Cannot start runtime workbench in QNX [message #101724] |
Mon, 28 July 2003 14:36  |
I'm trying to launch "Hello World" plugin in QNX (Eclipse 2.1.1). On the
start I can see a splash screen and stack trace in the console window.
Please, take a look at the .log file. Any ideas what can be wrong? The
same plugin with the same runtime parameters works fine in Win98. In QNX I
can launch a Java application, but a plugin gets stuck.
Sincerely,
Serge
!SESSION
!ENTRY org.eclipse.core.launcher 4 0 Jul 28, 2003 14:16:28.184
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.reflect.InvocationTargetException:
java.lang.reflect.InvocationTargetException: java.lang.StackOverflowError
Stack trace:
java/lang/Throwable.<init>()V
java/lang/Throwable.<init>(Ljava/lang/String;)V
java/lang/StackOverflowError.<init>(Ljava/lang/String;)V
java/lang/String.toLowerCase()Ljava/lang/String;
java/net/URL.setupStreamHandler()V
java/net/URL.<init> (Ljava/net/URL;Ljava/lang/String;Ljava/net/URLStreamHandler; )V
java/net/URL.<init>(Ljava/lang/String;)V
java/net/URLClassLoader.findClassImpl([Ljava/net/URL;Ljava/l ang/String;)Ljava/lang/Class;
java/net/URLClassLoader$4.run()Ljava/lang/Object;
java/security/AccessController.doPrivileged(Ljava/security/P rivilegedAction;Ljava/security/AccessControlContext;)Ljava/l ang/Object;
java/net/URLClassLoader.findClass(Ljava/lang/String;)Ljava/l ang/Class;
java/lang/ClassLoader.loadClass(Ljava/lang/String;Z)Ljava/la ng/Class;
java/lang/ClassLoader.loadClass(Ljava/lang/String;)Ljava/lan g/Class;
org/eclipse/core/internal/boot/DelegatingURLClassLoader.find ClassParents(Ljava/lang/String;Z)Ljava/lang/Class;
org/eclipse/core/internal/plugins/PluginClassLoader.internal FindClassParentsSelf(Ljava/lang/String;ZLorg/eclipse/core/in ternal/boot/DelegatingURLClassLoader;Z)Ljava/lang/Class;
org/eclipse/core/internal/boot/DelegatingURLClassLoader.find ClassParentsSelf(Ljava/lang/String;ZLorg/eclipse/core/intern al/boot/DelegatingURLClassLoader;Z)Ljava/lang/Class;
org/eclipse/core/internal/boot/DelegatingURLClassLoader.load Class(Ljava/lang/String;ZLorg/eclipse/core/internal/boot/Del egatingURLClassLoader;Ljava/util/Vector;Z)Ljava/lang/Class;
org/eclipse/core/internal/boot/DelegatingURLClassLoader.load Class(Ljava/lang/String;Z)Ljava/lang/Class;
java/lang/ClassLoader.defineClassImpl(Ljava/lang/String;[BII )Ljava/lang/Class;
java/lang/ClassLoader.defineClass(Ljava/lang/String;[BIILjav a/security/ProtectionDomain;)Ljava/lang/Class;
java/security/SecureClassLoader.defineClass(Ljava/lang/Strin g;[BIILjava/security/CodeSource;)Ljava/lang/Class;
org/eclipse/core/internal/boot/DelegatingURLClassLoader.find Class(Ljava/lang/String;)Ljava/lang/Class;
org/eclipse/core/internal/boot/DelegatingURLClassLoader.acce ss$0(Lorg/eclipse/core/internal/boot/DelegatingURLClassLoade r;Ljava/lang/String;ZLorg/eclipse/core/internal/boot/Delegat ingURLClassLoader;Ljava/util/Vector;Z)Ljava/lang/Class;
org/eclipse/core/internal/boot/DelegatingURLClassLoader$Dele gateLoader.loadClass(Ljava/lang/String;Lorg/eclipse/core/int ernal/boot/DelegatingURLClassLoader;Lorg/eclipse/core/intern al/boot/DelegatingURLClassLoader;Ljava/util/Vector;)Ljava/la ng/Class;
org/eclipse/core/internal/boot/DelegatingURLClassLoader.find ClassPrerequisites(Ljava/lang/String;Lorg/eclipse/core/inter nal/boot/DelegatingURLClassLoader;Ljava/util/Vector;)Ljava/l ang/Class;
org/eclipse/ui/views/navigator/ResourceNavigator.createViewe r(Lorg/eclipse/swt/widgets/Composite;)Lorg/eclipse/jface/vie wers/TreeViewer;
org/eclipse/ui/views/navigator/ResourceNavigator.createPartC ontrol(Lorg/eclipse/swt/widgets/Composite;)V
org/eclipse/ui/internal/PartPane$4.run()V
org/eclipse/core/internal/runtime/InternalPlatform.run(Lorg/ eclipse/core/runtime/ISafeRunnable;)V
org/eclipse/core/runtime/Platform.run(Lorg/eclipse/core/runt ime/ISafeRunnable;)V
org/eclipse/ui/internal/PartPane.createChildControl()V
org/eclipse/ui/internal/ViewPane.createChildControl()V
org/eclipse/ui/internal/ViewFactory$2.run()V
org/eclipse/ui/internal/ViewFactory.busyRestoreView(Lorg/ecl ipse/ui/IViewReference;)Lorg/eclipse/core/runtime/IStatus;
org/eclipse/ui/internal/ViewFactory$1.run()V
org/eclipse/swt/custom/BusyIndicator.showWhile(Lorg/eclipse/ swt/widgets/Display;Ljava/lang/Runnable;)V
org/eclipse/ui/internal/ViewFactory.restoreView(Lorg/eclipse /ui/IViewReference;)Lorg/eclipse/core/runtime/IStatus;
org/eclipse/ui/internal/ViewFactory$ViewReference.getPart(Z) Lorg/eclipse/ui/IWorkbenchPart;
org/eclipse/ui/internal/WorkbenchPage$1.propertyChange(Lorg/ eclipse/jface/util/PropertyChangeEvent;)V
org/eclipse/ui/internal/LayoutPart.setVisible(Z)V
org/eclipse/ui/internal/PartPane.setVisible(Z)V
org/eclipse/ui/internal/PartTabFolder.setSelection(Lorg/ecli pse/ui/internal/LayoutPart;)V
org/eclipse/ui/internal/PartTabFolder.setSelection(I)V
org/eclipse/ui/internal/PartTabFolder.createControl(Lorg/ecl ipse/swt/widgets/Composite;)V
org/eclipse/ui/internal/PartSashContainer.createControl(Lorg /eclipse/swt/widgets/Composite;)V
org/eclipse/ui/internal/PerspectivePresentation.activate(Lor g/eclipse/swt/widgets/Composite;)V
org/eclipse/ui/internal/Perspective.onActivate()V
org/eclipse/ui/internal/WorkbenchPage.onActivate()V
org/eclipse/ui/internal/WorkbenchWindow$7.run()V
org/eclipse/ui/internal/WorkbenchWindow.setActivePage(Lorg/e clipse/ui/IWorkbenchPage;)V
org/eclipse/ui/internal/WorkbenchWindow.busyOpenPage(Ljava/l ang/String;Lorg/eclipse/core/runtime/IAdaptable;)Lorg/eclips e/ui/IWorkbenchPage;
org/eclipse/ui/internal/WorkbenchWindow$6.run()V
org/eclipse/ui/internal/WorkbenchWindow.openPage(Ljava/lang/ String;Lorg/eclipse/core/runtime/IAdaptable;)Lorg/eclipse/ui /IWorkbenchPage;
org/eclipse/ui/internal/Workbench.openFirstTimeWindow()V
org/eclipse/ui/internal/Workbench.init([Ljava/lang/String;)Z
org/eclipse/ui/internal/Workbench.run(Ljava/lang/Object;)Lja va/lang/Object;
org/eclipse/core/internal/boot/InternalBootLoader.run(Ljava/ lang/String;Ljava/net/URL;Ljava/lang/String;[Ljava/lang/Stri ng;Ljava/lang/Runnable;)Ljava/lang/Object;
org/eclipse/core/boot/BootLoader.run(Ljava/lang/String;Ljava /net/URL;Ljava/lang/String;[Ljava/lang/String;Ljava/lang/Run nable;)Ljava/lang/Object;
java/lang/reflect/AccessibleObject.invokeL(Ljava/lang/Object ;[Ljava/lang/Object;)Ljava/lang/Object;
java/lang/reflect/Method.invoke(Ljava/lang/Object;[Ljava/lan g/Object;)Ljava/lang/Object;
org/eclipse/core/launcher/Main.basicRun([Ljava/lang/String;) Ljava/lang/Object;
org/eclipse/core/launcher/Main.run([Ljava/lang/String;)Ljava /lang/Object;
org/eclipse/core/launcher/Main.main([Ljava/lang/String;)V
Re: Cannot start runtime workbench in QNX [message #102629 is a reply to message #101724] |
Tue, 29 July 2003 15:54  |
I found a solution. Since I work with the J9 v1.5 I need to adjust some VM
parameters such as stack size and etc.
Actually I did it after I fell back to Eclipse 2.1.0. Perhaps I can do the
same in 2.1.1, but I didn't test it.
> Sincerely,
> Serge
> !SESSION
> !STACK
> Stack trace:
FUDForum. Page generated in 0.05424 seconds
