Home » Language IDEs » Java Development Tools (JDT) » [ANN] RMI Plugin for Eclipse & WSAD v1.5.5-beta1
[ANN] RMI Plugin for Eclipse & WSAD v1.5.5-beta1 [message #101421] Sun, 05 October 2003 09:48
A new beta release of the RMI plugin is now available at
http://www.genady.net/rmi/index.html?/rmi/ver150.html&MA IN
The new features are:
* Performance improvements in identifying remote classes. This is
most significant for projects with many classes that only few of them
are remote classes.
* Fully tested with WSAD 5.1 (trial)
* Initial work on new compilers infrastructure.
* Added diagnostics field to the project's RMI properties page
* Fixed piece of code that did not compile with JDK 1.3
* Better logging and progress notification for direct class compilation
* Get the rmiregistry executable from the default JVM installation
(that is checked in the Installed JREs page)
* Removed the last bits of code that should have supported
rmi-iiop/corba but were never actually tested.
* The new version does not require a new license key.
Please report any problems you encounter to rmi-bugs@genady.net.
I would mostly appreciate feedback from Linux and MacOS X developers.
Warning: Only internal compilation (i.e., tools.jar) was tested.
Make sure you read the FAQ
(http://www.genady.net/forum/viewforum.php?f=4) on the forums
(http://www.genady.net/forum/)
Enjoy,
Genady Beryozkin
Previous Topic:Generics are here (no, not in eclipse)
Next Topic:How to browse JDK Java Docs from Eclipse
Current Time: Sun Jul 13 13:30:43 EDT 2025
Powered by FUDForum. Page generated in 0.04687 seconds
