Home » Language IDEs » C / C++ IDE (CDT) » CDT Cygwin
CDT Cygwin [message #101465] Wed, 05 May 2004 03:10 Go to next message
Originally posted by: rn.yahoo.com
HI, I am a absolute beginner in this eclipse thing. I am trying to use CDT
2.0 for the latest eclipse (M8). i installed cygwin.
***is eclipse supposed to find out where cygwin is and use it automatically?
***I cannot build. how do i manually tell eclipse to look for cygwin and
make and gcc or g++?
thanks for all the help!!
Re: CDT Cygwin [message #101483 is a reply to message #101465] Wed, 05 May 2004 03:34 Go to previous messageGo to next message
make sure you have "C:\cygwin\bin" in your PATH variable.
Re: CDT Cygwin [message #101508 is a reply to message #101465] Wed, 05 May 2004 05:03 Go to previous messageGo to next message
Originally posted by: nospam-marcus.lindblom.junglepeak.com
I solved this by starting eclipse from a Cygwin shell prompt. You could
probably do something automatically by making bash run eclipse.exe directly
instead of creating an interactive login prompt. (I think the -e flag does
that, check the man page.)
However, whether this is the Right Way(tm) or not, I can't say. :)
/Marcus
"R" <rn@yahoo.com> wrote in message news:c7a3kv$6ar$1@eclipse.org...
automatically?
Re: CDT Cygwin [message #101531 is a reply to message #101508] Wed, 05 May 2004 10:40 Go to previous messageGo to next message
appreciate the help!! I have cygwin in my path. to check this i typed "make"
from "win+run" and it works fine. but i "build all" and "build
project"option in project are not active.
and how do i run eclipse from cygwin? sorry i am a novice.
"Marcus Lindblom" <nospam-marcus.lindblom@junglepeak.com> wrote in message
news:c7aa8i$eqg$1@eclipse.org...
directly
> /Marcus
CDT
> automatically?
Re: CDT Cygwin [message #101566 is a reply to message #101483] Wed, 05 May 2004 10:47 Go to previous messageGo to next message
does cygwin have to be installed in C:\ or cani install it somwhere else? i
have both eclipse and cygwin installed in
e:\programs\ which in a different hd than the one i use to load windows.
"Compuhelp" <compuhelp@caramail.com> wrote in message
news:c7a52i$7ql$1@eclipse.org...
CDT
automatically?
Re: CDT Cygwin [message #101679 is a reply to message #101531] Thu, 06 May 2004 12:00 Go to previous message
Your first question is non-cygwin specific. Make sure you have a C++
project, and fiddle from there. I've only used in for a few days, with
managed mode only. If you have such a project, and save a .h or .cpp file,
it should compile automatically (check the console).
As for the second, start the Cygwin bash shell (in the start-menu), cd to
your eclipse dir and just type eclipse.exe &. (the & is not required, but
puts eclipse in the background so that you can continue to do other things
in the shell).
/Marcus
"kevin" <kahcor@yahoo.com> wrote in message news:c7au18$9g1$1@eclipse.org...
"make"
> directly
does
> > /Marcus
> CDT
> > automatically?
and
Previous Topic:launching issue
Next Topic:How to disable linking
Current Time: Sun Jun 08 01:40:31 EDT 2025
Powered by FUDForum. Page generated in 0.03886 seconds
