Home » Eclipse Projects » Eclipse Platform » custom builder helper
custom builder helper [message #102180] Tue, 29 July 2003 09:11 Go to next message
We are working on a custom builder and I have a question regarding the
arguements Map that gets passed down via the BuildCommand. Is that map a
map of the keys / values from the compiler preferences for the given
project? If not, how do you get a hold of those preferences from a builder.
thanks,
Lance Phillips
Re: custom builder helper [message #102195 is a reply to message #102180] Tue, 29 July 2003 09:12 Go to previous messageGo to next message
Sorry... I think this belongs on JDT... I'll repost it over there.
lp
"Lance Phillips" <lphillips@metamatrix.com> wrote in message
news:bg5rr7$2hd$1@eclipse.org...
builder.
> thanks,
> Lance Phillips
Re: custom builder helper [message #107055 is a reply to message #102180] Tue, 05 August 2003 17:58 Go to previous message
Originally posted by: John_Arthorne.oti.com_
When you add a builder to a project's build spec, you supply an ICommand
object that contains the builder name and a map of arguments. This is
the map that is provided to the builder's run method. In other words,
that map is defined by you when you add your builder.
I assume you're looking for the java builder options? These are
available via the API JavaCore.getOption(String), where the string is
one of the preference constants defined on the JavaCore class.
> thanks,
> Lance Phillips
Previous Topic:Ant output to Console
Next Topic:Implementing createControl() to build Wizard Page
Current Time: Sat Jul 19 14:08:09 EDT 2025
Powered by FUDForum. Page generated in 0.03684 seconds
