 May 2005 17:56 Go to previous message
I believe that is the plan.
check out:
for progress.
The person contributing would know the finer details, might want to post
questions/comments on the feature request.
thanks,
-phil
>>>Hi,
>>>${test.}
>>>Thanks
>>>Bernhard
>>Hi Bernhard,
>>thanks
>>-phil
Previous Topic:WSDL->Java regeneration is wrong [m4|Top Down Web Service|Skeleton]
Next Topic:WST html capitalization of tags
Current Time: Thu Jul 17 21:29:01 EDT 2025
Powered by FUDForum. Page generated in 0.47281 seconds
