Home » Language IDEs » ServerTools (WTP) » Installation Problems
Installation Problems [message #102981] |
Thu, 12 May 2005 06:05  |
Originally posted by: philipp.seuring.lirmm.fr
I installed a the webtools project and all the required projects as
described in the installation manual. But it is not properly installed. I
keep having Warnings in the Error Log:
Problems encountered while PDE was scanning Target Platform - than a list
with all the
Missing required plug-in: org.eclipse.wst.xml.validation and so on.
The plug-ins are in the plug-in directory and I can see them via Help->About
Eclipse Platform->Plug-in Details
There is an other error when looking at the preferences page clicking on XML
Catalog gives me:
Invalid preference page path: XML Catalog
The other tabs which should be available like Web and XML are not there at
all.
I am using 1.0 M4 and the corresponding eclipse and plug-in versions.
Does anyone now what is wrong - is this a common pitfall?
Regards Philipp
Re: Installation Problems [message #103369 is a reply to message #103150] |
Fri, 13 May 2005 04:03   |
Hi Lawrence,
I tried to install the right versions. This are my configuration
details. Thanks a lot.
Philipp
*** Date: Fri May 13 09:57:39 CEST 2005
*** Platform Details:
*** System properties:
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.buildId=I20050401-1645
eclipse.commands=-os
linux
-ws
gtk
-arch
x86
-launcher
/auto/seuring/programs/eclipse/./eclipse
-name
Eclipse
-showsplash
600
-exitdata
c4e801a
-clean
-vm
/usr/bin/java
eclipse.product=org.eclipse.platform.ide
eclipse.startTime=1115891599485
eclipse.vm=/usr/bin/java
eclipse.vmargs=-Xms40m
-Xmx256m
-jar
/auto/seuring/programs/eclipse/./startup.jar
eof=eof
file.encoding=ISO-8859-15
file.encoding.pkg=sun.io
file.separator=/
java.awt.graphicsenv=sun.awt.X11GraphicsEnvironment
java.awt.printerjob=sun.print.PSPrinterJob
java.class.path=/auto/seuring/programs/eclipse/./startup.jar
java.class.version=48.0
java.endorsed.dirs=/usr/java/j2sdk1.4.2_05/jre/lib/endorsed
java.ext.dirs=/usr/java/j2sdk1.4.2_05/jre/lib/ext
java.home=/usr/java/j2sdk1.4.2_05/jre
java.io.tmpdir=/tmp
java.library.path=/usr/java/j2sdk1.4.2_05/jre/lib/i386/clien t:/usr/java/j2sdk1.4.2_05/jre/lib/i386:/usr/java/j2sdk1.4.2_ 05/jre/../lib/i386:/usr/lib/mozilla-1.7.2
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.4.2_05-b04
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.4
java.util.prefs.PreferencesFactory=java.util.prefs.FileSyste mPreferencesFactory
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.4.2_05
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.4.2_05-b04
line.separator=
org.osgi.framework.executionenvironment=J2SE-1.4
org.osgi.framework.language=fr
org.osgi.framework.os.name=Linux
org.osgi.framework.os.version=2.6.8-1.521custom
org.osgi.framework.processor=i386
org.osgi.framework.system.packages=javax.accessibility,javax .crypto,javax.crypto.interfaces,javax.crypto.spec,javax.imag eio,javax.imageio.event,javax.imageio.metadata,javax.imageio .plugins.jpeg,javax.imageio.spi,javax.imageio.stream,javax.n aming,javax.naming.directory,javax.naming.event,javax.naming .ldap,javax.naming.spi,javax.net,javax.net.ssl,javax.print,j avax.print.attribute,javax.print.attribute.standard,javax.pr int.event,javax.rmi,javax.rmi.CORBA,javax.security.auth,java x.security.auth.callback,javax.security.auth.kerberos,javax. security.auth.login,javax.security.auth.spi,javax.security.a uth.x500,javax.security.cert,javax.sound.midi,javax.sound.mi di.spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql ,javax.swing,javax.swing.border,javax.swing.colorchooser,jav ax.swing.event,javax.swing.filechooser,javax.swing.plaf,java x.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.m ulti,javax.swing.table,javax.swing.text,javax.swing.text.htm l,javax.swing.text.html.parser
,javax.swing.text.rtf,javax.swing.tree,javax.swing.undo,java x.transaction,javax.transaction.xa,javax.xml.parsers,javax.x ml.transform,javax.xml.transform.dom,javax.xml.transform.sax ,javax.xml.transform.stream,org.ietf.jgss,org.omg.CORBA,org. omg.CORBA_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynAn yPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA.portable,org .omg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNami ng.NamingContextExtPackage,org.omg.CosNaming.NamingContextPa ckage,org.omg.Dynamic,org.omg.DynamicAny,org.omg.DynamicAny. DynAnyFactoryPackage,org.omg.DynamicAny.DynAnyPackage,org.om g.IOP,org.omg.IOP.CodecFactoryPackage,org.omg.IOP.CodecPacka ge,org.omg.Messaging,org.omg.PortableInterceptor,org.omg.Por tableInterceptor.ORBInitInfoPackage,org.omg.PortableServer,o rg.omg.PortableServer.CurrentPackage,org.omg.PortableServer. POAManagerPackage,org.omg.PortableServer.POAPackage,org.omg. PortableServer.portable,org.omg.PortableServer.ServantLocato rPackage,org.omg.SendingContex
t,org.omg.stub.java.rmi,org.w3c.dom,org.xml.sax,org.xml.sax. ext,org.xml.sax.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.3.0
os.arch=i386
os.name=Linux
osgi.arch=x86
osgi.bundles=org.eclipse.core.runtime@2:start,
org.eclipse.update.configurator@3:start
osgi.bundles.defaultStartLevel=4
osgi.bundlestore=/auto/seuring/programs/eclipse/configuratio n/org.eclipse.osgi/bundles
osgi.clean=true
osgi.configuration.area=file:/auto/seuring/programs/eclipse/ configuration/
osgi.framework=file:/auto/seuring/programs/eclipse/plugins/o rg.eclipse.osgi_3.1.0.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.0.0
osgi.install.area=file:/auto/seuring/programs/eclipse/
osgi.instance.area=file:/auto/seuring/workspace/
osgi.instance.area.default=file:/auto/seuring/workspace/
osgi.logfile=/auto/seuring/workspace/.metadata/.log
osgi.manifest.cache=/auto/seuring/programs/eclipse/configura tion/org.eclipse.osgi/manifests
osgi.nl=fr_FR
osgi.os=linux
osgi.splashLocation=/auto/seuring/programs/eclipse/plugins/o rg.eclipse.platform_3.1.0/splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=/auto/seuring/programs/eclipse/plugins
osgi.ws=gtk
path.separator=:
sun.arch.data.model=32
sun.boot.class.path=/usr/java/j2sdk1.4.2_05/jre/lib/rt.jar:/ usr/java/j2sdk1.4.2_05/jre/lib/i18n.jar:/usr/java/j2sdk1.4.2 _05/jre/lib/sunrsasign.jar:/usr/java/j2sdk1.4.2_05/jre/lib/j sse.jar:/usr/java/j2sdk1.4.2_05/jre/lib/jce.jar:/usr/java/j2 sdk1.4.2_05/jre/lib/charsets.jar:/usr/java/j2sdk1.4.2_05/jre /classes
sun.boot.library.path=/usr/java/j2sdk1.4.2_05/jre/lib/i386
sun.cpu.endian=little
sun.cpu.isalist=
sun.io.unicode.encoding=UnicodeLittle
sun.java2d.fontpath=
sun.net.client.defaultConnectTimeout=60000
sun.net.client.defaultReadTimeout=60000
sun.os.patch.level=unknown
user.country=FR
user.dir=/auto/seuring/programs/eclipse
user.home=/auto/seuring
user.language=fr
user.name=seuring
user.timezone=Europe/Paris
*** Features:
org.eclipse.jdt (3.1.0) "Eclipse Java Development Tools"
org.eclipse.jdt.source (3.1.0) "Eclipse Java Development Tools SDK"
org.eclipse.pde (3.1.0) "Eclipse Plug-in Development Environment"
org.eclipse.pde.source (3.1.0) "Eclipse Plug-in Development Environment
Developer Resources"
org.eclipse.platform (3.1.0) "Eclipse Platform"
org.eclipse.platform.source (3.1.0) "Eclipse Platform Plug-in Developer
Resources"
org.eclipse.sdk (3.1.0) "Eclipse Project SDK"
*** Plug-in Registry:
com.ibm.etools.emf.event (3.0.0.1) "Event Model" [Resolved]
com.ibm.wtp.common.util (1.0.1) "Logging Plug-in" [Resolved]
com.ibm.wtp.emf.workbench (1.0.1.1) "EMF Workbench" [Resolved]
org.apache.ant (1.6.2) "Apache Ant" [Resolved]
org.apache.axis11 (1.1.0) "Apache Axis 1.1 Plug-in" [Resolved]
org.apache.lucene (1.4.3) "Apache Lucene" [Resolved]
org.apache.wsil4j (1.0.0) "Apache WSIL4J 1.0" [Resolved]
org.apache.xerces (2.6.2) "%pluginName" [Resolved]
org.eclipse.ant.core (3.1.0) "Ant Build Tool Core" [Resolved]
org.eclipse.ant.ui (3.1.0) "Ant UI" [Active]
org.eclipse.compare (3.1.0) "Compare Support" [Active]
org.eclipse.core.boot (3.0.0) "Core Boot" [Resolved]
org.eclipse.core.commands (3.1.0) "Commands" [Active]
org.eclipse.core.expressions (3.1.0) "Expression Language" [Active]
org.eclipse.core.filebuffers (3.1.0) "File Buffers" [Active]
org.eclipse.core.resources (3.1.0) "Core Resource Management" [Active]
org.eclipse.core.resources.compatibility (3.1.0) "Core Resource
Management Compatibility Fragment" [Resolved]
org.eclipse.core.resources.linux (3.0.0) "Core Resource Management Linux
org.eclipse.core.runtime (3.1.0) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.0) "Core Runtime Plug-in
Compatibility" [Active]
org.eclipse.core.variables (3.1.0) "Core Variables" [Resolved]
org.eclipse.debug.core (3.1.0) "Debug Core" [Active]
org.eclipse.debug.ui (3.1.0) "Debug UI" [Active]
org.eclipse.draw2d (3.1.0) "Draw2d" [Resolved]
org.eclipse.draw2d.doc.isv (3.1.0) "Draw2D Documentation" [Resolved]
org.eclipse.emf (2.1.0) "Eclipse Modeling Framework (EMF)" [Resolved]
org.eclipse.emf.ant (2.1.0) "EMF Ant Tasks" [Resolved]
org.eclipse.emf.codegen (2.1.0) "EMF Template Code Generator" [Active]
org.eclipse.emf.codegen.ecore (2.1.0) "EMF Ecore Code Generation" [Resolved]
org.eclipse.emf.codegen.ecore.ui (2.1.0) "EMF Ecore Code Generation UI"
[Resolved]
org.eclipse.emf.codegen.ui (2.1.0) "EMF Template Code Generator UI"
[Resolved]
org.eclipse.emf.common (2.1.0) "EMF Common" [Active]
org.eclipse.emf.common.ui (2.1.0) "EMF Common UI" [Active]
org.eclipse.emf.commonj.sdo (2.1.0) "CommonJ SDO" [Resolved]
org.eclipse.emf.doc (2.1.0) "Eclipse Modeling Framework (EMF)
Programmers Guide" [Resolved]
org.eclipse.emf.ecore (2.1.0) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.1.0) "EMF Ecore Change Model" [Resolved]
org.eclipse.emf.ecore.change.edit (2.1.0) "EMF Ecore Change Edit
Support" [Resolved]
org.eclipse.emf.ecore.edit (2.1.0) "EMF Ecore Edit Support" [Active]
org.eclipse.emf.ecore.editor (2.1.0) "Sample Ecore Editor" [Active]
org.eclipse.emf.ecore.sdo (2.1.0) "EMF Service Data Objects (SDO)"
[Resolved]
org.eclipse.emf.ecore.sdo.doc (2.1.0) "EMF Service Data Objects (SDO)
org.eclipse.emf.ecore.sdo.edit (2.1.0) "EMF Service Data Objects (SDO)
Edit Support" [Resolved]
org.eclipse.emf.ecore.sdo.editor (2.1.0) "EMF Service Data Objects (SDO)
Editor" [Resolved]
org.eclipse.emf.ecore.sdo.source (2.1.0) "EMF Service Data Objects (SDO)
Source" [Resolved]
org.eclipse.emf.ecore.xmi (2.1.0) "EMF XMI" [Active]
org.eclipse.emf.edit (2.1.0) "EMF Edit" [Active]
org.eclipse.emf.edit.ui (2.1.0) "EMF Edit UI" [Active]
org.eclipse.emf.mapping (2.1.0) "EMF Mapping" [Active]
org.eclipse.emf.mapping.ecore2ecore (2.1.0) "Ecore to Ecore Mapping"
[Active]
org.eclipse.emf.mapping.ecore2ecore.editor (2.1.0) "Ecore to Ecore
Mapping Editor" [Active]
org.eclipse.emf.mapping.ecore2xml (2.1.0) "Ecore to XML Mapping Model"
[Resolved]
org.eclipse.emf.mapping.ecore2xml.ui (2.1.0) "Ecore to XML Mapping UI"
[Resolved]
org.eclipse.emf.mapping.ui (2.1.0) "EMF Mapping UI" [Active]
org.eclipse.emf.mapping.xsd2ecore (2.1.0) "XSD to Ecore Mapping" [Resolved]
org.eclipse.emf.mapping.xsd2ecore.editor (2.1.0) "XSD to Ecore Mapping
Editor" [Resolved]
org.eclipse.emf.source (2.1.0) "Eclipse Modeling Framework (EMF) Source"
[Resolved]
org.eclipse.gef (3.1.0) "Graphical Editing Framework" [Resolved]
org.eclipse.gef.doc.isv (3.1.0) "Graphical Editing Framework
org.eclipse.gef.examples.flow (3.1.0) "GEF Flow Editor Example" [Resolved]
org.eclipse.gef.examples.logic (3.1.0) "GEF Logic Editor Example" [Resolved]
org.eclipse.gef.examples.shapes (3.1.0) "GEF Shape Editor Example"
[Resolved]
org.eclipse.gef.examples.source (3.1.0) "GEF Examples" [Resolved]
org.eclipse.gef.examples.text (3.1.0) "Graphical Editing Framework Text
Example" [Resolved]
org.eclipse.gef.source (3.1.0) "Graphical Editing Framework Developer
Resources" [Resolved]
org.eclipse.help (3.1.0) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.0) "Help Application Server" [Resolved]
org.eclipse.help.base (3.1.0) "Help System Base" [Resolved]
org.eclipse.help.ui (3.1.0) "Help System UI" [Resolved]
org.eclipse.help.webapp (3.1.0) "Help System Webapp" [Resolved]
org.eclipse.jdt (3.1.0) "Eclipse Java Development Tools" [Resolved]
org.eclipse.jdt.core (3.1.0) "Java Development Tools Core" [Active]
org.eclipse.jdt.debug (3.1.0) "JDI Debug Model" [Active]
org.eclipse.jdt.debug.ui (3.1.0) "JDI Debug UI" [Resolved]
org.eclipse.jdt.doc.isv (3.1.0) "Eclipse JDT Plug-in Developer Guide"
[Resolved]
org.eclipse.jdt.doc.user (3.1.0) "Eclipse Java Development User Guide"
[Resolved]
org.eclipse.jdt.junit (3.1.0) "Java Development Tools JUnit support"
[Resolved]
org.eclipse.jdt.junit.runtime (3.1.0) "Java Development Tools JUnit
runtime support" [Resolved]
org.eclipse.jdt.launching (3.1.0) "Java Development Tools Launching
Support" [Active]
[Resolved]
org.eclipse.jdt.ui (3.1.0) "Java Development Tools UI" [Resolved]
org.eclipse.jem (1.0.2) "Java EMF Model" [Resolved]
org.eclipse.jem.beaninfo (1.0.2) "Java EMF Model BeanInfo
(Introspection) Support" [Resolved]
org.eclipse.jem.proxy (1.0.2) "Java EMF Model Proxy Support" [Resolved]
org.eclipse.jem.ui (1.0.1) "Java EMF Model UI" [Resolved]
org.eclipse.jem.workbench (1.0.2) "Java EMF Model Workbench Support"
[Resolved]
org.eclipse.jface (3.1.0) "JFace" [Active]
org.eclipse.jface.text (3.1.0) "JFace Text" [Active]
org.eclipse.jst.common.annotations.controller (1.0.0) "Annotation
Controller Plug-in" [Installed]
org.eclipse.jst.common.annotations.core (1.0.0) "Annotation Core
org.eclipse.jst.common.annotations.ui (1.0.0) "Ui Plug-in" [Installed]
org.eclipse.jst.common.frameworks (1.0.0) "Integration Plug-in" [Installed]
org.eclipse.jst.common.frameworks.ui (1.0.0) "WTP JDT Integration UI
org.eclipse.jst.common.launcher.ant (1.0.0) "Ant Launcher Plug-in"
[Resolved]
org.eclipse.jst.common.navigator.java (1.0.0) "Navigator Plug-in"
[Installed]
org.eclipse.jst.ejb.ui (1.0.0) "WTP EJB UI Plug-in" [Installed]
org.eclipse.jst.j2ee (1.0.0) "J2EE Component" [Installed]
org.eclipse.jst.j2ee.core (1.0.0) "J2EE Core Component" [Installed]
org.eclipse.jst.j2ee.ejb (1.0.0) "EJB component Plug-in" [Installed]
org.eclipse.jst.j2ee.ejb.annotation.model (1.0.0) "EJB Annotation Model
org.eclipse.jst.j2ee.ejb.annotations.emitter (1.0.0) "EJB Emitter
org.eclipse.jst.j2ee.ejb.annotations.ui (1.0.0) "EJB Annotations Ui
org.eclipse.jst.j2ee.ejb.annotations.xdoclet (1.0.0) "Xdoclet
Annotations Plug-in" [Installed]
org.eclipse.jst.j2ee.jca (1.0.0) "JCA Plug-in" [Installed]
org.eclipse.jst.j2ee.jca.ui (1.0.0) "WTP JCA UI Plug-in" [Installed]
org.eclipse.jst.j2ee.navigator.ui (1.0.0) "J2EE Extensions to Common
Navigator" [Installed]
org.eclipse.jst.j2ee.ui (1.0.0) "WTP J2EE UI Plug-in" [Installed]
org.eclipse.jst.j2ee.web (1.0.0) "Web Plug-in" [Installed]
org.eclipse.jst.j2ee.webservice (1.0.0) "Web Service Plug-in" [Installed]
org.eclipse.jst.j2ee.webservices.ui (1.0.0) "WTP Webservice UI Plug-in"
[Installed]
org.eclipse.jst.jsp.core (1.0.0) "Structured Source JSP Model" [Installed]
org.eclipse.jst.jsp.ui (1.0.0) "SSE JSP Source Editor" [Installed]
org.eclipse.jst.server.core (1.0.0) "Java Server Support" [Resolved]
org.eclipse.jst.server.generic.core (1.0.0) "Generic Server Plugin"
[Resolved]
org.eclipse.jst.server.generic.serverdefinitions (1.0.0) "Generic server
example definitions" [Resolved]
org.eclipse.jst.server.generic.ui (1.0.0) "Generic Server Plugin UI"
[Resolved]
org.eclipse.jst.server.tomcat.core (1.0.0) "Apache Tomcat Support"
[Resolved]
org.eclipse.jst.server.tomcat.ui (1.0.0) "Apache Tomcat UI Support"
[Resolved]
org.eclipse.jst.server.ui (1.0.0) "Java Server UI Support" [Resolved]
org.eclipse.jst.servlet.ui (1.0.0) "WTP Servlet UI Plug-in" [Installed]
org.eclipse.jst.ws (1.0.0) "Web Services" [Installed]
org.eclipse.jst.ws.axis.consumption.core (1.0.0) "Web service Axis
Consumption Core" [Installed]
org.eclipse.jst.ws.axis.consumption.ui (1.0.0) "Webservice Axis
Consumption UI" [Installed]
org.eclipse.jst.ws.axis.creation.ui (1.0.0) "Webservice Axis Creation
UI" [Installed]
org.eclipse.jst.ws.consumption (1.0.0) "Web Services Consumption"
[Installed]
org.eclipse.jst.ws.consumption.ui (1.0.0) "Web Services Consumption
Graphical User Interface" [Installed]
org.eclipse.jst.ws.creation.ejb.ui (1.0.0) "Web Services Creation EJB
org.eclipse.jst.ws.creation.ui (1.0.0) "Web Services Creation Graphical
org.eclipse.jst.ws.uddiregistry (1.0.0) "Web Services Universal
Description Discovery and Integration Registry" [Installed]
org.eclipse.jst.ws.ui (1.0.0) "Web Services Graphical User Interface"
[Installed]
org.eclipse.ltk.core.refactoring (3.1.0) "Refactoring Core" [Resolved]
org.eclipse.ltk.ui.refactoring (3.1.0) "Refactoring UI" [Resolved]
org.eclipse.osgi.services (3.0.0) "OSGi Release 3 Services" [Resolved]
org.eclipse.osgi.util (3.0.0) "OSGi R3 Utility Classes" [Resolved]
org.eclipse.pde (3.1.0) "Eclipse Plug-in Development Environment" [Active]
org.eclipse.pde.build (3.1.0) "Plug-in Development Environment Build
Support" [Resolved]
org.eclipse.pde.core (3.1.0) "Plug-in Development Core" [Active]
org.eclipse.pde.doc.user (3.1.0) "Eclipse Plug-in Development User
Guide" [Resolved]
org.eclipse.pde.junit.runtime (3.1.0) "PDE JUnit Plug-in Test" [Resolved]
org.eclipse.pde.runtime (3.1.0) "Plug-in Development Environment
Runtime" [Active]
Developer Resources" [Resolved]
org.eclipse.pde.ui (3.1.0) "Plug-in Development UI" [Active]
org.eclipse.platform (3.1.0) "Eclipse Platform" [Resolved]
org.eclipse.platform.doc.isv (3.1.0) "Eclipse Platform Plug-in Developer
Guide" [Resolved]
org.eclipse.platform.doc.user (3.1.0) "Eclipse Workbench User Guide"
[Resolved]
org.eclipse.platform.source.linux.gtk.x86 (3.1.0) "Eclipse Platform
Plug-in Developer Resources" [Resolved]
org.eclipse.sdk (3.1.0) "Eclipse Project SDK" [Resolved]
org.eclipse.search (3.1.0) "Search Support" [Resolved]
org.eclipse.swt (3.1.0) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.gtk (3.1.0) "Standard Widget Toolkit for GTK 2.0" [Resolved]
org.eclipse.team.core (3.1.0) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.1.0) "CVS Team Provider Core" [Active]
org.eclipse.team.cvs.ssh (3.1.0) "CVS SSH Core" [Resolved]
org.eclipse.team.cvs.ssh2 (3.1.0) "CVS SSH2" [Active]
org.eclipse.team.cvs.ui (3.1.0) "CVS Team Provider UI" [Active]
org.eclipse.team.ui (3.1.0) "Team Support UI" [Active]
org.eclipse.text (3.1.0) "Text" [Active]
org.eclipse.tomcat (4.1.30.1) "Tomcat Wrapper" [Resolved]
org.eclipse.ui (3.1.0) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.1.0) "Browser Support" [Resolved]
org.eclipse.ui.cheatsheets (3.0.0) "Cheat Sheets" [Resolved]
org.eclipse.ui.console (3.1.0) "Console" [Active]
org.eclipse.ui.editors (3.1.0) "Default Text Editor" [Active]
org.eclipse.ui.externaltools (3.1.0) "External Tools" [Active]
org.eclipse.ui.forms (3.1.0) "Eclipse Forms" [Resolved]
org.eclipse.ui.ide (3.1.0) "Eclipse IDE UI" [Active]
org.eclipse.ui.intro (3.1.0) "Welcome Framework" [Resolved]
org.eclipse.ui.presentations.r21 (3.1.0) "R21 Presentation Plug-in"
[Resolved]
org.eclipse.ui.views (3.1.0) "Views" [Active]
org.eclipse.ui.workbench (3.1.0) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.1.0) "Workbench Compatibility"
[Resolved]
org.eclipse.ui.workbench.texteditor (3.1.0) "Text Editor Framework" [Active]
org.eclipse.uml2 (1.1.0) "UML2" [Resolved]
org.eclipse.uml2.doc (1.1.0) "UML2 Documentation" [Resolved]
org.eclipse.uml2.edit (1.1.0) "UML2 Edit Support" [Resolved]
org.eclipse.uml2.editor (1.1.0) "UML2 Editor" [Resolved]
org.eclipse.uml2.examples (1.1.0) "UML2 Examples" [Resolved]
org.eclipse.uml2.examples.emof2ecore (1.1.0) "EMOF2Ecore Example" [Resolved]
org.eclipse.uml2.examples.source (1.1.0) "UML2 Examples Source" [Resolved]
org.eclipse.uml2.examples.ui (1.1.0) "UML2 Examples UI" [Resolved]
org.eclipse.uml2.resources (1.1.0) "UML2 Resources" [Resolved]
org.eclipse.uml2.source (1.1.0) "UML2 Source" [Resolved]
org.eclipse.update.configurator (3.1.0) "Install/Update Configurator"
[Active]
org.eclipse.update.core (3.1.0) "Install/Update Core" [Active]
org.eclipse.update.core.linux (3.1.0) "Install/Update Core for Linux"
[Resolved]
org.eclipse.update.scheduler (3.1.0) "Automatic Updates Scheduler" [Active]
org.eclipse.update.ui (3.1.0) "Install/Update UI" [Active]
org.eclipse.wst.command.env (1.0.0) "Environment Command Framework
(headless)" [Active]
org.eclipse.wst.command.env.core (1.0.0) "%PLUGIN_NAME" [Active]
org.eclipse.wst.command.env.ui (1.0.0) "%PLUGIN_NAME" [Resolved]
org.eclipse.wst.common.dependencychecker (1.0.0) "%PLUGIN_NAME" [Resolved]
org.eclipse.wst.common.emf (1.0.0) "EMF Utilities" [Installed]
org.eclipse.wst.common.emfworkbench.integration (1.0.0) "EMF Workbench
Edit Plug-in" [Installed]
org.eclipse.wst.common.frameworks (1.0.0)
"org.eclipse.wst.common.frameworks" [Installed]
org.eclipse.wst.common.frameworks.ui (1.0.0) "WTP UI Plug-in" [Installed]
org.eclipse.wst.common.migration (1.0.0) "Tacit Migration Engine
org.eclipse.wst.common.migration.ui (1.0.0) "Compatibility Engine
Startup Hook" [Installed]
org.eclipse.wst.common.modulecore (1.0.0) "Modulecore Plug-in" [Installed]
org.eclipse.wst.common.navigator.views (1.0.0) "%Plugin.name" [Resolved]
org.eclipse.wst.common.navigator.workbench (1.0.0) "Navigator Workbench
Components" [Installed]
org.eclipse.wst.common.snippets (1.0.0) "Snippets View" [Installed]
org.eclipse.wst.common.ui (1.0.0) "Eclipse Base UI extensions" [Active]
org.eclipse.wst.common.ui.properties (1.0.0) "Common Properties UI"
[Resolved]
org.eclipse.wst.common.uriresolver (1.0.0)
"org.eclipse.wst.common.uriresolver" [Resolved]
org.eclipse.wst.css.core (1.0.0) "Structured Source CSS Model" [Installed]
org.eclipse.wst.css.ui (1.0.0) "SSE CSS Source Editor" [Installed]
org.eclipse.wst.dtd.core (1.0.0) "Structured Source DTD Core" [Installed]
org.eclipse.wst.dtd.ui (1.0.0) "SSE DTD Source Editor" [Installed]
org.eclipse.wst.dtd.validation (1.0.0) "DTD Validator" [Installed]
org.eclipse.wst.html.core (1.0.0) "Structured Source HTML Model" [Installed]
org.eclipse.wst.html.ui (1.0.0) "SSE HTML Source Editor" [Installed]
org.eclipse.wst.internet.cache (1.0.0) "Cache URI Resolver Plug-in"
[Resolved]
org.eclipse.wst.internet.monitor.core (1.0.0) "Monitor" [Resolved]
org.eclipse.wst.internet.monitor.ui (1.0.0) "TCP/IP Monitor" [Resolved]
org.eclipse.wst.internet.proxy (1.0.0) "Internet Proxy Preferences" [Active]
org.eclipse.wst.internet.webbrowser (1.0.0) "Web Browser" [Resolved]
org.eclipse.wst.javascript.core (1.0.0) "Structured Source JavaScript
Model" [Resolved]
org.eclipse.wst.javascript.ui (1.0.0) "SSE JavaScript Source Editor"
[Installed]
org.eclipse.wst.rdb.connection.ui (1.0.0) "RDB Connection.ui" [Resolved]
org.eclipse.wst.rdb.core (1.0.0) "RDB Core" [Resolved]
org.eclipse.wst.rdb.core.ui (1.0.0) "Core UI plugin" [Resolved]
org.eclipse.wst.rdb.dbdefinition.db2.cloudscape (1.0.0) "IBM Cloudscape
Database Definition" [Resolved]
org.eclipse.wst.rdb.dbdefinition.db2.iseries (1.0.0) "DB2 UDB iSeries
Database Definition Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.db2.luw (1.0.0) "DB2 UDB Database
org.eclipse.wst.rdb.dbdefinition.db2.zseries (1.0.0) "DB2 UDB Database
org.eclipse.wst.rdb.dbdefinition.derby (1.0.0) "IBM Cloudscape Database
org.eclipse.wst.rdb.dbdefinition.informix (1.0.0) "DBDefinition Informix
Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.oracle (1.0.0) "DBDefinition Oracle
Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.sqlserver (1.0.0) "DBDefinition
SQLServer Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.sybase (1.0.0) "DBDefinition Sybase
Plug-in" [Resolved]
org.eclipse.wst.rdb.derby (1.0.0) "Derby Plug-in" [Resolved]
org.eclipse.wst.rdb.derby.ui (1.0.0) "Derby Plug-in" [Resolved]
org.eclipse.wst.rdb.models.dbdefinition (1.0.0) "DBDefinition Model"
[Resolved]
org.eclipse.wst.rdb.models.sql (1.0.0) "SQLModel Plug-in" [Resolved]
org.eclipse.wst.rdb.outputview (1.0.0) "OutputView Plug-in" [Resolved]
org.eclipse.wst.rdb.server.ui (1.0.0) "Server Explorer plugin" [Resolved]
org.eclipse.wst.rdb.sqleditor (1.0.0) "SQL Source Editor Plug-in" [Resolved]
org.eclipse.wst.rdb.sqlscrapbook (1.0.0) "Sqlscrapbook Plug-in" [Resolved]
org.eclipse.wst.server.core (1.0.0) "Server Core" [Active]
org.eclipse.wst.server.ui (1.0.0) "Server UI" [Active]
org.eclipse.wst.server.util (1.0.0) "Server Utilities" [Active]
org.eclipse.wst.sse.core (1.0.0) "Structured Text Model" [Active]
org.eclipse.wst.sse.ui (1.0.0) "Structured Source Editor" [Installed]
org.eclipse.wst.validation (1.0.0) "Validation Framework" [Installed]
org.eclipse.wst.validation.ui (1.0.0) "Validation Framework UI" [Installed]
org.eclipse.wst.web (1.0.0) "Simple Web Plug-in" [Installed]
org.eclipse.wst.web.ui (1.0.0) "Simple Web UI Plug-in" [Installed]
org.eclipse.wst.ws (1.0.0) "%PLUGIN_NAME" [Resolved]
org.eclipse.wst.ws.explorer (1.0.0) "Web Services Explorer" [Resolved]
org.eclipse.wst.ws.parser (1.0.0) "%PLUGIN_NAME" [Resolved]
org.eclipse.wst.ws.ui (1.0.0) "Web Services UI" [Active]
org.eclipse.wst.wsdl (1.0.0) "WSDL Model" [Resolved]
org.eclipse.wst.wsdl.ui (1.0.0) "WSDL Editor" [Installed]
org.eclipse.wst.wsdl.validation (1.0.0) "WSDL Validator" [Installed]
org.eclipse.wst.wsi (1.0.0) "WSI Conformance Tools" [Installed]
org.eclipse.wst.wsi.ui (1.0.0) "Soap Monitor" [Installed]
org.eclipse.wst.xml.core (1.0.0) "Structured Source XML Model" [Active]
org.eclipse.wst.xml.ui (1.0.0) "SSE XML Source Editor" [Installed]
org.eclipse.wst.xml.uriresolver (1.0.0) "%pluginName" [Active]
org.eclipse.wst.xml.uriresolver.ui (1.0.0) "XML Catalog UI" [Active]
org.eclipse.wst.xml.validation (1.0.0) "XML Validator" [Installed]
org.eclipse.wst.xsd.contentmodel (1.0.0) "Content Model for XML Schema"
[Resolved]
org.eclipse.wst.xsd.ui (1.0.0) "XML Schema Editor" [Installed]
org.eclipse.wst.xsd.validation (1.0.0) "XML Schema Validator" [Installed]
org.eclipse.xsd (2.1.0) "XML Schema Infoset Model (XSD)" [Resolved]
org.eclipse.xsd.doc (2.1.0) "XML Schema Infoset Model (XSD) Programmers
Guide" [Resolved]
org.eclipse.xsd.edit (2.1.0) "XML Schema Edit Framework" [Resolved]
org.eclipse.xsd.editor (2.1.0) "XML Schema Editor" [Resolved]
org.eclipse.xsd.source (2.1.0) "XML Schema Infoset Model (XSD) Source"
[Resolved]
org.eclipse.xsd.test (2.1.0) "XML Schema Infoset Model Test" [Resolved]
org.junit (3.8.1) "JUnit Testing Framework" [Resolved]
org.uddi4j (1.0.0) "UDDI4J 2.0.3" [Resolved]
org.wsdl4j (1.0.0) "WSDL4J 1.4" [Resolved]
system.bundle (3.1.0) "OSGi System Bundle" [Active]
*** User Preferences:
#Fri May 13 09:57:40 CEST 2005
/instance/org.eclipse.team.cvs.core/repositories/%pserver%anonymous@dev.eclipse.org%%home%tools/location=\:pserver\:anonymous@dev.eclipse.org\:/home/tools
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.org.eclipse.update.configurator|org.eclipse.pde.c ore.requiredPlugins= <?xml
version\="1.0" encoding\="UTF-8"?>\n<classpath>\n<classpathentry
sourcepath\=" /auto/seuring/programs/eclipse/plugins/org.eclipse.platform. source_3.0.1/src/org.eclipse.core.runtime_3.0.1/runtimesrc.z ip "
kind\="lib"
path\=" /auto/seuring/programs/eclipse/plugins/org.eclipse.core.runt ime_3.0.1/runtime.jar "/>\n<classpathentry
sourcepath\=" /auto/seuring/programs/eclipse/plugins/org.eclipse.platform. source_3.0.1/src/org.eclipse.osgi_3.0.1/osgisrc.zip "
kind\="lib"
path\=" /auto/seuring/programs/eclipse/plugins/org.eclipse.osgi_3.0. 1/osgi.jar "/>\n<classpathentry
sourcepath\=" /auto/seuring/programs/eclipse/plugins/org.eclipse.platform. source_3.0.1/src/org.eclipse.osgi_3.0.1/coresrc.zip "
kind\="lib"
path\=" /auto/seuring/programs/eclipse/plugins/org.eclipse.osgi_3.0. 1/core.jar "/>\n<classpathentry
sourcepath\=" /auto/seuring/programs/eclipse/plugins/org.eclipse.platform. source_3.0.1/src/org.eclipse.osgi_3.0.1/resolversrc.zip "
kind\="lib"
path\=" /auto/seuring/programs/eclipse/plugins/org.eclipse.osgi_3.0. 1/resolver.jar "/>\n<classpathentry
sourcepath\=" /auto/seuring/programs/eclipse/plugins/org.eclipse.platform. source_3.0.1/src/org.eclipse.osgi_3.0.1/defaultAdaptorsrc.zi p "
kind\="lib"
path\=" /auto/seuring/programs/eclipse/plugins/org.eclipse.osgi_3.0. 1/defaultAdaptor.jar "/>\n<classpathentry
sourcepath\=" /auto/seuring/programs/eclipse/plugins/org.eclipse.platform. source_3.0.1/src/org.eclipse.osgi_3.0.1/eclipseAdaptorsrc.zi p "
kind\="lib"
path\=" /auto/seuring/programs/eclipse/plugins/org.eclipse.osgi_3.0. 1/eclipseAdaptor.jar "/>\n<classpathentry
sourcepath\=" /auto/seuring/programs/eclipse/plugins/org.eclipse.platform. source_3.0.1/src/org.eclipse.osgi_3.0.1/consolesrc.zip "
kind\="lib"
path\=" /auto/seuring/programs/eclipse/plugins/org.eclipse.osgi_3.0. 1/console.jar "/>\n</classpath>\n
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.org.eclipse.ui.editors|org.eclipse.jdt.launching. JRE_CONTAINER= <?xml
sourcepath\="/usr/java/j2sdk1.4.2_05/src.zip" kind\="lib"
path\="/usr/java/j2sdk1.4.2_05/jre/lib/rt.jar"/>\n<classpathentry
path\="/usr/java/j2sdk1.4.2_05/jre/lib/sunrsasign.jar"/>\n <classpathentry
path\="/usr/java/j2sdk1.4.2_05/jre/lib/jsse.jar"/>\n<classpathentry
path\="/usr/java/j2sdk1.4.2_05/jre/lib/jce.jar"/>\n<classpathentry
path\="/usr/java/j2sdk1.4.2_05/jre/lib/charsets.jar"/>\n<classpathentry
kind\="lib"
path\="/usr/java/j2sdk1.4.2_05/jre/lib/ext/dnsns.jar"/>\n <classpathentry
kind\="lib"
path\="/usr/java/j2sdk1.4.2_05/jre/lib/ext/ldapsec.jar"/>\n <classpathentry
kind\="lib"
path\="/usr/java/j2sdk1.4.2_05/jre/lib/ext/localedata.jar"/ >\n<classpathentry
kind\="lib"
path\="/usr/java/j2sdk1.4.2_05/jre/lib/ext/sunjce_provider.jar "/>\n</classpath>\n
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.com.omondo.uml.model|org.eclipse.jdt.launching.JR E_CONTAINER= <?xml
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.builder. resourceCopyExclusionFilter=*.uad,*.ucd,*.uld,*.upd,*.udd,*. uod,*.usd,*.utd,*.uud,*.odd,*.ead,*.ecd,*.eld,*.epd,*.edd,*. eod,*.esd,*.etd,*.eud,*.urd*.uml2,*.ecore,,*.launch
/instance/org.eclipse.team.cvs.core/repositories/%pserver%anonymous@dev.eclipse.org%%home%technology/location=\:pserver\:anonymous@dev.eclipse.org\:/home/technology
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.org.eclipse.update.configurator|org.eclipse.jdt.l aunching.JRE_CONTAINER= <?xml
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.org.eclipse.jdt.ui|org.eclipse.pde.core.requiredP lugins= <?xml
kind\="src" path\="/org.eclipse.ui"/>\n<classpathentry kind\="src"
path\="/org.eclipse.ui.console"/>\n<classpathentry
sourcepath\=" /auto/seuring/programs/eclipse/plugins/org.eclipse.platform. source_3.0.1/src/org.eclipse.help_3.0.0/helpsrc.zip "
kind\="lib"
path\=" /auto/seuring/programs/eclipse/plugins/org.eclipse.help_3.0. 0/help.jar "/>\n<classpathentry
sourcepath\=" /auto/seuring/programs/eclipse/plugins/org.eclipse.platform. source_3.0.1/src/org.eclipse.core.expressions_3.0.0/expressi onssrc.zip "
kind\="lib"
path\=" /auto/seuring/programs/eclipse/plugins/org.eclipse.core.expr essions_3.0.0/expressions.jar "/>\n<classpathentry
sourcepath\=" /auto/seuring/programs/eclipse/plugins/org.eclipse.platform. source_3.0.1/src/org.eclipse.core.resources_3.0.1/resourcess rc.zip "
kind\="lib"
path\=" /auto/seuring/programs/eclipse/plugins/org.eclipse.core.reso urces_3.0.1/resources.jar "/>\n<classpathentry
sourcepath\=" /auto/seuring/programs/eclipse/plugins/org.eclipse.jdt.sourc e_3.0.1/src/org.eclipse.jdt.core_3.0.1/jdtcoresrc.zip "
kind\="lib"
path\=" /auto/seuring/programs/eclipse/plugins/org.eclipse.jdt.core_ 3.0.1/jdtcore.jar "/>\n<classpathentry
kind\="src" path\="/org.eclipse.search"/>\n<classpathentry
sourcepath\=" /auto/seuring/programs/eclipse/plugins/org.eclipse.platform. source_3.0.1/src/org.eclipse.debug.core_3.0.1/dtcoresrc.zip "
kind\="lib"
path\=" /auto/seuring/programs/eclipse/plugins/org.eclipse.debug.cor e_3.0.1/dtcore.jar "/>\n<classpathentry
sourcepath\=" /auto/seuring/programs/eclipse/plugins/org.eclipse.platform. source_3.0.1/src/org.eclipse.debug.ui_3.0.1/dtuisrc.zip "
kind\="lib"
path\=" /auto/seuring/programs/eclipse/plugins/org.eclipse.debug.ui_ 3.0.1/dtui.jar "/>\n<classpathentry
sourcepath\=" /auto/seuring/programs/eclipse/plugins/org.eclipse.jdt.sourc e_3.0.1/src/org.eclipse.jdt.launching_3.0.1/launchingsrc.zip "
kind\="lib"
path\=" /auto/seuring/programs/eclipse/plugins/org.eclipse.jdt.launc hing_3.0.1/launching.jar "/>\n<classpathentry
sourcepath\=" /auto/seuring/programs/eclipse/plugins/org.eclipse.platform. source_3.0.1/src/org.eclipse.compare_3.0.0/comparesrc.zip "
kind\="lib"
path\=" /auto/seuring/programs/eclipse/plugins/org.eclipse.compare_3 .0.0/compare.jar "/>\n<classpathentry
kind\="src" path\="/org.eclipse.team.core"/>\n<classpathentry
sourcepath\=" /auto/seuring/programs/eclipse/plugins/org.eclipse.platform. source_3.0.1/src/org.eclipse.core.filebuffers_3.0.1/filebuff erssrc.zip "
kind\="lib"
path\=" /auto/seuring/programs/eclipse/plugins/org.eclipse.core.file buffers_3.0.1/filebuffers.jar "/>\n<classpathentry
kind\="src" path\="/org.eclipse.jface.text"/>\n<classpathentry
kind\="src"
path\="/org.eclipse.ui.workbench.texteditor"/>\n<classpathentry
kind\="src" path\="/org.eclipse.ui.ide"/>\n<classpathentry kind\="src"
path\="/org.eclipse.ui.views"/>\n<classpathentry kind\="src"
path\="/org.eclipse.ui.editors"/>\n<classpathentry
sourcepath\=" /auto/seuring/programs/eclipse/plugins/org.eclipse.platform. source_3.0.1/src/org.eclipse.core.runtime.compatibility_3.0. 0/compatibilitysrc.zip "
kind\="lib"
path\=" /auto/seuring/programs/eclipse/plugins/org.eclipse.core.runt ime.compatibility_3.0.0/compatibility.jar "/>\n<classpathentry
kind\="lib"
kind\="src" path\="/org.eclipse.osgi"/>\n<classpathentry kind\="src"
path\="/org.eclipse.update.configurator"/>\n<classpathentry kind\="src"
path\="/org.eclipse.ltk.core.refactoring"/>\n<classpathentry kind\="src"
path\="/org.eclipse.ltk.ui.refactoring"/>\n</classpath>\n
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.org.eclipse.emf.ecore.xmi|org.eclipse.jdt.launchi ng.JRE_CONTAINER= <?xml
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.com.omondo.xerces|org.eclipse.pde.core.requiredPl ugins= <?xml
version\="1.0" encoding\="UTF-8"?>\n<classpath>\n</classpath>\n
/instance/org.eclipse.ui.ide/EXIT_PROMPT_ON_CLOSE_LAST_WINDO W=false
/instance/org.eclipse.team.cvs.ui/pref_text_ksubst=-kkv
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.org.eclipse.ui.console|org.eclipse.jdt.launching. JRE_CONTAINER= <?xml
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.org.eclipse.jdt.core|org.eclipse.pde.core.require dPlugins= <?xml
kind\="lib"
kind\="lib"
path\="/org.eclipse.text"/>\n<classpathentry
sourcepath\=" /auto/seuring/programs/eclipse/plugins/org.eclipse.platform. source_3.0.1/src/org.apache.ant_1.6.2/lib/antsrc.zip "
kind\="lib"
path\=" /auto/seuring/programs/eclipse/plugins/org.apache.ant_1.6.2/ lib/ant.jar "/>\n<classpathentry
kind\="lib"
path\=" /auto/seuring/programs/eclipse/plugins/org.apache.ant_1.6.2/ lib/ant-antlr.jar "/>\n<classpathentry
kind\="lib"
path\=" /auto/seuring/programs/eclipse/plugins/org.apache.ant_1.6.2/ lib/ant-apache-bcel.jar "/>\n<classpathentry
kind\="lib"
path\=" /auto/seuring/programs/eclipse/plugins/org.apache.ant_1.6.2/ lib/ant-apache-bsf.jar "/>\n<classpathentry
kind\="lib"
path\=" /auto/seuring/programs/eclipse/plugins/org.apache.ant_1.6.2/ lib/ant-apache-log4j.jar "/>\n<classpathentry
kind\="lib"
path\=" /auto/seuring/programs/eclipse/plugins/org.apache.ant_1.6.2/ lib/ant-apache-oro.jar "/>\n<classpathentry
kind\="lib"
path\=" /auto/seuring/programs/eclipse/plugins/org.apache.ant_1.6.2/ lib/ant-apache-regexp.jar "/>\n<classpathentry
kind\="lib"
path\=" /auto/seuring/programs/eclipse/plugins/org.apache.ant_1.6.2/ lib/ant-apache-resolver.jar "/>\n<classpathentry
kind\="lib"
path\=" /auto/seuring/programs/eclipse/plugins/org.apache.ant_1.6.2/ lib/ant-commons-logging.jar "/>\n<classpathentry
kind\="lib"
path\=" /auto/seuring/programs/eclipse/plugins/org.apache.ant_1.6.2/ lib/ant-commons-net.jar "/>\n<classpathentry
kind\="lib"
path\=" /auto/seuring/programs/eclipse/plugins/org.apache.ant_1.6.2/ lib/ant-icontract.jar "/>\n<classpathentry
kind\="lib"
path\=" /auto/seuring/programs/eclipse/plugins/org.apache.ant_1.6.2/ lib/ant-jai.jar "/>\n<classpathentry
kind\="lib"
path\=" /auto/seuring/programs/eclipse/plugins/org.apache.ant_1.6.2/ lib/ant-javamail.jar "/>\n<classpathentry
kind\="lib"
path\=" /auto/seuring/programs/eclipse/plugins/org.apache.ant_1.6.2/ lib/ant-jdepend.jar "/>\n<classpathentry
kind\="lib"
path\=" /auto/seuring/programs/eclipse/plugins/org.apache.ant_1.6.2/ lib/ant-jmf.jar "/>\n<classpathentry
kind\="lib"
path\=" /auto/seuring/programs/eclipse/plugins/org.apache.ant_1.6.2/ lib/ant-jsch.jar "/>\n<classpathentry
kind\="lib"
path\=" /auto/seuring/programs/eclipse/plugins/org.apache.ant_1.6.2/ lib/ant-junit.jar "/>\n<classpathentry
kind\="lib"
path\=" /auto/seuring/programs/eclipse/plugins/org.apache.ant_1.6.2/ lib/ant-launcher.jar "/>\n<classpathentry
kind\="lib"
path\=" /auto/seuring/programs/eclipse/plugins/org.apache.ant_1.6.2/ lib/ant-netrexx.jar "/>\n<classpathentry
kind\="lib"
path\=" /auto/seuring/programs/eclipse/plugins/org.apache.ant_1.6.2/ lib/ant-nodeps.jar "/>\n<classpathentry
kind\="lib"
path\=" /auto/seuring/programs/eclipse/plugins/org.apache.ant_1.6.2/ lib/ant-starteam.jar "/>\n<classpathentry
kind\="lib"
path\=" /auto/seuring/programs/eclipse/plugins/org.apache.ant_1.6.2/ lib/ant-stylebook.jar "/>\n<classpathentry
kind\="lib"
path\=" /auto/seuring/programs/eclipse/plugins/org.apache.ant_1.6.2/ lib/ant-swing.jar "/>\n<classpathentry
kind\="lib"
path\=" /auto/seuring/programs/eclipse/plugins/org.apache.ant_1.6.2/ lib/ant-trax.jar "/>\n<classpathentry
kind\="lib"
path\=" /auto/seuring/programs/eclipse/plugins/org.apache.ant_1.6.2/ lib/ant-vaj.jar "/>\n<classpathentry
kind\="lib"
path\=" /auto/seuring/programs/eclipse/plugins/org.apache.ant_1.6.2/ lib/ant-weblogic.jar "/>\n<classpathentry
kind\="lib"
path\=" /auto/seuring/programs/eclipse/plugins/org.apache.ant_1.6.2/ lib/ant-xalan1.jar "/>\n<classpathentry
kind\="lib"
path\=" /auto/seuring/programs/eclipse/plugins/org.apache.ant_1.6.2/ lib/ant-xslp.jar "/>\n<classpathentry
kind\="src" path\="/org.eclipse.team.core"/>\n</classpath>\n
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.org.eclipse.jdt.core|org.eclipse.jdt.launching.JR E_CONTAINER= <?xml
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.org.eclipse.jdt.ui|org.eclipse.jdt.launching.JRE_ CONTAINER= <?xml
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.org.eclipse.core.expressions|org.eclipse.jdt.laun ching.JRE_CONTAINER= <?xml
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_ code_templates= <?xml
version\="1.0" encoding\="UTF-8"?>\n<templates/>
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.galicia|org.eclipse.jdt.launching.JRE_CONTAINER= <?xml
sourcepath\="/auto/seuring/download/jdk1.5.0_02/src.zip" kind\="lib"
path\="/auto/seuring/download/jdk1.5.0_02/jre/lib/rt.jar"/ >\n<classpathentry
path\="/auto/seuring/download/jdk1.5.0_02/jre/lib/jsse.jar"/ >\n<classpathentry
path\="/auto/seuring/download/jdk1.5.0_02/jre/lib/jce.jar"/ >\n<classpathentry
path\="/auto/seuring/download/jdk1.5.0_02/jre/lib/charsets.jar "/>\n<classpathentry
kind\="lib"
path\=" /auto/seuring/download/jdk1.5.0_02/jre/lib/ext/sunjce_provid er.jar "/>\n<classpathentry
kind\="lib"
path\=" /auto/seuring/download/jdk1.5.0_02/jre/lib/ext/sunpkcs11.jar "/>\n<classpathentry
kind\="lib"
path\="/auto/seuring/download/jdk1.5.0_02/jre/lib/ext/dnsns.jar "/>\n<classpathentry
kind\="lib"
path\=" /auto/seuring/download/jdk1.5.0_02/jre/lib/ext/localedata.ja r "/>\n</classpath>\n
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.org.eclipse.core.runtime|org.eclipse.jdt.launchin g.JRE_CONTAINER= <?xml
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
/instance/org.eclipse.ui.ide/SWITCH_PERSPECTIVE_ON_PROJECT_C REATION=always
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.com.omondo.uml.core|org.eclipse.jdt.launching.JRE _CONTAINER= <?xml
sourcepath\="/usr/java/j2sdk1.4.2_05/src.zip" kind\="lib&q
Re: Installation Problems [message #103623 is a reply to message #103589] |
Fri, 13 May 2005 12:03   |
I think you would need to keep configuration/config.ini. You might
extract it from the 3.1M6 zip and try again. When I "clear" the
configuration, I just delete all the subdirectories of the configuration
directory.
Larry
Philipp Seuring wrote:
> I deleted the configuration directory, now eclipse is not starting any more
> and I get the attached .log
> Hope you can help me...
> Philipp
> <lmandel@ca.ibm.com> schrieb im Newsbeitrag
> news:d60m9c$e5d$1@news.eclipse.org...
>>Hi Philipp,
>>Are you running Eclipse 3.1M6? Can you itemize the projects that you
>>installed?
>>Lawrence
> !SESSION 2005-05-13 17:32:01.261 -----------------------------------------------
> eclipse.buildId=unknown
> BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=fr_FR
> Command-line arguments: -os linux -ws gtk -arch x86 -clean
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.264
> !MESSAGE Application error
> !STACK 1
> java.lang.RuntimeException: No application id has been found.
> at org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:206)
> at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:344)
> at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:156)
> at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
> at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:324)
> at org.eclipse.core.launcher.Main.invokeFramework(Main.java:315 )
> at org.eclipse.core.launcher.Main.basicRun(Main.java:268)
> at org.eclipse.core.launcher.Main.run(Main.java:942)
> at org.eclipse.core.launcher.Main.main(Main.java:926)
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.300
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.js t.common.annotations.controller_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.300
> !MESSAGE Missing required bundle org.eclipse.wst.common.frameworks_[0.0.0,null.
> !MESSAGE Missing required bundle org.eclipse.wst.common.emf_[0.0.0,null.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.301
> !MESSAGE Missing required bundle org.eclipse.jst.common.annotations.core_[0.0.0,null.
> !MESSAGE Missing required bundle org.eclipse.jem.util_[0.0.0,null.
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.309
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.js t.common.annotations.core_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.310
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.320
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.js t.common.annotations.ui_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.321
> !MESSAGE Missing required bundle org.eclipse.jst.common.annotations.controller_[0.0.0,null.
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.327
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.js t.common.frameworks.ui_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.327
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.328
> !MESSAGE Missing required bundle org.eclipse.jst.common.frameworks_[0.0.0,null.
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.336
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.js t.common.frameworks_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.336
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.337
> !MESSAGE Missing required bundle org.eclipse.wst.common.modulecore_[0.0.0,null.
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.345
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.js t.common.navigator.java_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.345
> !MESSAGE Missing required bundle org.eclipse.wst.common.navigator.workbench_[0.0.0,null.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.346
> !MESSAGE Missing required bundle org.eclipse.wst.common.frameworks.ui_[0.0.0,null.
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.354
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.js t.ejb.ui_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.354
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.357
> !MESSAGE Missing required bundle org.eclipse.jst.j2ee.ejb_[0.0.0,null.
> !MESSAGE Missing required bundle org.eclipse.jst.j2ee.jca_[0.0.0,null.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.358
> !MESSAGE Missing required bundle org.eclipse.jst.j2ee.web_[0.0.0,null.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.359
> !MESSAGE Missing required bundle org.eclipse.jst.j2ee_[0.0.0,null.
> !MESSAGE Missing required bundle org.eclipse.jst.j2ee.core_[0.0.0,null.
> !MESSAGE Missing required bundle org.eclipse.wst.common.emfworkbench.integration_[0.0.0,null.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.360
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.361
> !MESSAGE Missing required bundle org.eclipse.wst.common.migration_[0.0.0,null.
> !MESSAGE Missing required bundle org.eclipse.jst.j2ee.ui_[0.0.0,null.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.362
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.368
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.js t.j2ee.core_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.368
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.369
> !MESSAGE Missing required bundle org.eclipse.wst.validation_[0.0.0,null.
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.376
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.js t.j2ee.ejb.annotation.model_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.376
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.377
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.378
> !MESSAGE Missing required bundle org.eclipse.jst.j2ee.ejb.annotations.emitter_[0.0.0,null.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.379
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.388
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.js t.j2ee.ejb.annotations.emitter_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.388
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.389
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.396
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.js t.j2ee.ejb.annotations.ui_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.397
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.398
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.415
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.416
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.417
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.418
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.419
> !MESSAGE Missing required bundle org.eclipse.jst.j2ee.ejb.annotation.model_[0.0.0,null.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.420
> !MESSAGE Missing required bundle org.eclipse.jst.ejb.ui_[0.0.0,null.
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.427
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.js t.j2ee.ejb.annotations.xdoclet_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.428
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.429
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.430
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.446
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.447
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.448
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.456
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.js t.j2ee.ejb_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.488
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.489
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.490
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.491
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.503
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.js t.j2ee.jca.ui_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.503
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.504
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.505
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.509
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.510
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.516
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.js t.j2ee.jca_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.517
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.519
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.520
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.521
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.529
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.js t.j2ee.navigator.ui_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.529
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.532
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.533
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.534
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.535
> !MESSAGE Missing required bundle org.eclipse.jst.servlet.ui_[0.0.0,null.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.536
> !MESSAGE Missing required bundle org.eclipse.jst.j2ee.jca.ui_[0.0.0,null.
> !MESSAGE Missing required bundle org.eclipse.jst.common.navigator.java_[0.0.0,null.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.537
> !MESSAGE Missing required bundle org.eclipse.jst.j2ee.webservices.ui_[0.0.0,null.
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.545
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.js t.j2ee.ui_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.545
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.546
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.547
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.548
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.550
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.551
> !MESSAGE Missing required bundle org.eclipse.wst.web_[0.0.0,null.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.552
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.560
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.js t.j2ee.web_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.560
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.561
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.562
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.563
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.564
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.568
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.583
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.js t.j2ee.webservice_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.584
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.585
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.586
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.598
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.js t.j2ee.webservices.ui_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.598
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.599
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.600
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.601
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.602
> !MESSAGE Missing required bundle org.eclipse.jst.j2ee.webservice_[0.0.0,null.
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.612
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.js t.j2ee_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.613
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.614
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.615
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.621
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.js t.jsp.core_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.622
> !MESSAGE Missing required bundle org.eclipse.wst.html.core_[0.0.0,null.
> !MESSAGE Missing required bundle org.eclipse.wst.sse.ui_[0.0.0,null.
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.629
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.js t.jsp.ui_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.630
> !MESSAGE Missing required bundle org.eclipse.wst.html.ui_[0.0.0,null.
> !MESSAGE Missing required bundle org.eclipse.wst.css.ui_[0.0.0,null.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.631
> !MESSAGE Missing required bundle org.eclipse.wst.xml.ui_[0.0.0,null.
> !MESSAGE Missing required bundle org.eclipse.jst.jsp.core_[0.0.0,null.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.632
> !MESSAGE Missing required bundle org.eclipse.wst.css.core_[0.0.0,null.
> !MESSAGE Missing required bundle org.eclipse.wst.javascript.ui_[0.0.0,null.
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.641
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.js t.servlet.ui_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.641
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.642
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.643
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.645
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.664
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.665
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.670
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.js t.ws.axis.consumption.core_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.670
> !MESSAGE Missing required bundle org.eclipse.jst.ws_[0.0.0,null.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.671
> !MESSAGE Missing required bundle org.eclipse.jst.ws.consumption_[0.0.0,null.
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.677
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.js t.ws.axis.consumption.ui_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.678
> !MESSAGE Missing required bundle org.eclipse.jst.ws.consumption.ui_[0.0.0,null.
> !MESSAGE Missing required bundle org.eclipse.jst.ws.axis.consumption.core_[0.0.0,null.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.679
> !MESSAGE Missing required bundle org.eclipse.jst.ws.ui_[0.0.0,null.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.680
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.688
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.js t.ws.axis.creation.ui_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.689
> !MESSAGE Missing required bundle org.eclipse.jst.ws.creation.ui_[0.0.0,null.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.690
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.691
> !MESSAGE Missing required bundle org.eclipse.jst.ws.axis.consumption.ui_[0.0.0,null.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.692
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.693
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.699
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.708
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.js t.ws.consumption.ui_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.709
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.710
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.711
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.712
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.713
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.720
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.js t.ws.consumption_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.721
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.722
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.723
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.724
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.729
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.js t.ws.creation.ejb.ui_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.729
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.730
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.731
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.746
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.js t.ws.creation.ui_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.747
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.748
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.749
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.750
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.755
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.js t.ws.uddiregistry_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.755
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.756
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.782
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.js t.ws.ui_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.783
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.784
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.792
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.js t.ws_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.792
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.793
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.794
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.800
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.ws t.common.emf_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.801
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.807
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.ws t.common.emfworkbench.integration_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.807
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.808
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.814
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.ws t.common.frameworks.ui_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.814
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.819
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.ws t.common.frameworks_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.819
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.825
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.ws t.common.migration.ui_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.825
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.832
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.ws t.common.migration_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.832
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.833
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.839
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.ws t.common.modulecore_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.840
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.845
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.ws t.common.navigator.workbench_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.845
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.850
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.ws t.common.snippets_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.850
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.855
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.ws t.css.core_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.855
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.862
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.ws t.css.ui_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.862
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.869
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.ws t.dtd.core_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.869
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.874
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.ws t.dtd.ui_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.875
> !MESSAGE Missing required bundle org.eclipse.wst.dtd.core_[0.0.0,null.
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.880
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.ws t.dtd.validation_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.880
> !MESSAGE Missing required bundle org.eclipse.wst.xml.validation_[0.0.0,null.
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.886
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.ws t.html.core_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.886
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.889
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.898
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.ws t.html.ui_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.898
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.899
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.903
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.904
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.910
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.ws t.javascript.ui_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.911
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.918
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.ws t.sse.ui_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.919
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.925
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.ws t.validation.ui_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.925
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.926
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.928
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.934
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.ws t.validation_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.934
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.969
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.ws t.web.ui_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.969
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.976
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.ws t.web_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.976
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.977
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.984
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.ws t.wsdl.ui_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.984
> !MESSAGE Missing required bundle org.eclipse.wst.xsd.ui_[0.0.0,null.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.987
> !ENTRY org.eclipse.osgi 2005-05-13 17:32:01.992
> !MESSAGE Bundle update@/auto/seuring/programs/eclipse/plugins/org.eclipse.ws t.wsdl.validation_1.0.0/ was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2005-05-13 17:32:01.992
Re: Installation Problems [message #104259 is a reply to message #104161] |
Mon, 16 May 2005 11:08  |
Originally posted by: philipp.seuring.lirmm.fr
Thank you, now it works.
I think it is hard to find the JEM download - but nevertheless possible to
do it right - sorry.
"Nitin Dahyabhai" <nitind@us.ibm.com> schrieb im Newsbeitrag
news:d6a0s8$ib3$1@news.eclipse.org...
>> I tried to install the right versions. This are my configuration details.
>> Thanks a lot.
>> org.eclipse.jem.beaninfo (1.0.2) "Java EMF Model BeanInfo (Introspection)
>> Support" [Resolved]
>> [Resolved]
> Philipp, it looks like you have the wrong version of JEM installed--M4
> requires JEM-SDK-I20050415.zip.
> - Nitin
Current Time: Fri Jul 18 00:44:26 EDT 2025
Powered by FUDForum. Page generated in 0.06186 seconds
