Home » Language IDEs » C / C++ IDE (CDT) » Someone must know how to install CDT??
Someone must know how to install CDT?? [message #102842] Fri, 21 May 2004 12:08 Go to next message
Originally posted by: ext-bil.lewis.nokia.com
I have had no luck following the vague hints for installation. :-(
In particular, the UPDATES feature just hangs (I'll guess it's
related to firewalls).
Moving the CDT directories into Eclipse will show REFERENCES
to CDT, but New>Project still won't show "C++".
I notice others have run into this.
What to do?
-Bil
Re: Someone must know how to install CDT?? [message #102876 is a reply to message #102842] Fri, 21 May 2004 14:08 Go to previous messageGo to next message
Originally posted by: viktor.ransmayr.t-online.de
Hello Bil,
Thanks to Manolo (manolo@itesm.mx) I've been able to figure out
my problems installing CDT.
For the record: I was interested in installing CDT-1.2.1
w/ Eclipse-2.1.2 on WinXP-Pro.
The following recipe worked for me:
1) You have to select the Install/ Update perspective.
1.5) In case you don't "see" the Install/Update perspective execute
Windows > Preferences and select the Install/Update box.
2) In the Install Configuration pane you open the Eclipse Platform
tree.
3) You select the disabled CDT item(s) and hit the Show Disabled
Features button.
I hope this solves the problem for you too.
Viktor
> What to do?
Hope this solves your problem.
Viktor
Re: Someone must know how to install CDT?? [message #102883 is a reply to message #102876] Fri, 21 May 2004 16:02 Go to previous messageGo to next message
Viktor,
I enormously appreciate the suggestion.
But it doesn't help. :-(
I'm trying to install the CDT 2.0.0 on Eclipse 3.0 on a machine running
Windows 2000. I have nothing in Eclipse yet.
This ought to be the simplest, most common installation of CDT. How
could it not work?
-Bil
Viktor Ransmayr wrote:
> Hello Bil,
> tree.
> Features button.
> Viktor
> > What to do?
> Viktor
Re: Someone must know how to install CDT?? [message #102910 is a reply to message #102883] Fri, 21 May 2004 23:01 Go to previous messageGo to next message
Originally posted by: jan.ruzicka.comcast.net
in the updates try to add a site
http://download.eclipse.org/tools/cdt/updates/release/
and then select the correct version.
Bil Lewis wrote:
> Viktor,
> could it not work?
> -Bil
Re: Someone must know how to install CDT?? [message #102923 is a reply to message #102842] Sat, 22 May 2004 11:07 Go to previous messageGo to next message
Hello Bil,
I had the same problems installing CDT on Linux. The reason is that maybe
you missed to install the make and managedbuilder plug-in.
You can get them at:
http://download.eclipse.org/tools/cdt/updates/builds/2.0M8/
(the two last zip files) or just add the link above into the eclipse
build-in update mechanism and then select all three plug-ins.
I don't know the reason why it is separated because it can lead to some
confusion :-)
Alex
Re: Someone must know how to install CDT?? [message #102952 is a reply to message #102842] Sat, 22 May 2004 12:24 Go to previous messageGo to next message
Originally posted by: compuhelp.caramail.com
and
How to install cdt under eclipseM9? :)
I try to do this, but I failed: xerces dependency via update site :/
Re: Someone must know how to install CDT?? [message #103023 is a reply to message #102883] Mon, 24 May 2004 03:06 Go to previous messageGo to next message
"Bil Lewis" <ext-bil.lewis@nokia.com> ???????/???????? ? ???????? ?????????:
news:40AE606F.7C852CDA@nokia.com...
> Viktor,
> could it not work?
See: Help-> Software Updates -> Manage Configuration.
In taskbar select "Show disabled features" button
Re: Someone must know how to install CDT?? [message #103180 is a reply to message #102876] Mon, 24 May 2004 11:52 Go to previous messageGo to next message
I've followed the suggestions of Viktor and Alexander, but no luck. :-(
I can select the C++ perspective, but I can't make a C++ project.
(The "new project" dialog only has two selections: Java & Plug-in.)
You folks have all done it. What's the magic trick?
-Bil
Re: Someone must know how to install CDT?? [message #103192 is a reply to message #103180] Mon, 24 May 2004 12:23 Go to previous messageGo to next message
Originally posted by: tobiaskleinherborn.web.de
download n install the complete package, it consosts of 3 (three) files
including managed and make
then it should work
Re: Someone must know how to install CDT?? [message #103668 is a reply to message #103192] Tue, 25 May 2004 16:23 Go to previous message
Tobias,
That's what I did. (Or at least that's what I *think* I did!)
Certainly in the directory eclipse\features\ all three are there. I
don't see a method to verify from eclipse that all are
installed/active/etc.
Wait! ...
The glories of Win32! It made a duplicate directory and fooled me
into thinking I was installing correctly!!
It works now.
Thank you very much.
-Bil
> then it should work
Previous Topic:How do I get these functions in CDT
Next Topic:Save Error
Current Time: Sat Jul 26 06:05:46 EDT 2025
Powered by FUDForum. Page generated in 0.29119 seconds
