Home » Modeling » GMF (Graphical Modeling Framework) » strange problem with "unresolved references"
| strange problem with "unresolved references" [message #101915] |
Wed, 07 February 2007 06:21  |
Originally posted by: mail.volker-wegert.de
Hi all,
I'm not sure whether this is an EMF or a GMF problem, so I'll post to both
NGs. I can't really recall what caused the trouble, but when loading a file
into my GMF generated editor, I get tons of messages like
!ENTRY org.eclipse.gmf.runtime.diagram.ui.resources.editor 4 1 2007-02-07 11:09:04.989
!MESSAGE Unresolved reference 'DATE_ARRIVAL'. (platform:filename, 33, 189)
The reference in question always points from an element that is displayed in
the GMF editor to an element not part of the GMF models.
How can I find the source of this message? It doesn't seem to be related to
the UnresolvedReferenceException (tried to catch it with the debugger - no
luck). I haven't found the message text in the GMF components either...
Volker
* Volker Wegert * http://www.volker-wegert.de/contact *
* "Dream as if you'll live forever, live as if you'll die today." (James
* Dean)
| Re: strange problem with "unresolved references" [message #101967 is a reply to message #101915] |
Wed, 07 February 2007 08:01   |
Volker Wegert <mail@volker-wegert.de> writes:
Okay, I'm getting closer - and though it appears to be a problem of GMF
origin, I suppose I need some EMF help here.
From what I can see, the GMFResource I need to get the GMF-based editor
working doesn't care about the IDs specified by the ecore model, but uses
strings like "_lQ0LurapEdu-JpXuZtvRxg". This is why
xmlResource.getEObject("DATE_ARRIVAL") fails, although the attribute
containing this value is marked as "iD".
Question: Is there any way (example, documentation, ...?) on how to create a
resource set (resource, editing domain, ??) that can be used for both EMF and
GMF operations?
Volker
* "Drei Uhr morgens ist immer zu früh und immer zu spät für das, was du
* vorhast." (Jean-Paul Sartre)
| Re: strange problem with "unresolved references" [message #101985 is a reply to message #101967] |
Wed, 07 February 2007 08:13   |
--------------000309000904040006020004
Content-Type: text/plain; charset=UTF-8; format=flowed
Volker,
I'm not sure why this posting didn't show up in both newsgroups.
I think this is likely produced by
org.eclipse.emf.ecore.xmi.UnresolvedReferenceException and
represents an IDREF (a same document reference) to something that
can't be resolved.
Based on your latest comment I would ask if you are using the resource
implementation generated (if there is one) and registered for your
model? It sounds like you are using a resource that specifies to use
UUIDs and that isn't what you want. So using just a plain old
XMIResourceFactoryImpl is likely what you want...
> GMF operations?
> Volker
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Volker,
<br>
<br>
I'm not sure why this posting didn't show up in both newsgroups. <br>
<blockquote> I think this is likely produced by
org.eclipse.emf.ecore.xmi.UnresolvedReferenceException and represents
an IDREF (a same document reference) to something that can't be
resolved.
<br>
</blockquote>
XMIResourceFactoryImpl is likely what you want...<br>
<br>
<br>
<blockquote cite="mid87k5yujf4m.fsf@sinclair.home.volker-wegert.de"
type="cite">
<pre wrap="">Volker Wegert <a class="moz-txt-link-rfc2396E" href="mailto:mail@volker-wegert.de"><mail@volker-wegert.de></a> writes:
</pre>
<blockquote type="cite">
<pre wrap="">I'm not sure whether this is an EMF or a GMF problem, so I'll post to both
</pre>
</blockquote>
<pre wrap=""><!---->
GMF operations?
Volker
</pre>
</blockquote>
<br>
</body>
</html>
--------------000309000904040006020004--
| Re: strange problem with "unresolved references" [message #102041 is a reply to message #102031] |
Wed, 07 February 2007 09:01   |
--------------090807060202050904020502
Volker,
A resource implementation will be generated and registered only if the
generator knows that special options are needed. If there is no such
need, the default XMIResourceFactoryImpl would be used. I don't think
GMF requires you to use GMFResourceFactory so you should register
XMIResourceFactoryImpl to handle your file extension. This can be done
using the editing domain's resource set's resource factory registry.
> Ed Merks <merks@ca.ibm.com> writes:
> No problem, I'm reading both newsgroups.
>> model?
> If the Eclipse type hierarchy isn't lying, there is no generated resource
> implementation - should there be one?
> I have to admit that I didn't really care about the resource implementation
> until I ran into problems. The EMF editor (method createModel) retrieves a
> resource from the editingDomain, and I didn't care what implementation was
> behind it. However, for the GMF integration I need a
> TransactionalEditingDomain that can be wrapped into a FileEditorInputProxy
> object, and this EditingDomain provides a GMFResource. This resource
> implementation in turn seems to use UUIDs as you mentioned.
> BTW, if my descriptions sound like a blind man prodding and poking around,
> that pretty much reflects what I'm doing here ;-)
> Volker
<html>
<head>
<title></title>
</head>
Volker,<br>
<br>
using the editing domain's resource set's resource factory registry.<br>
<br>
<br>
<blockquote cite="mid87fy9ijcse.fsf@sinclair.home.volker-wegert.de"
type="cite">
<pre wrap="">Ed Merks <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com"><merks@ca.ibm.com></a> writes:
</pre>
<pre wrap=""> I'm not sure why this posting didn't show up in both newsgroups.
</pre>
</blockquote>
</pre>
<pre wrap=""> Based on your latest comment I would ask if you are using the resource
model?
</pre>
</blockquote>
</pre>
<pre wrap=""> It sounds like you are using a resource that specifies to use
</pre>
</blockquote>
Volker
</pre>
</blockquote>
<br>
</body>
</html>
--------------090807060202050904020502--
| Re: strange problem with "unresolved references" [message #102050 is a reply to message #102041] |
Wed, 07 February 2007 09:29  |
> I don't think
That plus reading the TransactionalEditingDomain's header comment gave me tha
(okay, one of the) essential hints: I had to cleanup the GMF generated plugin
manifest because the registration performed there caused the GMFResource to be
pulled in. Thanks a lot! I'll try to find something to hit my head with, then
approach the next set of troubles...
Volker
* "Meistens belehrt uns erst der Verlust über den Wert der Dinge."
* (Arthur Schopenhauer)
Current Time: Thu Nov 20 23:06:59 EST 2025
Powered by FUDForum. Page generated in 0.07488 seconds
