Home » Archived » Visual Editor (VE) » swing tabbed pane & layout manager
swing tabbed pane & layout manager [message #102995] Sun, 21 August 2005 10:04 Go to next message
HI. Is there a way to add a layout manager to a tabbed pane in VE?
When i add components, each component takes the whole place, i can't add
several components.
Gaetan.
Re: swing tabbed pane & layout manager [message #103015 is a reply to message #102995] Sun, 21 August 2005 10:28 Go to previous messageGo to next message
QUENTIN Gaétan wrote:
Environment:
Eclipse 3.1, VE 1.1.0, jdk 1.5.0_04 , Linux 2.6.12rc4
> several components.
> Gaetan.
Re: swing tabbed pane & layout manager [message #103027 is a reply to message #103015] Sun, 21 August 2005 11:27 Go to previous message
Originally posted by: myersj.nospam.gmail.com
Gaetan,
A JTabbedPane only accepts one child component on each tab. So what
you'll have to do is drop a JPanel onto the tab, then set the layout on
the JPanel to whatever you want, then place the multiple components on
the JPanel.
- Jeff
>>several components.
>>Regards,
>>Gaetan.
Re: swing tabbed pane & layout manager [message #610347 is a reply to message #102995] Sun, 21 August 2005 10:28 Go to previous message
Environment:
> several components.
> Gaetan.
Re: swing tabbed pane & layout manager [message #610348 is a reply to message #103015] Sun, 21 August 2005 11:27 Go to previous message
Gaetan,
the JPanel.
- Jeff
>>several components.
>>Regards,
>>Gaetan.
Previous Topic:swing tabbed pane & layout manager
Next Topic:when does VE plan to support c/c++ GUI designing?
Current Time: Thu Jul 17 09:06:34 EDT 2025
Powered by FUDForum. Page generated in 0.07634 seconds
