Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Compare] Comparing methods
[Compare] Comparing methods [message #102187] Fri, 09 November 2007 08:22 Go to next message
Originally posted by: brtnik.802.cz
Hello!
I'd like to ask if is (or will be) some possibility to influence comparing
emf objects. For example lets have two objects : A{property p1 = 1,p2 =1;}
B{property p1 = 1,p2 =2;}
In first case I want to compare all properties , so result will be : object
are not similar.
In second case I want to compare only against first property , so result
will be : object are similar.
I've looked in org.eclipse.emf.compare.match.statistic.DifferencesServices.
Also, I tried to extend class to override some methods like isSimilar, but
it seems to be not optimal way.
Thank you in advance!
Re: [Compare] Comparing methods [message #102247 is a reply to message #102187] Fri, 09 November 2007 10:23 Go to previous message
--------------030604010707060008080707
Ivo,
Well in fact, method "DifferencesServices#isSimilar" is accessible for
this kind of needs, just call super.isSimilar() for the objects you
don't want to be compared by their first property ;).
You will then have to extend the extension point
"org.eclipse.emf.compare.match.engine" to have your match engine used.
I you can think of a better way to alter the way objects are detected as
similar, do not hesitate to give us your thoughts :).
Laurent Goubet
Obeo
Ivo Hajducek a
Re: [Compare] Comparing methods [message #612430 is a reply to message #102187] Fri, 09 November 2007 10:23 Go to previous message
Ivo,
Laurent Goubet
Obeo
Ivo Hajducek a
Previous Topic:[Announce] Ecore Diagram Component Proposal
Next Topic:[CDO] how to handle object update conflicts
Current Time: Tue Jul 08 01:04:22 EDT 2025
Powered by FUDForum. Page generated in 0.26348 seconds
