Home » Language IDEs » C / C++ IDE (CDT) » Eclipse 3.0M9 + CDT 2.0 M7 = i need org.apache.xerces
Eclipse 3.0M9 + CDT 2.0 M7 = i need org.apache.xerces [message #102976] Sat, 22 May 2004 15:35 Go to next message
Originally posted by: kva.server.by
Hello
Re: Eclipse 3.0M9 + CDT 2.0 M7 = i need org.apache.xerces [message #102989 is a reply to message #102976] Sat, 22 May 2004 19:52 Go to previous messageGo to next message
Originally posted by: compuhelp.caramail.com
Vasili Kirynau wrote:
> Hello
> áfter I installed ECLIPSE 3.0M9 I had been trying to install CDT 2.0M7,
> but everytime I had the same problem updater say that I need
> org.apache.xerces.
> guys where I can find it and how to setup it properly..
> thank you for any help..
I habe the same problem :/
Re: Eclipse 3.0M9 + CDT 2.0 M7 = i need org.apache.xerces [message #103001 is a reply to message #102989] Sat, 22 May 2004 20:27 Go to previous messageGo to next message
Originally posted by: makitalo.cc.jyu.fi
> > Hello
> > org.apache.xerces.
I Dont know how this will help but I'm having same problem. Perhaps cdt
wont work because they dropped the xerces from latest eclipse platform
because it was already implemented in jvm
Re: Eclipse 3.0M9 + CDT 2.0 M7 = i need org.apache.xerces [message #103067 is a reply to message #103001] Mon, 24 May 2004 05:50 Go to previous messageGo to next message
Originally posted by: lemon.canuda.net
olpe wrote:
> > > Hello
> > > org.apache.xerces.
Well, I am trying to install CDT 2.0M8 in eclipse 3.0M9, and I have
exactly the same problem.
Nobody has been able to use 3.0M9 with CDT?
Re: Eclipse 3.0M9 + CDT 2.0 M7 = i need org.apache.xerces [message #103088 is a reply to message #102976] Mon, 24 May 2004 07:00 Go to previous messageGo to next message
Why you guys, all below this thread, just try to use the latest builds?
The link is posted just above the 2.0M7/M8 download links.
..oO( Actually, using 2.0M7 in 3.0M8 and M9 just shows, guys can't read
the download page. Sorry, but this I have already addressed once in this
newsgroup..., There might be exceptions.)
> Hello
> org.apache.xerces.
> Vasili Kiryanau
Re: Eclipse 3.0M9 + CDT 2.0 M7 = i need org.apache.xerces [message #103222 is a reply to message #103088] Mon, 24 May 2004 13:46 Go to previous messageGo to next message
Why not?
Builds are done for being used...
3.0M9 has some interesting capabilities. And I use eclipse to code in C++,
so if I want to use 3.0M9 I must use CDT 2.0M8...
Well, I have been looking at it carefully, and I'm not able to find any
link for this org.apache.xerces plugin.
Well, download pages say that you need 2.0M8 for 3.0M8... I have found no
information for running 2.0M8 in 3.0M9
> > Hello
> > org.apache.xerces.
> > Vasili Kiryanau
Re: Eclipse 3.0M9 + CDT 2.0 M7 = i need org.apache.xerces [message #103229 is a reply to message #103222] Mon, 24 May 2004 16:01 Go to previous messageGo to next message
Andreu Escudero wrote:
> Why not?
Sorry, I meant why you don't use the latest CDT 2.0 _builds_. They are
working with the latest Eclipse-3.0M9. You can either use the Update
Manager, or download them from the same update-site as Update Manager
would use.
http://update.eclipse.org/tools/cdt/updates/builds/2.0/
CDT2.0M8 is not working with Eclipse3.0M9 since there is, once again, an
API-change in Eclipse itself. (Still remember, that M7/8/9 is still no
real _release_. Its just a milestone.)
You need to install the daily builds up to the end of this week, if you
want to stay "cutting edge". CDT Team is not the same team as
Eclipse-Platform/JDT/PDE team. They have to catch up on API changes of
the Platform guys as the JDT-team does or EMF-team or...
Btw., org.apache.xerces is dropped and not needed anymore.
Thats what I meant. It clearly states that CDT2.0M7 is for Eclipse 3.0M7
and CDT2.0M8 is for Eclipse3.0M8. (And as the Eclipse-Plans/Roadmap have
been showing API changes, I would not rely on a working CDT2.0M8 on the
new Eclipse3.0M9).
>>>Hello
>>>org.apache.xerces.
>>>Vasili Kiryanau
Re: Eclipse 3.0M9 + CDT 2.0 M7 = i need org.apache.xerces [message #103270 is a reply to message #103229] Mon, 24 May 2004 17:47 Go to previous messageGo to next message
Originally posted by: pierre.penguin.none
you can download the org.apache.xerces plugin from the eclipse CVS
repository (dev.eclipse.org:/home/eclipse)
You don't even have to compile it, it is already binary. You just need
to copy it to your plugins directory and hopefully that should work :)
Pierre-Alexandre
Re: Eclipse 3.0M9 + CDT 2.0 M7 = i need org.apache.xerces [message #103521 is a reply to message #103270] Tue, 25 May 2004 09:19 Go to previous messageGo to next message
Thank you, this is good answer on my question ..
P.s. no any information in FAQ,
and so many time noone can say how to resolve this problem..
"Pierre-Alexandre" <pierre@penguin.none> wrote in message
news:c8tq3f$re9$1@eclipse.org...
> Pierre-Alexandre
Re: Eclipse 3.0M9 + CDT 2.0 M7 = i need org.apache.xerces [message #103823 is a reply to message #103270] Wed, 26 May 2004 14:13 Go to previous messageGo to next message
Did that.
It doesn't - copied org.apache.xerces to the plugins dir, CDT still
says it requires org.apache.xerces.
Any help? No dice on the web so far, googling my brains out.
Re: Eclipse 3.0M9 + CDT 2.0 M7 = i need org.apache.xerces [message #103918 is a reply to message #103823] Wed, 26 May 2004 19:37 Go to previous message
CDT2.0M7 does not even work with Eclipse 3.0M8, though why do you think
it would be working with M9?
Solution: Wait until an CDT2.0M9 Release comes out by the end of this
week or next week maybe, or use one of the daily builds (build from CVS
HEAD-branch, so be careful!). I use the one with the timestamp 20040521,
its the last one working on my system here.
Don't mess with the xerces, its taken out of Eclipse3.0M9 because
functionality is now contained within Java itself.
> Did that.
> It doesn't - copied org.apache.xerces to the plugins dir, CDT still says
Previous Topic:cdt parse / lookup problem
Next Topic:Has anyone been able to get Eclipse M9 working with the latest CDT?
Current Time: Wed Jul 16 10:24:52 EDT 2025
Powered by FUDForum. Page generated in 0.13599 seconds
