Home » Archived » BIRT » URL of datasource as parameters?
URL of datasource as parameters? [message #101600] Thu, 22 December 2005 05:49 Go to next message
Originally posted by: XnoXspamXyeecn.pd.jaring.my
Is it possible to parameterize the datasource of a report? My particular use
case is that my application is serving different customers, and it is
switching database connections behind the secne depends on the user's login.
I like to have my reports able to switch database as well. Is this possible
with BIRT?
Thanks my advance.
Yee
Re: URL of datasource as parameters? [message #102610 is a reply to message #101600] Tue, 27 December 2005 15:37 Go to previous messageGo to next message
Yes it's possible. With BIRT 2.0 there are two ways to do this:
(1) Use Data Source Property Binding. This is a new feature added to 2.0 and
you will need the latest nightly build (post-M3) to see this work. A
description of this feature is here:
http://www.eclipse.org/birt/wiki/index.php?n=BPS.BPS40. You can, for
example, bind a JDBC data source's URL property to a Javascript expression
that returns a url constructed based on the user login (the user login in
turn can be passed in as a report parameter).
(2) Use BIRT Scripting. In the Data Source's beforeOpen script (or its
script event handler's
org.eclipse.birt.report.engine.api.script.eventHandler.befor eOpen method, if
you are using the new Java scripting feature), you can set the data source's
URL connection property to a value based on runtime settings. For more
information and code example, search this newsgroup - there had been some
previous posts on this topic.
regards,
Gary Xue
Actuate Corporation - Product Development
BIRT Committer
"YeeCN" <XnoXspamXyeecn@pd.jaring.my> wrote in message
news:doe0cv$ram$1@utils.eclipse.org...
use
login.
possible
> with BIRT?
> Thanks my advance.
> Yee
Re: URL of datasource as parameters? [message #102715 is a reply to message #102610] Wed, 28 December 2005 04:08 Go to previous message
Originally posted by: zhangliang.vip.gmail.com
it's ok,can use the params to change the datasource.
Previous Topic:can use the url in the chart ?
Next Topic:How to add a vertical column?
Current Time: Sun Jul 27 12:49:28 EDT 2025
Powered by FUDForum. Page generated in 0.06221 seconds
