Home » Newcomers » Newcomers » changing a project's location w/o moving it
changing a project's location w/o moving it [message #101844] Wed, 14 September 2005 19:20 Go to next message
Originally posted by: brettREMOVE.rockREMOVEnut.com
howdy,
i need to change my project to point to a different location
i tried editing the .location file (binary) and, as expected, eclipse does
not like this
using the "move" option, moves the files (which i do not want to do)
i know this is kinda screwy
i searched the posts and did not find anything
tia,
brett
ps. bonus question: anybody know whey this file is binary? i'd expect
xml for everything.
Re: changing a project's location w/o moving it [message #101897 is a reply to message #101844] Thu, 15 September 2005 07:17 Go to previous messageGo to next message
You should not be surprised that eclipse does not like that you change
..location file. This is an ***internal**** file in ***internal*** .metadata
directory structure!
This also explains why this file is not a user-friendly readable format...
By the way, I'm not sure to understand what you need exactly...
Can you provide more details on what do you want to do exactly (project
name and location before and after the move)?
brett wrote:
> howdy,
> does not like this
> tia,
> brett
> xml for everything.
Re: changing a project's location w/o moving it [message #102107 is a reply to message #101897] Thu, 15 September 2005 10:51 Go to previous messageGo to next message
what i want to do is copy my workspace and my build directories to have a
new working copy of the code (this is to "seed" a workspace for work on a
code branch)
setting up a workspace at my company is kinda a pain - our SCM plugins are
painful - thought i'd try this before i spend hours doing it the "right"
way
i can search/replace the path in all but the .location file
what i want to do is modify a project's location (and i don't want to do
it by moving the files via the "move" popup command)
thanks,
brett
Re: changing a project's location w/o moving it [message #102132 is a reply to message #102107] Thu, 15 September 2005 11:00 Go to previous messageGo to next message
Then, just copy your workspace and open a new eclipse session on
this copied workspace. There's no need to change projects locations
in this new workspace as all resources pathes are relative to workspace
location...
Copy workspaces is something I do very often and never get any problem
since 3.0 with this action...
> a new working copy of the code (this is to "seed" a workspace for work
> on a code branch)
> are painful - thought i'd try this before i spend hours doing it the
> "right" way
> do it by moving the files via the "move" popup command)
> thanks,
> brett
Re: changing a project's location w/o moving it [message #102249 is a reply to message #102132] Thu, 15 September 2005 14:30 Go to previous messageGo to next message
my source is outside my workspace - this might be the difference between
our environments - maybe this is unusual maybe this is why i couldn't find
posts on this topic
anyway, since there doesn't seem to be an "official" way to do this...
for future readers...
open .location w/ hex editor - edit the path - update the 2 bytes before
the path string to be the new length of the path
so far this seems to be working
if i don't post a reply to this you know i haven't had any issues w/ it
thanks,
brett
Re: changing a project's location w/o moving it [message #102396 is a reply to message #102249] Fri, 16 September 2005 02:18 Go to previous messageGo to next message
OK, I can figure out your configuration now.
Here's a proper way to change a project location after you have
copied its directory using file system:
1) Start eclipse session on your workspace
1) Delete project from your workspace
BE CAREFUL: in "Confirme Project Delete" dialog verify that
"Do not delete contents" button is selected
(this is the default behavior, but just to be sure...)
3) Import the copied project (ie. at new location) in your workspace
4) That's it!
It's a little bit longer but definitely better than modifying .location
file!
Furthermore, you can copy your worskpace so you can go back to your old
sources in your old worskpace as often as you want...
Another point, if you copy your source only to make new branches, why
don't you use CVS? Then, you do no longer need to do that as CVS allow
you to create as many branches as you want...
> find posts on this topic
> thanks,
> brett
Re: changing a project's location w/o moving it [message #102463 is a reply to message #102249] Fri, 16 September 2005 10:26 Go to previous messageGo to next message
NO!
For future readers this it DEFINITELY NOT what you want to do. As
someone earlier in the thread pointed out, the .location file is an
internal piece of metadata that is not intended to be user-modifiable.
Moving projects and workspaces around is not that difficult if you take
the time to really understand how Eclipse manages them and expects you
to manage them.
There is always a better way, just ask (and give enough detail so others
can help).
Eric
Re: changing a project's location w/o moving it [message #1713056 is a reply to message #102463] Fri, 30 October 2015 08:46 Go to previous messageGo to next message
Can someone please tell how to get the path of a Project file thats outside the workspace?
I have been trying different solutions but am unable to get an answer.
Re: changing a project's location w/o moving it [message #1713062 is a reply to message #1713056] Fri, 30 October 2015 09:56 Go to previous message
What happens when you right-click on the project or a file in the
project and choose Properties?
Previous Topic:How to set connection timeout with Jetty 9.2.10?
Next Topic:CDT Installation problem on Luna - "cannot perform operation"
Current Time: Fri Jul 18 23:48:12 EDT 2025
Powered by FUDForum. Page generated in 0.09800 seconds
