Home » Language IDEs » AspectJ » Novice question on the use of static introductions
Novice question on the use of static introductions [message #9264] Fri, 25 October 2002 14:38 Go to next message
Originally posted by: john_daly.hp.com
I'm attempting to use static introductions in a code based with the
following package structure and would like to have the stated
introductions weaved into all classes from 'src' package down recursively.
Package Structure
src (main package)
src.shp (shape package including a sample shape class: Shape.java)
src.shp.tst (tst packagge including sample test class: Test.java)
src.log (log package including sample logger aspect: Logger.java)
Logger Aspect
public aspect Logger
public static void (src.*.*.*).fatal(Object message)
System.out.println(message);
In the code above the 'src.*.*.*' introduces the method 'fatal' only into
the
'Test.java' class found in 'src.shp.tst'but not into any of the classes
above it in the package hierarchy.
Is there a syntax for specifying all classes in all packages below a
certain package level? I'm thinking of something similar to the mechanism
for selecting subtypes(i.e. Shape+)but have been unsuccessful in determing
if such a selection mechanism exists.
Thanks in advance for any pointers or thoughts.
Re: Novice question on the use of static introductions [message #9325 is a reply to message #9264] Mon, 28 October 2002 08:20 Go to previous messageGo to next message
Hi John,
The wildcard pattern src..* will match every class in the src package, its
subpackages, and inner classes. (You could also be more specific with
src.shp..* etc if you wanted).
FYI for the future, the best place to ask these kinds of questions is on
the AspectJ mailing list. See
http://aspectj.org/servlets/AJSite?channel=userCommunity& ;subChannel=mailingLists
This newsgroup is primarily for issues dealing with the AJDT plugin to
Eclipse.
Julie Waterhouse
AJDT Development Team
John Daly wrote:
> Hello,
> I\'m attempting to use static introductions in a code based with the
> introductions weaved into all classes from \'src\' package down recursively.
> Package Structure
> src (main package)
> Logger Aspect
> In the code above the \'src.*.*.*\' introduces the method \'fatal\' only into
> the
> \'Test.java\' class found in \'src.shp.tst\'but not into any of the classes
> certain package level? I\'m thinking of something similar to the mechanism
Re: Novice question on the use of static introductions [message #9349 is a reply to message #9325] Mon, 28 October 2002 11:51 Go to previous message
Julie,
Thanks for the response and sorry for the incorrect newsgroup post.
-jd
Julie Waterhouse wrote:
> Hi John,
> Eclipse.
> Julie Waterhouse
> John Daly wrote:
> > Hello,
> > I\\\'m attempting to use static introductions in a code based with the
> > introductions weaved into all classes from \\\'src\\\' package down
recursively.
> > Package Structure
> > src (main package)
> > Logger Aspect
> > In the code above the \\\'src.*.*.*\\\' introduces the method
\\\'fatal\\\' only into
> > the
> > \\\'Test.java\\\' class found in \\\'src.shp.tst\\\'but not into any of
the classes
> > certain package level? I\\\'m thinking of something similar to the
mechanism
Re: Novice question on the use of static introductions [message #562367 is a reply to message #9264] Mon, 28 October 2002 08:20 Go to previous message
Hi John,
Eclipse.
Julie Waterhouse
John Daly wrote:
> Hello,
> Package Structure
> src (main package)
> Logger Aspect
> the
Re: Novice question on the use of static introductions [message #562391 is a reply to message #9325] Mon, 28 October 2002 11:51 Go to previous message
Julie,
-jd
> Hi John,
> Eclipse.
> Julie Waterhouse
> John Daly wrote:
> > Hello,
recursively.
> > Package Structure
> > src (main package)
> > Logger Aspect
> > the
the classes
mechanism
Previous Topic:ADJT and workspace build errors
Next Topic:Specification of Build Path - Output
Current Time: Sun Aug 31 23:05:05 EDT 2025
Powered by FUDForum. Page generated in 0.04847 seconds
