Home » Language IDEs » ServerTools (WTP) » Exceptions when trying to access already created projects after Eclipse restart
Exceptions when trying to access already created projects after Eclipse restart [message #101979] Tue, 10 May 2005 13:02 Go to next message
I am getting illegalStateExceptions and NullPointerExceptions when
trying to access already created flexible project. Is it a bug? How to
avoid it?
1. I create a workspace.
2. I setup tomcat 5.0.30 version in server tab.
3. I create flexible project "test" and module "test" (using tomcat
configuration defined in previous step) (in J2EE perspective, if it does
matter)
4. I restart Eclipse.
5. I try to access "Java Build Path" of "test" project or simple browse it
and get following error log:
!SESSION 2005-05-10 19:42:28.544
eclipse.buildId=I20050401-1645
java.version=1.4.2_08
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=ru_RU
Command-line arguments: -os win32 -ws win32 -arch x86 -clean
!ENTRY org.eclipse.ui 4 4 2005-05-10 19:42:28.544
!MESSAGE Error adapting
org.eclipse.jst.j2ee.navigator.internal.workingsets.Componen tWorkingSet to
org.eclipse.core.resources.mapping.ResourceMapping. Contribution
org.eclipse.compare.MenuGroups is being ignored
!ENTRY org.eclipse.ui 4 4 2005-05-10 19:42:28.564
org.eclipse.team.ccvs.ui.ResourceMapperContributions is being ignored
!ENTRY org.eclipse.ui 4 4 2005-05-10 19:42:28.574
org.eclipse.team.ui.ResourceContributions is being ignored
!ENTRY org.eclipse.ui 4 4 2005-05-10 19:42:28.594
!MESSAGE Error adapting selection to
!ENTRY org.eclipse.ui 4 4 2005-05-10 19:42:37.76
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2005-05-10 19:42:37.76
!MESSAGE EMF context is null
!STACK 0
java.lang.IllegalStateException: EMF context is null
org.eclipse.wst.common.internal.emfworkbench.integration.Edi tModel.getEmfContext(EditModel.java:900)
org.eclipse.wst.common.internal.emfworkbench.integration.Edi tModel.dispose(EditModel.java:151)
org.eclipse.wst.common.internal.emfworkbench.integration.Edi tModel.releaseAccess(EditModel.java:946)
org.eclipse.wst.common.componentcore.internal.StructureEdit. dispose(StructureEdit.java:407)
org.eclipse.wst.common.componentcore.internal.operation.Comp onentCreationDataModel.checkForDuplicateName(ComponentCreati onDataModel.java:198)
org.eclipse.wst.common.componentcore.internal.operation.Comp onentCreationDataModel.doValidateProperty(ComponentCreationD ataModel.java:164)
org.eclipse.jst.j2ee.application.internal.operations.J2EECom ponentCreationDataModel.doValidateProperty(J2EEComponentCrea tionDataModel.java:346)
org.eclipse.jst.j2ee.internal.web.archive.operations.WebComp onentCreationDataModel.doValidateProperty(WebComponentCreati onDataModel.java:308)
org.eclipse.wst.common.frameworks.internal.operations.WTPOpe rationDataModel.validateProperty(WTPOperationDataModel.java: 949)
org.eclipse.wst.common.frameworks.internal.operations.WTPOpe rationDataModel.validateDataModel(WTPOperationDataModel.java :858)
org.eclipse.wst.common.frameworks.internal.operations.WTPOpe rationDataModel.isValid(WTPOperationDataModel.java:901)
org.eclipse.wst.common.frameworks.internal.ui.WTPWizard.canF inish(WTPWizard.java:202)
org.eclipse.jface.wizard.WizardDialog.updateButtons(WizardDi alog.java:1110)
org.eclipse.jface.wizard.WizardPage.setPageComplete(WizardPa ge.java:289)
org.eclipse.wst.common.frameworks.internal.ui.WTPWizardPage. validatePage(WTPWizardPage.java:273)
org.eclipse.wst.common.frameworks.internal.ui.WTPWizardPage. validatePage(WTPWizardPage.java:262)
org.eclipse.jst.j2ee.internal.wizard.J2EEComponentCreationWi zardPage.validatePage(J2EEComponentCreationWizardPage.java:1 63)
org.eclipse.wst.common.frameworks.internal.ui.WTPWizardPage. propertyChanged(WTPWizardPage.java:361)
org.eclipse.wst.common.frameworks.internal.operations.WTPOpe rationDataModel.notifyListeners(WTPOperationDataModel.java:8 17)
org.eclipse.wst.common.frameworks.internal.operations.WTPOpe rationDataModel.notifyListeners(WTPOperationDataModel.java:8 02)
org.eclipse.wst.common.frameworks.internal.operations.WTPOpe rationDataModel.notifyDefaultChange(WTPOperationDataModel.ja va:1008)
org.eclipse.jst.j2ee.internal.web.archive.operations.WebComp onentCreationDataModel.doSetProperty(WebComponentCreationDat aModel.java:104)
org.eclipse.wst.common.frameworks.internal.operations.WTPOpe rationDataModel.internalSetProperty(WTPOperationDataModel.ja va:762)
org.eclipse.wst.common.frameworks.internal.operations.WTPOpe rationDataModel.setProperty(WTPOperationDataModel.java:741)
org.eclipse.wst.common.frameworks.internal.ui.WTPDataModelSy nchHelper.setProperty(WTPDataModelSynchHelper.java:176)
org.eclipse.wst.common.frameworks.internal.ui.WTPDataModelSy nchHelper$ModifyTextListener.modifyText(WTPDataModelSynchHel per.java:69)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:187)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:842)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:866)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:847)
at org.eclipse.swt.widgets.Text.wmCommandChild(Text.java:2019)
at org.eclipse.swt.widgets.Control.WM_COMMAND(Control.java:3155 )
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3032 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3466 )
at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:154 9)
at org.eclipse.swt.widgets.Text.callWindowProc(Text.java:127)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3114 )
at org.eclipse.swt.widgets.Text.windowProc(Text.java:1742)
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:16 25)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2525)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:803 )
at org.eclipse.jface.window.Window.open(Window.java:781)
org.eclipse.wst.common.navigator.internal.actions.WizardShor tcutAction.run(WizardShortcutAction.java:114)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2894)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2527)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1570)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1534)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:306)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:228)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:344)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:156)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:315 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:268)
at org.eclipse.core.launcher.Main.run(Main.java:942)
at org.eclipse.core.launcher.Main.main(Main.java:926)
!SESSION 2005-05-10 19:43:03.434
!ENTRY org.eclipse.jface 4 2 2005-05-10 19:43:03.434
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.jface".
!STACK 0
org.eclipse.jst.server.tomcat.core.internal.TomcatRuntimeTar getHandler.getClasspathContainerLabel(TomcatRuntimeTargetHan dler.java:44)
org.eclipse.jst.server.core.internal.RuntimeClasspathContain er.getDescription(RuntimeClasspathContainer.java:67)
org.eclipse.jdt.internal.ui.packageview.ClassPathContainer.g etLabel(ClassPathContainer.java:163)
org.eclipse.jdt.ui.JavaElementLabels.getTextLabel(JavaElemen tLabels.java:348)
org.eclipse.jdt.internal.ui.viewsupport.JavaUILabelProvider. getText(JavaUILabelProvider.java:161)
org.eclipse.jst.common.navigator.internal.java.PackageExplor erLabelProvider.getText(PackageExplorerLabelProvider.java:56 )
org.eclipse.wst.common.navigator.internal.provisional.views. NavigatorContentServiceLabelProvider.getText(NavigatorConten tServiceLabelProvider.java:114)
org.eclipse.jface.viewers.DecoratingLabelProvider.getText(De coratingLabelProvider.java:118)
org.eclipse.jface.viewers.DecoratingLabelProvider.updateLabe l(DecoratingLabelProvider.java:208)
org.eclipse.jface.viewers.StructuredViewer.buildLabel(Struct uredViewer.java:1727)
at org.eclipse.jface.viewers.TreeViewer.doUpdateItem(TreeViewer .java:215)
org.eclipse.jface.viewers.AbstractTreeViewer$UpdateItemSafeR unnable.run(AbstractTreeViewer.java:85)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1021)
at org.eclipse.core.runtime.Platform.run(Platform.java:757)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:40)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 8)
org.eclipse.jface.viewers.AbstractTreeViewer.doUpdateItem(Ab stractTreeViewer.java:524)
org.eclipse.jface.viewers.StructuredViewer$UpdateItemSafeRun nable.run(StructuredViewer.java:351)
org.eclipse.jface.viewers.StructuredViewer.updateItem(Struct uredViewer.java:1670)
org.eclipse.jface.viewers.AbstractTreeViewer.createTreeItem( AbstractTreeViewer.java:438)
org.eclipse.wst.common.navigator.internal.provisional.views. CommonViewer.createTreeItem(CommonViewer.java:201)
org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractT reeViewer.java:417)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.jface.viewers.AbstractTreeViewer.createChildren( AbstractTreeViewer.java:397)
org.eclipse.jface.viewers.AbstractTreeViewer.handleTreeExpan d(AbstractTreeViewer.java:849)
org.eclipse.jface.viewers.AbstractTreeViewer$4.treeExpanded( AbstractTreeViewer.java:860)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:179)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:851)
at org.eclipse.swt.widgets.Tree.wmNotifyChild(Tree.java:3679)
at org.eclipse.swt.widgets.Control.WM_NOTIFY(Control.java:3558)
at org.eclipse.swt.widgets.Composite.WM_NOTIFY(Composite.java:1 015)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3080 )
at org.eclipse.swt.widgets.Tree.callWindowProc(Tree.java:219)
at org.eclipse.swt.widgets.Tree.WM_LBUTTONDOWN(Tree.java:2788)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3062 )
at org.eclipse.swt.widgets.Tree.windowProc(Tree.java:2360)
Re: Exceptions when trying to access already created projects after Eclipse restart [message #102262 is a reply to message #101979] Wed, 11 May 2005 00:05 Go to previous message
Jevgeni Holodkov wrote:
> Hello,
> avoid it?
> matter)
> it and get following error log:
> to org.eclipse.core.resources.mapping.ResourceMapping. Contribution
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Please open a defect at
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Web%20To ols under
jst.server component with the details you have above.
Previous Topic:JSP Editor Issue (long standing)
Next Topic:JSF WYSIWG-Editor in the near?
Current Time: Tue Jul 15 08:09:12 EDT 2025
Powered by FUDForum. Page generated in 0.08241 seconds
